11
Leaf spring bushings
DirtyComanche replied to MeanLemons's topic in MJ Tech: Modification and Repairs
That's good to know. Like I said, I didn't order them because I was scared they wouldn't work. -
Intense death wobble
DirtyComanche replied to Master7122's topic in MJ Tech: Modification and Repairs
That will happen without rust, and I think I mentioned it? Not sure. The bolts can come loose too, which will give you as much trouble. -
Normally motor mounts look torn when they're done anyways. But yes, your problems are suspension related, front suspension related... You can get horrible sway/hopping from the rear shocks being blown out, especially if SOA, but that's a different matter. -
Does it come with the blonde?
YJ fan? Y? I mean why...? I changed the oil. Spun the old filter off and hurled it in the trash. Spun the new one on and it turns out it's dented to crap all over the top. And that was the last Renix filter out of the batch I bought a while ago, so I guess I'll go to the parts store tomorrow and buy 5 more.
Battery over heating and dies after 4 kms
DirtyComanche replied to Myles Cyncora's topic in MJ Tech: Modification and Repairs
Probably was just deformed and didn't make decent contact. They stretch out over time and the bolt will bottom the ears before it's actually tight on the post. Or something else is terribly wrong. You can get a new generic negative cable from a parts store for not much. Make sure the stud it connects to on the block is clean and tight too. -
The connector on the battery post, or the one on the block? -
Vent window...?
DirtyComanche replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
Can you buy new seals for them? I wish I had them on the highway. But I think I'd rather just go to the new style large one piece window. -
I agree his battery has coded. But I don't want to say "Throw a new one in" without determining that it is charging correctly first... But that's just me. Auto parts stores here don't typically offer to test your dead battery or charging system when you go in to get a new battery. My volt meter often reads 2V low, and that's typical on crusty old clusters and wires, throw 16.5V at a new battery for a while and it'll be as dead as his current one is. Storing batteries in decent conditions while charged does not cause them to die a terribly early death, and 4 years is a terribly early death. That said, we don't know how he charged it or abused it otherwise. -
I'm with Gene. Get a real multimeter on it before jumping to conclusions. It does sound like a bad battery, but easily could be overcharging. -
I'm saying I don't know. I was going to order them a while back but saw it crosses to the XJ one, which it shouldn't since I believe they are a different size (certainly they're different OEM part numbers). I guess I could go measure... Edit, went to measure and can't tell for sure without pulling a spring out of one of my MJs, which isn't going to happen. They look like they're close though, so maybe they're the same. -
Pilot bearing question
It depends what year it is. Early ones (89/90) use a pilot bearing that's off the shelf, the later ones use the bushing. When you get the trans back see if the pilot bushing fits nice on the snout of the input shaft. If it doesn't, you need a bearing, which will come with the clutch kit for a 90 XJ/MJ with an AX-15. -
Does it restart immediately after it dies? -
Exhaust manifold
DirtyComanche replied to jason.cook.52206's topic in MJ Tech: Modification and Repairs
I'd probably weld it again. I have a cheap stainless one meant for a 91+ on my XJ. Wasn't worth the hassle to make it fit. -
Got a voltage gauge? Or multimeter? What's it charging at? Does it restart? Or do you have to charge the battery first? -
running rich/low mpg
DirtyComanche replied to a bum with money's topic in MJ Tech: Modification and Repairs
The CTS is almost certainly the problem. The IAT likely was fairly correct given those ambient temps and the vehicle being stationary. The intake manifold gets heated badly by the exhaust. You can actually test both the CTS and IAT in water with a multimeter if you really want to. The resistance table is on here somewhere, or I can dig it out if you really need. -
What was ambient temperature? -
I don't think the Moog front bushing is correct, they have it crossed to the XJ front bushing. -
Prior to using pilot bearings, pilot bushings were used. That's what is used when bolting a later AX-15 to a Renix, and what you bought. It will work fine. You swapping in a whole external slave trans, or rebuilding the one that's in there? -
Old Drippy - Revived
DirtyComanche replied to Dave Stark's topic in MJ Hardcore Tech: Epic Journeys to Greatness
206 tail rotor blade? Cool project... I toyed with doing an OM617, just never found a good donor car. -
It's a welded in nut. Either weld a nut to the broken bolt and turn it out, or get drilling and tap it the next size over. I also believe you can fish a new tab nut in through the front of the frame rail, there is some holes to give you access.
The clip goes on the line first, then the oring/backup ring/oring. Not sure if that's exactly the right clip, but it is something like that and it might just be an updated/universal design, basically if it snaps in and locks it is compatible.
Tires are 265/70R17 (stolen from a JK), so they work out to 31.6" in theory. Gears are 3.55 (automatic gears) with a AX-15, which basically puts it back to stock ratio. Fuel economy was not calculated due to the failed speedometer/odometer, but eyeballing consumption vs the GPS indicated that it was pretty much normal, which is about 17mpg. I can get about 400km out of 55L of fuel.
