9
Everything posted by 87MJTIM
The part in and of itself may be fine, it's just that when it fail (not If, but when) you have to drop the trans to replace it. As an original owner, mine went through five separate internal slave cyls. Some lasted for many years; some only lasted 2-3 years. The part is not expensive. Its the labor to drop the trans and reinstall that made it costly. As I have stated repeatedly on CC, mine saw 5, it was never going to see a 6th.
The slave cylinder is going bad. Go ahead and replace it. It happened to me at least 5 times. Then I swapped in an AX15 with an external slave cyl.
Cruise Harness Connector Question
87MJTIM replied to Big Dan's topic in MJ Tech: Modification and Repairs
The two wire is the clutch cut-off switch. The harness must have come from a manual trans. An automatic would have a bridge connector in the plug. The single wire is a ground wire in the engine bay, near the firewall. -
OMG. The side photo looked like a Studebaker. The front showed the Chevy name and emblem that gave it away.
What? It just a "conversion" van.
Comanche bed dimensions
87MJTIM replied to carolinajeepman's topic in MJ Tech: Modification and Repairs
Don’t the mirrors and door handles stick out further than the flairs? how will you address those? -
Looks like my wife's play list.
Ax15 Pilot Bearing Question
87MJTIM replied to Blaine.D's topic in MJ Tech: Modification and Repairs
I have an 87 4.0 and installed a 98 AX15. The 74 CJ5 bushing worked perfectly. -
So, let me get this straight. You want to perform a lot of modifications and fabricating (which will take time and money) only to undo what you did to take it back to what you had. Do I have that correct?
First of all: What year is your MJ? What engine? What size was the tank you removed? Completer your signature with that info. The tank from an XJ will not fit. There are after market MJ tanks available. I bought one about 5-6 year ago. Search RockAuto. The sending unit from an XJ will not fit. It faces the wrong direction. Search for MTS on Comanche Club. They sell aftermarket pumps/sending units. Other than those two items, the last one (pump) will swap over.
It was probably in Vietnam. Where were you?
I was driving N on Rt 15 heading to PA. I saw a white SB in great condition. I waved as you passed me. I was driving a Chevy suburban towing a camper. nice MJ
I once found a note on my windshield asking me to call the number if I ever plan to sell it. (I still have the note. I've never called the number.) I have had people casually ask if it was for sale. I tell them no. No one has ever thrown out a price.
My advice before he does this: Look before you leap. If you consider this option, sit down with a CPA and discuss the accounting and tax issues first. Understand the different ways to operate a business (sole proprietor, LLC, S-Corp) and the responsibilities that each one has. If you are not comfortable with handling the accounting and tax issues, hire someone to assist you.
I got that line again. I was getting gas today. A woman (possibly 30 +/-) was behind me filling up. I noticed she was looking at my truck. As we were finishing, she called out to me the above comment. I told her Jeep made pickups from the late 40s until 1992. She then commented, with a hint of disgust, about the new Wrangler pick up.
I was having problems with wandering and slow responsive steering. I did all the above checks: had someone turn the steering wheel while I got down under the truck and checked/felt all the steering connections. Couldn't find anything loose. Took it to my mechanic. The problem was between the gear box and the steering wheel. Turned out that the steering shaft u-joint was wearing out. He was surprised. Those things very seldom wear out, but it is 30+ yrs. old.
https://www.faxonautoliterature.com/Search.aspx?c=95341 Faxon Auto Literature
The list is shorter for what I have done, rather than what I still need to do.
90s wrangler ax15 with transfer case
87MJTIM replied to rylee144's topic in MJ Tech: Modification and Repairs
The attached youtube videos show the "clocking" issue of a YJ vs. XJ trans. Of course, these involve putting an XJ trans into a YJ. The OP is going the other direction. The videos would be a lot shorter if he didn't "man-slain" every little detail. Part 1: Part 2: -
The AX15 (at least in XJ/MJs) were internal slave cyl from mid-89 thru 93. In 94, Jeep switched to external slave cyl. The 94+ AX15 (at least the bellhousings) is more desirable.
The AX15 is a good transmission. I have two, one in the MJ and one in a CJ. The one in the CJ came from a wrecked 90 XJ. The one in the MJ was purchased off Craigslist. The guy selling it pulled it from a 98 XJ he was parting out. I did not see up close the XJ, but it did not appear to have been wrecked. Both have worked fine. (Although the one in the CJ feels better for shifting.) (Actually, I have three. I pulled one from the JY. There were two XJs with AX15s. One was a 4wd with an internal slave cyl. The other was a 2wd with an external slave cyl. I left the JY with a 4wd AX15 and the bellhousing for the external slave cyl.) If you're concerned about a JY AX15, search for an XJ that was wrecked. If it was wrecked, it probably means it was being driven. Also, look for one that was not heavily modified for off roading. If it was somebodies daily driver, it may not have been thrashed on the trails.
I would start at the top. Look at the master cylinder, both in the engine compartment and inside at the push rod. Is the push rod damp? Probably need to replace master. If so, check the fuse block for brake fluid that may have dripped from the master cyl. If the master cyl is fine, then travel down to the slave/throw-out cyl. Is there fluid dripping from the bottom of the trans? Could be oil, could be hydraulic fluid. If the slave cyl is bad, then you will have to drop the trans and replace it. While you are in there check/replace the clutch kit while you are in there (unless it was replaced recently). Not to sound like a broken record, but.... My BA10 never left me stranded. My issues were always the internal slave cylinders. For the first 25 yrs, my MJ was on its 5th slave cyl. Some lasted many years, others lasted <2 yrs. It did not get to see a 6th cyl. I swapped in an AX15 with an external slave cyl.
