Blue88Comanche Posted May 20, 2012 Share Posted May 20, 2012 fixed dads engine problem, one of the injector connections where disconnected somehow. changed the speedometer gear in dads MJ so the speedometer works with the new rear axle. and about to wash the MJs Link to comment Share on other sites More sharing options...
Zenobian_84 Posted May 20, 2012 Share Posted May 20, 2012 Installed the 2.5 litre badge on the tailgate, along with the Jeep letters from Spence over @ Jeepstickers. Working on getting my horn fixed.... :fs1: Link to comment Share on other sites More sharing options...
SW86 Posted May 21, 2012 Share Posted May 21, 2012 painted it white over this past weekend. next is the yellow touches Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 21, 2012 Share Posted May 21, 2012 Installed the 2.5 litre badge on the tailgate, along with the Jeep letters from Spence over @ Jeepstickers. Working on getting my horn fixed.... :fs1: Do you have any pics of the 2.5 badge?? I would love to see if this would be something for my truck. Link to comment Share on other sites More sharing options...
Paul Bruchal Posted May 21, 2012 Share Posted May 21, 2012 Cut most of it off. more tomorrow Link to comment Share on other sites More sharing options...
Zenobian_84 Posted May 21, 2012 Share Posted May 21, 2012 Installed the 2.5 litre badge on the tailgate, along with the Jeep letters from Spence over @ Jeepstickers. Working on getting my horn fixed.... :fs1: Do you have any pics of the 2.5 badge?? I would love to see if this would be something for my truck. Old picture, but the best one I have of it on the truck. If you want me to take another, updated picture, I can in the morning. It definitely gives some identity to the pickup, that's for sure. :cheers: The badge by itself. Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 22, 2012 Share Posted May 22, 2012 Right on! :cheers: Link to comment Share on other sites More sharing options...
skidoo_j Posted May 22, 2012 Share Posted May 22, 2012 Hauled the dredge. Doesn't look like i got anything worth jumping up and down ove. Gave the comanche a bath. Put tire wax on the rubber. Cleaned out the cab and cleaned up some of the wiring. Link to comment Share on other sites More sharing options...
apexjeepinjoe Posted May 22, 2012 Share Posted May 22, 2012 Got my exhaust leak fixed. Then I went and passed my emissions test with flying colors. :banana: Link to comment Share on other sites More sharing options...
apexjeepinjoe Posted May 25, 2012 Share Posted May 25, 2012 Installed a 1999 era Clarion pro receiver so now I have tunes!! PO had the wiring so messed up it took me a bit to get it all figured out. Link to comment Share on other sites More sharing options...
mvusse Posted May 25, 2012 Share Posted May 25, 2012 Cut of the remains of the driver side lower control arm bracket. Made two tabs out of 1/4" steel and tacked them on. Still need to grind one edge flat and cut a skid plate/cross connector. Then to a buddy's to have them burned on permanently. Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 25, 2012 Share Posted May 25, 2012 enjoyed the simple things in life, cleaned it head to toe just to get it muddy again Link to comment Share on other sites More sharing options...
relyt120 Posted May 30, 2012 Share Posted May 30, 2012 Replaced the battery box with one that isn't broken ,the old one was smacking the cooling fan and belt. - Reminded me of using cards on bicycle to sound cool. :chillin: BUT probably not good for my belt... :fs1: Link to comment Share on other sites More sharing options...
aaronbtxnc Posted May 31, 2012 Share Posted May 31, 2012 Spent about 6 hours (from 5 pm til 11pm) working on a bed swap. I removed tail lights from driver and parts truck, removed gas tank skid plate from both trucks, removed gas tank from both trucks (first one was a bit of a challenge with me stuck holding the almost half full tank for nearly 40 minutes while my friends were trying to figure out what was still holding it :mad: , turns out that just loosening the clamps on the filler neck and vent lines isn't enough, you need to go ahead and get the hoses off the metal part :doh: , second one took about 5 minutes), removed exhaust hanger and spare jack from parts truck, and removed 6 of 8 bed bolts from parts truck and what I thought were the other two bed bolts but as soon as I got them out I thought they weren't, and they weren't, they were the two bolts just ahead or behind maybe the back bed bolts that have to be accessed through the frame, I have to get a longer extension for my ratchet to get these last 2 out. I only got about half way though the swap, it'll be Saturday before I can get back to it and hopefully done. I wish swapping beds was as easy as on my Ranger was, 6 bolts from the top, disconnect taillights and disconnect fuel filler neck and pull it off. My arse is dragging this morning! Be watching your computers for questions I may run in to Saturday morning/afternoon. Link to comment Share on other sites More sharing options...
mvusse Posted May 31, 2012 Share Posted May 31, 2012 Finished getting the power windows in the Purple People Eater working. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 31, 2012 Share Posted May 31, 2012 spent 30 min trying out how how the belt tension adjuster works, then changed the alternator on dads jeep Link to comment Share on other sites More sharing options...
skidoo_j Posted June 1, 2012 Share Posted June 1, 2012 tinted windows with gila 20%. not bad for under $30 Link to comment Share on other sites More sharing options...
my86mj Posted June 3, 2012 Share Posted June 3, 2012 pulled pretty much all of my emissions gizmos off. pulled all the vacuum lines that went with it. freed up a lot of space. then did valve cover gaskets and painted my covers lime green. then did a tune up and pulled the glass pack off so i can actually here myself go down the road. Link to comment Share on other sites More sharing options...
skidoo_j Posted June 5, 2012 Share Posted June 5, 2012 replaced the harmonic balancer. Trying to chase down a belt squeal to no avail. The old balancer was probably on it's way out as the rubber was becoming disconnected and a pretty good piece came out so i don't feel too bad having replaced it. But am even more confused now as to the cause of my serp belt squeal caused by it moving on the clutch fan pulley. Link to comment Share on other sites More sharing options...
mvusse Posted June 5, 2012 Share Posted June 5, 2012 Bought 15' of 16/3 extension cord, one toggle switch with a safety cover and one momentary toggle switch for Wilbur. Link to comment Share on other sites More sharing options...
Squeegy410 Posted June 5, 2012 Share Posted June 5, 2012 replaced the harmonic balancer. Trying to chase down a belt squeal to no avail. The old balancer was probably on it's way out as the rubber was becoming disconnected and a pretty good piece came out so i don't feel too bad having replaced it. But am even more confused now as to the cause of my serp belt squeal caused by it moving on the clutch fan pulley. I had one a few Weeks ago that was just a junky belt. Ended up getting a more expensive ones that didn't feel like hard plastic and that did the trick. Link to comment Share on other sites More sharing options...
mvusse Posted June 5, 2012 Share Posted June 5, 2012 Wired up in cab winch controls. Link to comment Share on other sites More sharing options...
TylerJY Posted June 6, 2012 Share Posted June 6, 2012 Pressure washed it/the engine bay Replaced my DS Headlight with the Autopal H4 conversion (leaving the other side for tomorrow so i can get some comparison shots) Replaced my power steering fluid reservoir that was leaking like crazy Replaced my intermediate steering shaft that was popping like crazy Link to comment Share on other sites More sharing options...
aaronbtxnc Posted June 6, 2012 Share Posted June 6, 2012 ... is what I did this past weekend, and got started on my abnormally difficult seat swap this evening thread link Link to comment Share on other sites More sharing options...
aaronbtxnc Posted June 9, 2012 Share Posted June 9, 2012 Decided to pull my carpet and tackle that hole I found last weekend when I finally decided to look up from the bottom... Got the seat and carpet pulled before breakfast (I'm eating it now) and am about to (hopefully if it's good) rob the metal I need from the parts truck. Link to comment Share on other sites More sharing options...
