11
We started off in Prince George. The first leg was to Valemount, only 290km, but some time was spent at one stop of interest, being Ancient Forest. Ancient Forest is a small collection of old growth red cedar that have been spared from fire, windstorm, drought, and most recently the fallers' saws (some of the trees have paint marks from timbercruisers and sample blocks cut from them even). Many of these trees are pushing 1000 years of age as they have flourished in this small section of interior rainforest. This spot was basically unknown when I moved here, but now has a large boardwalk trail, parking lot, signs, and is noted in tourism books and on Google Maps, likewise the number of visitors has skyrocketed. Unfortunately I was fighting user error and didn't get any good pictures of the really large trees, but I did get one of the small waterfall at the top of the park.
Power steering pulley replacement
DirtyComanche replied to JayhonB's topic in MJ Tech: Modification and Repairs
I'm about 95% certain it's a standard GM pulley if it's a V-belt... -
NEW MJ Fuel Sending Units
DirtyComanche replied to mrmel2you's topic in MJ Tech: Modification and Repairs
While it's completely clear to me what needs to be done, by any chance did you take some pictures? Would make a good one for the write ups section. -
Gauge cluster with tachometer
DirtyComanche replied to Warren99's topic in MJ Tech: Modification and Repairs
That. I think either the tach is straight up broken, or there is a massive amount of noise in the signal or power. -
TO Loc or not to Loc
DirtyComanche replied to hakukamana's topic in MJ Tech: Modification and Repairs
I have a Yukon Zip locker. As much as it annoyed me with how the product is somewhat goofy regarding installation and a few other things, it has worked flawlessly. Instant engagement every time. They can be had for a much better price than list if you sweet talk a dealer or wait for a sale. -
I'm betting that will not be reliable...
I've used a ton of those Honda EU1000i/EU2000i generators. They're rock solid and will handle a way larger surge load than they're rated for. I've used them for weeks on end with no issues. If it won't start your A/C, you might still be able to find a larger start capacitor for it to make it work.
Yes. Might be able to come up with something nicer between RADesigns or modding up one of the available aftermarket shifters... Or even using a GC shifter that has the manual up/down buttons on it?
I think your problems are at least partly transmission related. The AW4 is not very efficient outside of lockup, and I'm guessing you're seeing very little time in lockup during your around town driving.
100% I think there's a decade left before it will really be felt... As it sits an EV conversion doesn't seem to be a great economical choice, unless you're really putting on the miles in a manner that you can maximize the strengths of an EV, but the costs are coming down in general. Big rigs might actually be converted sooner rather than later. With driver log requirements and mandatory rest periods, couple with many trucks being owned/leased by fleets, they're actually a great option for electric as they can charge/swap batteries during the driver's mandatory breaks, and if you own a fleet of trucks the infrastructure cost is far easier to be justified. It's just not there yet, but throw another good 'ol fashioned oil crisis at us and I'm sure it will happen.
Dual fuel setups are a big compromise, I've dealt with them and don't think they're worth it.
When I had mine dialed in, I will admit it worked really good. Good power, good fuel economy, and it was dirt simple. Lack of range and the inability to use jerry cans (stuck buying expensive forklift tanks, or using the hack method with grill tanks) was really why I went away from it. The fact that starting it in the cold is just a fight was another issue, but I could deal with that for the most part.
I know a guy with a (non-working) CNG MJ. CNG works good in a local fleet environment (local buses, taxis, etc) as you need a lot of time to fill them, and there's normally almost no filling stations, and range is only so-so. The taxi company here had their own filling station, but they also got massive subsidies to install it. The fuel itself is cheap, the other problems of it are not.
E85 is great for a turbo/supercharger. My old MJ ran on propane, and I still have my plowtruck on propane... I'd probably not do it again though.
Thanks, I wanted a bumper that would still protect the body reasonably, but not stick out too far since the Jeep is pretty low. (I fixed the embed on the video too)
Front bumper is done. I really debated doing a hidden winch, but at the end of the day I'd rather be able to see the cable spool and get at the winch easily, plus there's a lot of brush around here so the bumper does need to protect the sheetmetal a bit. Video for people that like watching them:
Higher crawl ratio? 150:1?
DirtyComanche replied to Swampy's topic in MJ Tech: Modification and Repairs
Shop around. There's lots of room to move on the pricing of AA stuff. -
You could buy actual good LED headlights too...
Interesting box on that thing. Would make a good RV.
Member on here by any chance? I was running to keep up with other people, so didn't have a chance to try to flag him down.
Curious if anyone has a picture of the actual Corbeau brackets? I have a pair of Corbeau seats.
Intense death wobble
DirtyComanche replied to Master7122's topic in MJ Tech: Modification and Repairs
Not really. See Eagle's comment. IMHO it's as likely, if not more likely, to be caused by worn control arm bushings or ball joints as it is steering parts. The track bar/brackets seem to be the most common suspect though, but even if worn out they may not specifically cause issues. Typically it's cumulative wear/stackup of tolerances, as in everything is worn a bit and not one part is really what's throwing it over the edge. Basically look at things and start replacing stuff with whatever looks the worst or has the most play in it, repeat until the issue goes away. Make sure the tires are balanced and haven't developed a bulge or tread separation, and the wheels are true. Look for the track bar bracket egging out the hole on the axle, along with cracks on the uniframe by the steering box and frame side track bar bracket, or the steering box spacer breaking or the bolts coming loose. Upper and lower control arms, make sure the bolts are tight, the holes aren't egged, and the bushings aren't failing. It is a good time to do some upgrades though. I'd order the new style XJ/ZJ steering parts, WJ lower control arms, new stock uppers/bushings, and a new style track bar and frame side bracket (might have to junkyard the bracket). If the wheel bearings and ball joints are worn I'd do them and probably do the u-joints in the axle shafts (or buy CVs) at the same time. I'd highly consider going to the new style knuckles/brakes/wheel bearings at that time. All of this is assuming I planned to keep the truck for a long time and wanted it to be nice, but did not plan to lift it. -
Maiden Voyage - My List Just Got Longer
DirtyComanche replied to Griff04's topic in MJ Tech: Modification and Repairs
I always buy Fel-Pro for that stuff. https://www.rockauto.com/en/moreinfo.php?pk=122759&cc=1181584&jsn=439 https://www.rockauto.com/en/moreinfo.php?pk=126037&cc=1181584&jsn=449 Don't buy the cork one unless you're planning to do it again. There's also a support strap for the rear of the pan, HOrnbrod has the P/N I believe, it was a later update and was backwards compatible with older models.
