JMO413
    4
Everything posted by JMO413
  1. I have the MTS assembly in my truck and the gauge isn't very accurate but that's my only problem with it. It's a very nice product otherwise. I would just but a new tank also and Save the headache. Just my thoughts. Also very jealous that looks like a very nice truck!
  2. https://www.oreillyauto.com/detail/b/import-direct-ignition-4488/ignition---tune-up-16776/ignition-module-control-unit-ignitor-12521/e281cd9fff15/import-direct-5-terminal-ignition-control-module/140197/4575249 This is the link to the one I bought from O'Reilly's. We have had good luck with import direct parts at work. I replaced mine beacuse the bottom was cracking like Andy was describing. Mine finally gave up when I soaked it flushing the heater core.
  3. Your truck and what you've done are almost identical to mine. Same black pioneer with some rust. I've got rid of allot of rust and replaced both floor pans. Can't wait to see the progress.
  4. Good work! I absolutely love that color!
  5. JMO413
    Veterans Day
    Thank you to all who served.
  6. GM has red called Dexcool, Mopar also has a red coolant. You need automotive antifreeze not RV. Your truck would have started life with green.
  7. Awesome that's what I was planning on using. Now I just need to do it.
  8. This blows my mind. I've had a dozen or so people stop and talk to me about mine. And mine sure isn't too pretty. I talked to a guy at the gas station Tuesday for a good 10 minutes.
  9. It's Iowa stop and knock.
  10. Mine are all still there. Didn't interfere with the rubber gasket/trim at all.
  11. What did you end up using to lube it?
  12. Welcome. Hope that will help. If I remember right the organization l orange and black is for the interior lights.
  13. Beautiful truck! You should do a build thread work some more pictures.
  14. The seal goes on the windshield before you install it. Your going to have to pull the windshield. I believe the later windshield is also slightly bigger. I know it's a different part number than the original. I am very pleased with mine. It's just cleaner.
  15. mj1988electricalmanual_(1).pdf This is the 88 electrical manual PDF.
  16. Congratulations beautiful truck!
  17. This is sad to hear you do amazing work!
  18. I would take 2 if you get them made.
  19. Good looking truck!
  20. Get the Volvo replacement cap. https://www.napaonline.com/en/p/BK_7031396
  21. Not quite true. Renix exhaust manifold is different than HO. HO doesn't have an EGR bung in the exhaust manifold and the O2 sensors is in the head pipe. They are interchangable if you delete EGR and get the HO head pipe. You will still need a Renix manifold gasket.
  22. Me Everytime the siren goes off. And all my neighbors just looking around.
