6
Everything posted by Limeyjeeper
Jeepcables.com
88 MJ, "she's for the streets"
Limeyjeeper replied to Car Enthusiast's topic in Member Projects: Your Comanches
Looks awesome!! -
Comanche Dawn
Limeyjeeper replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Some guys moved to a Volvo electric PS pump. That might be an option for you. Borgeson Electric Power Steering - LS1TECH - Camaro and Firebird Forum Discussion -
Comanche Dawn
I think the problem is that the Corvette pump is very small and doesn't deal with a lot of distance from the tank. When I had the G8 setup I probably had 2 feet of hose. It squealed like a pig. It wasn't cavitation. I just don't think the pump had enough power to pull the fluid through that much hose when you think the stock hose from the reservoir to the pump is no more than 3"!!! -
Bored out throttle body
Limeyjeeper replied to jamespwsullivan's topic in MJ Tech: Modification and Repairs
Leigh performance machine still does them. www.strokedjeep.com -
I used a G8 remote reservoir for a little while. The pump didn't like the extended hose length, made a lot of not good noises. Went back to the standard corvette setup with the tank right above the pump. No more noises
High $ Listings on Hemmings
Limeyjeeper replied to NHMJXJ's topic in Craigslist/eBay... i.e. Not Your Stuff
Sure looks like it. -
Project “Tomahawk”
Limeyjeeper replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I would probably do an auto. The LS torque curve doesn't lend itself very well to a 5 speed. Or I would go with 3.73 gears nor 3.55. The LS makes its power once you get over 2.5k revs. The LS1 intake doesn't help that moves up the torque and power curve. A good tune might fix some of it too. Still haven't got around to getting the LS on a dyno. -
Comanche Dawn
I have had this really annoying rear transfer case seal leak, well that is what I thought it was. Turns out the crappy Spicer slip yoke is what is leaking. After several rear transfer case seal swaps with no fix I decided to stand my driveshaft on its end and I filled the slip yoke spline shaft with ATF. Sure enough the next morning I looked at the yoke and fluid was pooling behind the yoke base. Never seen this before. I wonder how many people fighting transfer case leaks really don't have a seal issue but a leaking yoke. -
Project “Tomahawk”
I had one in my LJ. Very poor German truck transmission and it had a shift throw that was insanely long. B&M makes a short throw shifter which helped a bit. Mine only had around 35k on it and it was impossible to shift quickly. The syncro's were really weak. A Tremec TKX or a TR4050 would be the best choice. However, the old AX15 is a pretty stout trans too. -
If anybody is looking for connectors these guys are about the best. Very clear pictures and connectors and pins are all cross referenced. I have found this site really helpful in identifying connectors. Automotive Electrical Connectors | Weather Pack, Deutsch, Metri-Pack, 56 Series, ECM/PCM, Relays, Buss, Splice, Fuse | Custom Connector Kits
Replacement AC Liquid Line?
Limeyjeeper replied to BizarroStormy's topic in MJ Tech: Modification and Repairs
Very hard to find. Probably need to get one made or go to a junkyard. You can ditch the brass valve which does absolutely nothing and then you have a more standard fitting on the drier. Both ends would then be No 6 fittings. -
That is a really cool looking unit. Got to be either running Android or just apple car play and Android Auto. From the Walmart site the specs look pretty impressive. It would definitely fit in a pre 97. I have a 6.5" Joying which works well, but I wish it was a bit shorter. This one would be perfect. Single Din Multimedia System w/ 6.5” LCD Color Capacitive Touchscreen Wireless Apple CarPlay® with Siri® Eyes-Free Wireless Android Auto™ with Google Assistant™ *with Firmware Update (See link below) Bluetooth V5.0 Calling + A2DP Music Streaming Customizable Background and Startup App *with Firmware Update (See link below) Advanced FM/AM Tuner with RDBS Data Display Accepts OEM Steering Wheel Control Interfaces 10-Band Digital Audio EQ & with User Presets Wireless Direct Select Remote Control Included Front & Rear View Back-up Camera Inputs Hands-Free Profile Dials & Receives Calls & Displays Call Logs Phone Book Access Profile Displays Caller ID Info & Contacts Audio/Video Remote Control Profile Enables Playback Controls Advanced Audio Distribution Profile Streams Audio Wirelessly Built-in Microphone for Mobile Phone Hands-free Calling USB/SD Audio/Video Playback Playback of MP3 & WMA, & Other Audio Files, Up to 64GB Playback of 1080P MP4 & Other Video Files, Up to 64GB View JPEG, GIF, PNG, BMP, & Other Image Files, Up to 64GB ID3 MP3 Tag Reading for Track & Artist Information New Dynamic User Interface w/ SmartSense Touchscreen 6.5” HD Quality 1,024x600 Resolution TFT-LCD Display Pinpoint Accuracy Capacitive Touchscreen Low Reflection Industrial Grade Glass Top Panel Large Format User Interface Reduces Distraction
I just had my worse, to date, late midlife crisis and bought a GMC Syclone. Always had a love affair with this vehicle it is so cool. If anybody is going to be at the Carlisle Truck Nationals it will be there with a bunch of others. 36k miles, totally clean. It is fast. Not sure I am liking the bed cover. Paint is almost perfect for the age. It is almost exactly the same size as a Comanche but has a much better driving position. I keep telling myself it is an investment as they only made 2,900 of them. Was the fastest pickup truck until the TRX came out. Held the honor for 30 years.
Comanche Dawn
I had the mount in its most rear position. The motor sits really close to the bulkhead. -
Comanche Dawn
Very late with the update. Got the Quickdraw bellhousing installed. Much better setup than the Novak adapter. However, I had to lop a bit off the top of the bellhousing to get it to fit. If you are dropping the engine and trans in together it might fit. If I had removed the radiator etc. to allow me to drop the engine even further, I might have got it, but it would probably have needed the headers to be removed. Stock external slave cylinder works perfectly. Overall, a nice setup. Allowed me to move the transmission up another inch or so, which has stopped my transfer case tailhousing leak. Next project is to get the under-dash wiring organized. I have been in there too many times to troubleshoot a couple of things and now it is interfering with the accelerator pedal - Not good. -
Well done, great truck and your sense of adventure is awesome!!
What an amazing, once in a lifetime experience!!
April 2024 - Eureka's Pioneer Metric Ton
Limeyjeeper replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Good looking truck. Congrats. -
Ordering front end parts
Limeyjeeper replied to Spinnakerblue89's topic in MJ Tech: Modification and Repairs
Do not go aftermarket on Header panel. The aftermarket ones are primarily junk. Very flimsy and don't fit well. Find a good used one at a junkyard. Aftermarket headlight bezels are hit and miss. You can find usually find OEM grills on Ebay. Again, aftermarket is hit or miss. As you have a pre 91 the headlight bezels are two piece (very hard to find OEM, not made aftermarket except as one piece) and the header panel has the metal strips which no aftermarket has. After 90 the header panel lost the metal strips, and the headlight bezels are a different one-piece design. Not interchangeable. You would need an after 90 header panel, headlight bezels and grille. -
What exhaust do you recommend?
Limeyjeeper replied to ExpatMJGuy's topic in MJ Tech: Modification and Repairs
Go with a Walker factory replacement. Works fine and pretty cheap. -
Electrical connectors compilation
Limeyjeeper replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
That is an outstanding idea. I had so much trouble with my build identifying some of the connectors that I gave up and changed to Deutch!!
