fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. Now that's almost as old as I am.
  2. In order to bleed MJ brakes: Open the right front bleeder Depress brake pedal and hold Start engine, brake light should stay on after engine starts indicating bypass valve has moved (sensed front brake leak) Turn off engine, leave bleeder open, release parking brake Bleed left rear Bleed right rear Bleed righ front (close bleeder when done) Bleed left front This is from the FSM (an accurate one)
  3. If you go to your first post and select edit you can change the title.
  4. I've had this on my to do list for years, still deciding on a good place for the switch.
  5. Well, this is what SARS-CoV-2 has done to the company I work for.
  6. I remember someone coming across one of those early MJ bumpers at a JY and posting a picture of it, but can't find it.
  7. When I put a header on mine the EGR tube would not fit. So what I did was cut the tube and sleeve it with another pipe the correct ID and brazed it in place after attaching both ends for a perfect fit (engine was out of the vehicle). Don't know how far off yours is so this may not work. Some pictures here:
  8. Welcome to CC! Please add it to the registry
  9. Do you plan on making a trip out west?
  10. fiatslug87
    Fenders
    Did you leave a CC card? HA, I beat you to it Pete!!!
  11. I think Pete means if you want to bob the bed for the departure angle, you can armor it and have it slide off whatever it hangs up on.
  12. Makes me appreciate the MJ's simplicity.
  13. Is it in the registry yet?
  14. Thanks guys. I'll hit my "local" ACE this weekend (20 miles away) they have a huge fastner section.
  15. Nope, too large.
  16. @Pete M Please change title to VIN. Thanks.
  17. Welcome, and add it to the registry please. https://comancheclub.com/forum/30-1987/
  18. November 2020 update see first post. 48 new additions this month for a total of 1092.
  19. @Pete M can you delete this double post? Thanks.
  20. It's an 87, base model, 4.0L, 4x4, coulmn shift auto., paint is Grenadine Metallic.
  21. Build sheet please.
  22. He says Acetabularia funny.
  23. Thank you! I was going through withdrawals yesterday, I'm all better know!
  24. What are those brackets by the straps?
