ComancheCrusher9800
    Lucedale, Mississippi
  • Interests
    Jeeps
1151 profile views
ComancheCrusher9800's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. What year Comanche do you have? Are you using the original wiring harness? Sent from my SM-G900V using Tapatalk
  2. What year model do you have? Sent from my SM-G900V using Tapatalk
  3. Did you make the adapter or did you buy it? It looks easier than the way I was thinking first. You took the original all thread out and used bolts to put it in and used new ones to adapt your TB to. I like that idea. All I would really need it a piece of plate. But what did you use? Sent from my SM-G900V using Tapatalk
  4. Just an Update. I did end up getting a 99 4.0 4×4 2-Door Sent from my SM-G900V using Tapatalk
  5. Alright so I haven't posted in a while, since my Comanche was running. But I blew the motor about a year ago and am just now getting to replace is. The one I am putting in is a 2.5l out of a 2000 Cherokee. I am using just the motor and putting my flywheel, clutch and transmission, etc. But I want to use the intake and exhaust off of the 2000 but the Throttle body off of my Comanche will not fit on the Cherokee intake. Does anyone make an adapter for it? Or has anyone ever done it? Sent from my SM-G900V using Tapatalk
  6. Yeah it happened back in April and I got another MJ and now an XJ also Sent from my SM-G900V using Tapatalk
  7. Yeah it's something because I came up with the name before I wrecked it. Sent from my SM-G900V using Tapatalk
  8. A guy can into my lane and ran me off road I hit a tree and rolled Sent from my SM-G900V using Tapatalk
  9. Does anybody ever sport a Comanche Club Logo on any of their other vehicle? Of so what kind of vehicle do you have one on?
  10. Is the 1999 Jeep Cherokee a good year? The one I'm interested in is a 99 2 door 4×4 sport. Sent from my SM-G900V using Tapatalk
  11. It spun 3 different bearings 3 different times Sent from my SM-G900V using Tapatalk
  12. I keep having trouble with the rod bearings. I've rebuilt the engine twice in the last 2 weeks and then had to replace a bearing the.other day. 6 miles down the road and she spins a bearing again. It happen after after 20 miles the other day. First time I rebuilt it a bolt came out of the timing chain fastener and the cam hit it through the block so I had to rebuilt the other motor. Then I slung a bearing. And now I've slung another bearing what do yall thing the problem could be? Sent from my SM-G900V using Tapatalk
  13. I'm 16 and I have two Comanches both 87 one LWB and One SWB. I bought them both with my own money earned from my two jobs and I'm still in school also. I gotta say I'm very glad I got into the lifestyle Sent from my SM-G900V using Tapatalk
  14. So I just completed a new rebuild last Wednesday I believe. Everything brand new except the block and head themselves. A day later I realize there is alot of oil all over the passengers side. Next day I went to look and see if the oil filter was leaking or something and then I saw it. A hole about the size of a half dollar in the block. Right beside the cam and a lifter (the lifter is still there). But the engine still runs perfectly also. But this puts me back at stage 1 with it. The hole is right beside the oil pressure gauge in the past picture. What do yall think could of caused it? Sent from my SM-G900V using Tapatalk
  15. Where'd you get the valve cover from though? Sent from my SM-G900V using Tapatalk
