apexjeepinjoe
Everything posted by apexjeepinjoe
  1. Yeah I wouldn't screw with it at all.
  2. I am looking for a chrome grill for my 88. No cracks or missing pieces. Let me know.
  3. It was not an easy job but it fits great(and no leaks at all). http://www.rakuten.com/prod/edv700bt-crl-duo-vent-four-panel-slider-with-dark-gray-glass-for-1986/227017184.html I had a coupon and I guess they raised the price since I ordered just since the beginning of April.
  4. You can still buy brand new. I just got a 4 pc rear sliding glass in Smoke for 150.00 Shipped
  5. I would offer 1/2 of that max.
  6. Installed the rear sliding glass I bought. Scraping the urethane was the worst part.
  7. I just installed a set in the front of my comanche with 2 inch lift and they do seem a tad short. I also installed JKS bar pin eliminator kit which adds a bit of length. I ran these this way on an 89 Cherokee I had with 3 inch lift and never has a problem.
  8. Finally got my ACOS installed. Also installed some JK front shocks.
  9. Just got my card in the mail. $56 bucks for the year here in Idaho. Plus $20 every other year for emissions.
  10. How much does a new TPS cost?
  11. I have an 1988 4.0 w/manual transmission. When I start it it seems to idle fine but as it warms up it act as if it gets stuck on high idle. I can not kick it down but if I shut it off and wait when I restart it. It starts the cycle all over again. Any ideas of what to check or what it might be? Throttle position sensor or Idle air control??
  12. Just the upper part.
  13. No I did that on mine works fine. My AX15 is from a 98 TJ.
  14. Search Tempest.
  15. Just use the shifter from the BA10 transmission
  16. Spline count is different. You need to change the shafts.
  17. 3.89 a gal for unleaded here.
  18. About 2 inches of lift and hopefully get rid of the lean to the left.
  19. I am trying to decide if I should have my stock rear springs re-curved or just buy some metric ton springs. Any suggestion on which way to go.
  20. Turned over the grill after realizing it was in upside down. Re installed my front drive shaft after putting some new u joints in. Then drove it around for awhile.
  21. I have only seen a handful of MJs here in Boise myself.
  22. What no hats??!!
  23. 04338855 that is the spring clip.
