Hello,
Well I took fuse block apart and cleaned up the connections as best I could. And got the same results. By the way it’s easier to remove the two bolts on the inside, then push the block in from the outside and tilt it up. You can see and access the outside bolt better.
Eagle, I did clean up the connector behind the headlight. And put in the extra ground for the fan when I replaced it. Do you have a fix for the brown power wire you stated?
That relay was for the horn. New one doesn’t make it beep but it was hit and miss before. Put the old one back on and pushed on the metal part and it worked but not with the button.
