75sv1
Everything posted by 75sv1
  1. I did a cross over steering, 1-ton tie rod ends. I did want to see if stock would work. The taper is the same. I believe others have done it. Also, use the lower WJ ball joint. The taper is correct, the XJ lower ball joint will 'fit' with slop. Not advised.
  2. 07-08 Libby or Nitro rotors will work for a 5 on 4.5. 00-01 XJ hubs work on WJ knuckles. I don't know if you would need the 1/4 spacers or not. I did have to use spacers front and rear with 15" aluminum rims. I am swapping WJ 5X5 hubs and knuckles on the front, presently. Also, going to adapt the WJ rears to a Ford 8.8 with Yukon floating axles. They have an option for 5X5.
  3. Any brand name motor oil is way better than even 10 years ago. I do run Shell Rotella T6 in my XJ. I did run Shell Rotella 15W-40 and 10W-30. If you engine leaks oil, then run conventional. Otherwise sort of a flip of the coin. I do run synthetics about 7,500 miles, and a synthetic oil filter (NAPA Platinum). I do use Zerex Z05 radiator fluid. I have a Ford Contour and MB 240D, so that works in them too. I do use distilled water to mix 50/50. The Z05 can be mixed for more extreme heat. I'd probably run 10W-30 from October to March, then 10W -40 in the summer. More for starting. I do run 15W-40 in the MB in the summer months, the 10W-30 when temps get colder. Yes, it makes a difference in that motor for starting. You did not mention where you are located at. That could determine what oil(s) to run.
  4. http://www.grimmjeeper.com/gears.html
  5. My take is that the radiator is a bit undersized from the factory. Some of use put on an auxiliary trans cooler or two. My plan is or would be to put a separate engine oil cooler on. Possibly with a thermostat by-pass.
  6. There is a place in TX, that sells short block. I remember $950 plus shipping. Maybe $200 core. Also, see about a place in NC or SC. I saw some good prices on them.
  7. During WW2, they would take a sheet metal part off a B-17 and make a mold off of it. I think the molds were formed out of Bismuth (sp). The molds do not last long, say 20,000-30,000 parts. I think I have used something similar or just called by another name 'Cero safe' . It is used to take cast of chambers of firearms. Also, as I remember there is a place in Ohio that deals in Ford Model T parts. They use this to make reproduction body panels for the Model T. Old school still works.
  8. I have the new fenders and am planning to use the old header. I just see it as relocating the four holes for attachment. I will be using '95 XJ wiring. I am thinking you just have to drill holes into the fiberglass of the header or in my case, make some brackets. The wiring??? You might see if you can access MAD/XJ site. It had some conversion stuff from the old XJs to the new XJs turn signals. Also, a headlight relay wiring harness on the headlights. Just thoughts.
  9. I am trying the reverse of this. The attachment bolts, screws or studs are in different locations. In my case, I could bondo the corners and make them rounds.
  10. As for straightening NiCop, I used the corner of the bottom of a wall. Sort of unrolled the coil into the 90 degree. It was fairly straight. Then when I cut the piece to length with extra, I straightened it with my hands. I did look at the rollers for straightening it.
  11. Yes, I used a pipe cutter. One of the small plastic ones. I think I also chamfered the ID.
  12. This was posted on an MB board.
  13. I have used NiCOP on my '00 Ford Contour SVT. Bends easy. I doubt it will rust. Porsche uses it. You can bend the stuff with your hands.
  14. I wonder if the OP could use XJ or adjustable shackles to level the rear?
  15. I'll change the subject a bit, to movies I wished I'd seen in the theater or even IMAX. RUSH, The A-TEAM, and Grand Prix. Even though Grand Prix is older, the scenes are well done. I'd include the MATRIX series on that too. The Lord of the Rings, I'm glad I did.
  16. There are write ups on the WJ front sway bar. I have been looking into this. Basically, the frame brackets need moved forward a bit.
  17. Star Wars. I saw it in DC before it gained its popularity. My friend had to convince me to go. I remember 'Sci-fi, ugh!' or something to that affect. You just couldn't explain that movie at that time to others, who hadn't seen it. I still watch it from time to time. Others Star Wars movies might be technically better. But the original has soul. The Matrix did eclipse the technical aspects. Also, excellent story etc. There were some movies at that time, that I think changed movies to come and culture. Jaws is one that has not been mentioned. Changed horror movies The Jerk, with Steve Martin. Martin was not under contract with SNL, not to make movies. He was contracted as a writer. Changed comedy. The Deer Hunter. I think it changed the perception of Nam vets. Sort of changed War movies. Saturday Night Fever, changed culture for a while. One other I'll add, Blade Runner. Except for the flashing neon lights on the hovering cop cars, I think it could be release today. Alien is up there. Also, like Rocky.
  18. I did a 4.0L WJ PS Pump upgrade. I had to block off a port in the reservoir. I hear KJ reservoirs fit. I did notice a bit better operations. That is with a rebuilt stock (Advanced Auto) gear box. I did rebuilt the PS Pump. Edit: Mine is on a '98 XJ. So, there might be mods to do on earlier engines.
  19. 75sv1
    98 Cherokee
    As for rust, under the driver seat and above the muffler. Also, check the rear brake line. They rust. Will not be fun if it fails when driving. '98s are a good year. The rocker look good from the pics. Usually the first to go.
  20. I'd be couscous on what a bank will loan you. It might put your budget out of whack. I remember I was approved for about $110K. I bought my house for $65K. I was making $16/hour, no or little OT. Also, watch that you are making a bunch of OT currently. How long will that last? How stable is the housing market, were you are at? That could be neighborhood to neighborhood. Still, get preapproved. It works in your favor. Also, see if there are house buying classes in your area. In my area, at least it used to be, customary to put down $500 as a promise note. If you backed out of the deal, it was the sellers $$.
  21. '5. The listing has been reduced by $13k, or @16%, in only 90 days on the market. I tried to look up the assessed value of the home, but was only able to find public records on the tax assessment on the land. It was noted as a "delinquent account" despite the property tax on the land only being $118. Those two pieces of info indicate a distress sale to me and why it is being sold "as is", i.e. they don't have any money. ' Interesting point, and has a bearing on PMI. PMI is based on the value of the house, not the loan (or at least that is what worked for me). So, if the house is valued at $80 or higher, then you might be out of PMI already. Something to look into. There are also taxes and some other stuff that might get rolled into the loan.
  22. OK, you win. I use two wallets. One for everyday. Approaches 'George' territory at time. The other is a money clip. I use it when I do go out. Some $$, one CC, Carry Permit (if I'm carring), Car Insurance maybe a few other things.
  23. As mentioned PMI. I think it is a percentage of the loan each month. I would think about $75 a month for that house. Look into the 15 vs 30 year loans. I would say it would be a $100 difference on that amount. To check into first time buyer loans. Possibly better rates and usually less down. Check out several banks. They have different loan criteria. I'd say at least have $5000 to possibly $10,000 left in the bank when done. Check out laws as for vehicles being outside. You will probably want to work on your Jeeps. Different location and different neighbors can be a pain.
  24. I believe the valve cover is a 93-95 Grand Cherokee. The newer valve cover grommets hand CCV stuff should work. I have done two of them. Installed one in a '98 XJ. The rear is a CCV, the other is a just an elbow if I remember correctly. You can use a latter CCV tube on the rear 97+. You would need to use the 97+ plus fitting in the intake manifold. The tube is larger. It might help your Blowby or oil getting into the air filter. Also, Cruiser's tip on modifying the tubes or shields in the valve cover. Also, check out FelPro's valve cover gasket. I think its $35 or so. In my experience, blowby can be a leak at the valve cover gasket. Also, the Chrysler gray (??) RTV has its fans.
  25. 'They're all there, inside an '86(?) Waggy, which IIRC is sitting on a Dana44, at Wesman Salvage in' I take it this is a FS, so the bolt pattern should be 6 on 5.5 (???). Also, Isuzu Rodeos have Dana 44 under them, but same deal 6 on 5.5. Also, don't the Rubicon Wranglers have Dana 44s?
