dwa175
    oakville,conn
  • Interests
    xj p/u
1366 profile views
dwa175's Achievements
  1. live in leesburg florida now jan 1 2020
  2. 1990 mj steering wheel play,truck is hard to drive straight,local shop said it needs lower control arms,note moved to fla from conn have to garage to help and I do not have my shop anymore,any help here. oringal mj 159000 miles,i servived this truck since new,has been no front end parts problems dwa 175.
  3. dwa175
    1J7FJ36L9LL130370
    my 1990 1j7fj36ll130370 dwa175
  4. take heater hose off at themostst fill till fluid comes out of heater hose you can also do this by taking off upper rad hose I found easler to take heater hose
  5. 6/2018 got my 90 comanche p/u from 10 mouth paint and floors replace. now I add gas and gas runs out a fast as I put in in. cannot see tank because of cover and I don't have lift. is there a repair shop in conn who can fix thank you dwa
  6. dwa175
    looking for
    hi looking for oem seat covers buckets gray for 1990 comn also in dash clock dwa175 maybe there is a vendor for these items
  7. I have never seen or used flush line but I like the idea I am going to try it I can not get air out this has been the hardist jeep to get air out I have tried all most everything .someone asked when does it get hot just running in drive way go right to red.all hose are hot,heat from heater,also mite try coolant cap from napa but I will keep posting note I have 5 cars,two bikes and I having nothing I can drive I will just wait for the bus dwa thanks
  8. looks like a throttle control turn it see whats happens the red button if pushed releases cable dwa . :MJ 1: .
  9. jasper there the best they give good service if there is s problem,i have used many jasper rebuilds in my shop but they my be the most costing dwa . :MJ 1: .
  10. thanks did temp sensor it just doesn't want to give in,sometimes it just has get the air on its own I keep tring dwa note my wife whats me to install a plow don't think its a good idea but at lest it will be warn in cab.
  11. 90 comn had to replace radiator had big hole,i bought neww radiator from rock auto brand new mopar still on box,replaced now it overheated slowing I have done all my old tricks but this will not give in I have checked everything 3 times it slowly overheates dam French did the ever make anything that worked any ideas I will find problem but running out of time going to my home in florida for 6 months hope to fix before I go thanks dwa . :MJ 1: .
  12. peter m thanks I forgot nose down I will jack up sat morn I did many of these but this has been a bear it just seems air locked,if nothing works I am going to pull radiator out something is wrong,i will update dwa
  13. had to replace raditor in my 90 I'm conch all is does just overheats I did all the tricks I know. it has coolet bottle something to do with the French [sorry] any ideas.it is 6 cyl no air,auto 158000 miles. thanks dwa,note radiator hoses all new and get hot ,left side rad doesn't seem to get hot air?.
  14. I live in conn what town/city are you in ,I am in Oakville,never saw that jeep in my dealership dwa175
  15. I think you should check crank sensor frist truck is a part maybe not connect or damaged seen my times mo crank signal no spark its easy to replace now can get at any mopar parts dept dwa :thumbsup:
