pizzaman09
Everything posted by pizzaman09
AX-15 And rear end shudders
pizzaman09 replied to Manche Man's topic in MJ Tech: Modification and Repairs
Yeah, mine is probably double the force required compared to the old internal slave cylinder. Is there a different master used on the external slave setup? I reused my master as it was almost new. -
Sliding Glass Latch Rubber Isolator
pizzaman09 replied to TeKdo's topic in MJ Tech: Modification and Repairs
I didn't realize there was supposed to be a piece of rubber there, mine rattles too. Subscribed to learn more! -
Any help with any photos
pizzaman09 replied to Aussiemj's topic in MJ Tech: Modification and Repairs
I assume you are talking about this photo. That steel pipe connects to the bottom of the expansion tank, heater core and the rubber hose that runs up the left side of the upper radiator hose. The cooling system you have should be more similar to an HO Comanche or XJ than a Renix one. I don't think this steel pipe would be applicable in the HO setup. -
Hopefully these help. The two modifications you will note are the addition of factory cruise control and the plug for a Renix engine monitor on the large diagnostics port. Overview: Intake side Battery side Electronics cover panel removed: AC line lifted to see vacuum hose routing to accumulator ball in front bumper Relay area: Relay area: Lots of common lugs come here, I forget what the block they are on is for. Back side of said block: Connectors near battery: Connectors near battery view 2: View looking under coolant bottle: View showing cruise control actuator and the 4x4 vacuum lines: General view of ignition coil: Distributor: -
Absolutely fantastic trip! Reminds me of buying my first Comanche that we drove through that way on the way home. I have lots of pics of it in Monument valley, many of those photos were featured in the bring a trailer and when we sold it. I really want to get my stock Comanche out there some day to drive it on the slick rock.
The vacuum storage tank is usually on the front bumper, left side if you are standing in front looking at the front of the truck. I totally forgot to do this today, tomorrow after work I'll take the photos. -
December 2024 - The MJ from SEMA and Radwood
pizzaman09 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Just love it. An awesome, low Comanche with an epic wrap. Not for my current one but this one makes the wheels turn for if I want to build one someday. -
I suspect krustys is what you are looking for, but I did want to throw out there a not quite as good option. I tow with a ball mounted on my Westin Fey bumper. I did have to weld chain hooks to it, but otherwise it works wonderfully. I'll admit I've towed around 5k with it, the bumper has 3000lbs max capacity stamped into it. I love how sturdy it is, no rattle from the hitch loosely fitting into the receiver.
Let me know what photos you need and I can take photos tomorrow. I have a 90 4.0L. -
Exactly! The Bosch one was very slow, like 30 seconds to toggle back and forth based on what my REM was showing. The NTK is super quick. The NTK fixed my lean rough idle.
I tried a Bosch when I first purchased my truck 3 years ago based on my success with Bosch for other vehicles O2 sensors. It was a mistake, the sensor was super slow to respond and would slowly wave back and forth from rich to lean over and over again. I purchased the recommended NTK sensor and it fixed everything. I had a smooth idle and more power just about everywhere.
All excellent suggestions. Another easy one to check that has caused miss fires for me is engine ground. Make sure the block actually has a good ground.
I'd totally have islander graphics on a Comanche.
That pizza looks delicious. I've found the Italians to be incredibly passionate about their pizza.
Stock height with stock tires...it's rubbing
pizzaman09 replied to J33ps's topic in MJ Tech: Modification and Repairs
Good to know, this is something I've been interested in addressing for a while. -
I was just thinking this. I swapped from 225/75 R15 light truck tires to 235/75 R15 BFG KO2 all terrain tires that are knobby in the sides. When I turn hard left they will run on the lower control arm, of which the 225s didn't. I keep meaning to look into whether I can adjust or add a steering stop. -
I'm in the field of designing elastomeric bearings for helicopter rotors. About 50:50 defense and civil. Right now is a fine time to be in defense. All of those sound like fun industries.
Having worked with many Italians, it would be a panino. Panini is the plural, sandwiches. Absolutely awesome adventure! I drove from Marseille, France via Nice and onto Genoa, Italy before turning north or Milano last year for work. The Mediterranean coast was amazing, the blue water like in your one shot was incredible.
Good stuff, I am a Mechanic Engineer myself. What do you want to do when you are done with school? Totally understand the desire to want to be in the southwest and your choice to go to school there.
Is a MJ reliable enough for a daily driver
pizzaman09 replied to typicaljeepname's topic in MJ Tech: Modification and Repairs
Completely agree! I could regale you with a dozen anecdotes of vintage cars driven regularly working great and not so vintage stuff not driven frequently that do not run well. I have a 62 Austin Healey Sprite that I put 1500-2000 miles ago year on. I can get into it at anytime and just know it will start and run well. Original dual carbs and points ignition, driven rain or shine, it works.- 28 replies
- reliability
- restoration
(and 2 more)
Tagged with:
Awesome! I actually purchased my first Comanche in Los Angeles and drove it 2500 miles home. A complete no known history Craigslist purchase. It was a brilliant trip and I am crazy enough to do it again, particularly since my current Comanche has cruise control, air conditioning and bucket seats, of which my pteione had none of those options.
It's a dream of mine to get my Comanche out there, and Easter Jeep safari would be a great time. That said, the 1800 mile drive is a serious treck. I've flown out there a few times and rented off road vehicles, I'm so jealous of the dry slick rock off roaring compared to everything out east is pretty much just mudding.
I've used goof off to remove yellow line paint off of a car, it didn't touch the 20 year old clear coat. Obviously try in a discreet area first.
Woohoo! Clutch troubles are super frustrating.
1990 Comanche Eliminator
pizzaman09 replied to pizzaman09's topic in Member Projects: Your Comanches
So, apparently this PCV idea was not a good one. It does indeed prevent oil from getting into the filter. However it prevents vacuum from the back port from being pulled by the intake and has caused my rear main seal to leak substantially more. I've decided to modify the PCV a bit to prevent it from blocking off the flow of air in to the engine. I did this by pounding a 1/4" square drive into the bottom of the PCV so it won't seat and seal off entirely. See photo: Now of course it is the end of the season with snow in the forecast tomorrow, so the truck was washed up and is parked for the winter. The PCV fix probably won't get tested until spring unless I have a major need for a truck this winter.
