75sv1
Everything posted by 75sv1
Tool recommendation for pop rivets
75sv1 replied to pizzaman09's topic in MJ Tech: Modification and Repairs
I want to say Kwik-?? Pop or something. -
Redrilling hubs for a new bolt pattern
75sv1 replied to Smokeyyank's topic in MJ Tech: Modification and Repairs
I wouldn't see an issue with drilling another set of 5 on 5???. I might have to do that with the rear axle shafts on an XJ with Ford 8.8. The Yukon axles come with 5 on 4.5 and 5 on 5.5. Either drill the rear axles, or come up with 5 on 5.5 hubs for the front. And also, 5.5 rims. -
Need a second opinion on this color.
75sv1 replied to 512tr's topic in MJ Tech: Modification and Repairs
I'd look for some darker brown accents on the exterior with also the black. Not so much black on the hood as on the Comanche Concept. I'd also think that on the interior. Black or a dark brown on either the inner or outside of the seat. Same on other interior parts. Maybe a black or dark gray carpet. So, stains aren't an issue. -
I kind of like it in the engine bay. Possibly easier to see things. I think your idea of two tone or multi colors or layers would look good. I have a Sienna (Burgundy) XJ. I did different black accents on it. Looks good to me. Recently, I had to replace a rim, as one decided to go Jeep on me and went on its own trail. It was silver. I came across a gray rim, with silver ring. Really sets off the rest of the exterior color. So, now I need one more to complete the set. I think there is a fine line , between to much and to little. Your work looks good. Want to see progress pictures. -
How to identify which pulley/bearing is going?
75sv1 replied to acfortier's topic in MJ Tech: Modification and Repairs
Harmonic balancers make noise when they are slipping. Put a white line across the hub and the outer ring. See if it stays in position after running it. I change mine on any 'new' old vehicle I buy. They are about $50. Good time to check the timing chain. A lot cheaper than replacing a crankshaft. -
My thought is a cracked piston skirt. Do you notice the noise on the driver's side? I have a 2000 XJ with 280K on it. It ran about 2-3 years with the 'piston slap'. I could only hear it from the LH side. Close to what you describe. My AC compressor is bad. Rebuilt unit, I think is locked up. Anyways, this last summer it was hot. So, I turned on the AC. Wasn't blowing cold, so I turned it off. I was picking up my LS Block from the machine shop. I noticed a clacking. I made it home. I took off the oil pan, hoping for rod bearings. All were tight. I noticed some aluminum pieces in the oil pan. It was piston #6. As posted above, I did check the trans bolt first. I too use Rotella T6. I do not add Zinc. I has about 1200 ppm ZDP. I thought about putting in a used piston or a new one in #6. I finished up my mini-stroker and installed it. My head was actually OK. Don't know if I was replaced before or original. Its not a TUPY. The bores had a lip at the bottom of the stroke. Maybe a block for a full stroker.
There are bracket from IRO that go on the steering knuckles. I have a set, but need to find lights that work with them. It would put them very low.
I don't like the idea of parking lights only. I don't think it is enough light in driving situations. Also, other drivers expect seeing head lights. So, I do see the 'need' for City Lights. I think City Light are mainly used in Cities, as street lamps would provide much of the lighting.
The idea of fog lights is to beam light under the fog. Fog is a low level cloud. So, lower is better. I think it is against the law to have fog lights on when hi -beams are on. In Europe I think they have or had, where the fog lights would come on, but the headlights would come on dimmed. I've also hear this called "City light'. I can see this as an advantage. As sometimes in snow, fog or even rain, I get some glare .
I looked at : Car-Part.com--Used Auto Parts Market Sunrise Foreign Cars & Parts 877-786-1040 has a header panel $150. Has Fenders too. Barefield's has one side for the fenders.
Let me look at Car-Parts Inc. Shipping can make parts expensive. I'll try and see what shipping is on the header panel. I have the grill in Siena, Burgundy. I do have two Sienna front fenders. I'd probably swap them on my XJ. Then give up the Red and Silver Blue ones on the MJ.
Manual or auto? With a manual 3.55 gears should work well with 31's. Auto, 4.10's. My XJ is 2" lift. I really like it. I will be going to 3-1/2, but only as I have the springs and they'd be an upgrade. I was behind a stock XJ a few years ago wheeling. It did well.
I have some fenders. Or I can possibly get some. I'd have to check the condition to some burgundy fenders. Or swap them onto my Comanche and take the fenders from it. Yes, they are 97-01 fenders. I take it I'd be shipping to Guam. What's the best carrier to ship by? Also, the wiring on the Header panel might need new connectors for the headlights. I'll try and check tonight.
Does color matter. I should have a Desert sand header.
Ran acroos a RHD 2000 Jeep XJ 4.0L at Greibe Pnp, nears Myerstown PA. I did pick the belt drive brackets. Interiors gone, except dash and steering wheel.
Your YJ box should be heavier duty than the XJ box. I plan to go that route on an XJ I have. I have used an stock XJ box with 32's. Also the Ironman brace. Mine also had WJ Big Brakes and cross over steering. My present XJ is on 31's. WJ BBs and Cross over steering. Also, A Bad Dad Fab Hidden Winch Mount with Steering Box brace. Excellent steering. That is with a stock box.
I use the Valve cover off a 93-95 ZJ. It has the latter CCV grommets and fittings. I use the latter Tube and fitting to the manifold. Also, the FelPro rubber gasket. I do the Cruiser Tower mods too.
Might try Ozium for the smoker smell.
I've done one or two. I used an Inch-LB dial torque wrench. Some of the instructions go with a mark, then turn 1/2 inch. Also, the shaft may be worn at the seal location. The lock nut should be torqued to 75-ft -lbs. I just put some Loctite on and banged the nut tight. Meaning to make something to tighten the nut and be able to keep the other part in place.
Comanche full exhaust options, sans header
75sv1 replied to knever3's topic in MJ Tech: Modification and Repairs
I'd also think the CAT might act like a resonator chamber. I'd run 2.5 on a full stroker. Also, what diameter TB? I'd run at least a 60mm, 62mm would be better. I'm using Brown Dogs, and still have a flex pipe. I used a 'V' band clamp. Really like it. -
I used some lug nots from the steelies I had on for an aluminum set or rims. The steel rims had scored the lug nuts, so they did not seat well with the aluminum rims. I was working on a steering gear box. Let loose of the shaft. So, it spun and all the balls fell to the floor. Probably not the worse I have done.
Sorry Row 52 : Row52 | Find Recycled Auto Parts Finder for parts at Pick-n-Pulls across the US. Also, I have a wiring harness from an '88 Manual in good shape, that I could spare.
You might include year and if auto or manual. I would also try Car-Parts.inc . Possibly one of the Jeep Only Junk Yards. I used Davey's Jeeps in OH a long time ago. Aslo, Lot54 Pick n Pull has pickers on their site, for a fee.
ax15/np231 rebuild questions
75sv1 replied to watchamakalit's topic in MJ Tech: Modification and Repairs
I was going to rebuild a 241. I had it all apart. Time etc., so I had someone rebuild it. The plastic parts on the shift fork came off. He did rebuild it. This time used some RTV to glue on the plastic parts. I think he used the Ruff Stuff or Right Stuff from Permatex. Not cheap. I pieced together my parts. In the end, I think going with the NOVAK might have been a better option. I think I spent the same or more. -
Dana 44 Rubicon axles under MJ
75sv1 replied to Bugout 1's topic in MJ Tech: Modification and Repairs
Auto or Manual trans?
