eaglescout526
Administrators
    13
  1. See I was genuinely looking for a older GM tester or something like such including the Kent Moore tools but was worried that the tester wouldn’t plug into that AMC control board plug. And I didn’t want to dump money into something that would be used sparingly.
  2. Yup. Guy wants that much for a very obsolete and almost non existent cruise set up tester. Supposedly a lot of the other car companies of the 80’s used the DANA cruise control system but all I found was AMC and Ford used them.
  3. https://www.ebay.com/itm/DANA-ELECTRONIC-CRUISE-CONTROL-TESTER-W-HARNESS-ADAPTER-USED-IN-GOOD-CONDITION/291890471087?hash=item43f60720af:g:IJMAAOSw8gVX6sk7 Merry Christmas. This guy is dreaming he will get that much. Might as well sit on his shelf and collect dust.
  4. I had a set of black rear floor mats a bit ago. Sold them to another member on here when I bought them from another dealer.
  5. Hoses, pump, reservoir, sensor and power steering gear box. Most everything except the 2.5L reservoir can be had easily. Also there's no need to find a bracket either. The empty pulley is an adjuster for tension on the belt so all you'll need to do is swap in a pump(the pulley/bracket is bolted to the intake manifold on the drivers side).
  6. Wow, that's a vinyl floor, at least you don't have to worry about cleaning carpet. Check the master cylinder for leakage.
  7. I see what you did there. I'm gonna do that on the first! I have been putting it off for too long.
  8. That is a great question, but I'm waiting patiently. The tint guy is going to get it done in January, with life hitting him hard recently and Chrysler delivering all the new 2020 Dodge and what's left of the 2019 models, he has been busy. Rest assured 89 MJ, you will be the first to know about the decals!
  9. Been there, done that. Except I did it the hard way and never removed the side window. Probably should have but oh well. Must be nice to not get wet on the inside. I have to do the infamous door hinge repair to stop that.
  10. I feel very productive lately. Knocking stuff off the long list of stuff to do. Now I just need to tend to other members requests. I blame life. Can’t always do MJ stuff. Anyways bug shield is on and rear bumper bracket will be swapped
  11. One less thing to worry about doing in the future.
  12. Looks like the antenna pad needs to be replaced. But damn that is nice!
  13. Apparently this recall was only issued to "salt belt" states as Chrysler puts it.
  14. Think of it this way. Its free brake rotors! As far as Chrysler changing the rotors, no I doubt it. Now the knuckles I have heard changed for the 4WD models. Yes you have to take it in in order for the recall to be closed and done.
  15. So I decoded it and this truck has buckets and an open recall.
  16. Yup. Oddly enough. The first MJ I have run across with an open recall.
  17. *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 133 Zone 33-Philadelphia 1AA U.S. Dealer Retail 5KR Midland Corporation ADA Light Group ADH Heavy Duty Electrical Group ALR GTS Interior Package APA Monotone Paint ARM Radio AM/FM Cassette BA1 100 AMP ALTERNATOR BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHS Floor Mount Automatic Shift Lever DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HW1 JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2B STRIPE/BADGE/MOLDING/COLOR K3X STRIPE/BADGE/MOLDING/COLOR KLH LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PX8 Black Clear Coat QX8 Black Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 7/31/89 Body code JL61 This truck has an open recall for disk brake rotors
  18. I have a few of those repair kits. There’s plenty from Chrysler. They come in handy. Now if only I could find the right flare nut to repair my original supply line.
  19. Snag 'em and bag 'em!
  20. I just added my set today and I have 2WD. Not a bad idea to have them plus they look pretty cool. There is an aftermarket set out there you can buy but the bumper bracket doesn't have the OEM holes to allow the bumper to move forward for the hidden winch.
  21. *B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -Q8 151 Zone 51-Chicago 1AA U.S. Dealer Retail 4ZF Order Tracking VI 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMF 4.10 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PB3 Intense Blue Pearl Coat QB3 Intense Blue Pearl Coat RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SAA Manual Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z76 Right Front Spring Group VI Build date 8/24/88 Body code TL62
  22. Yup, that's how I drove in the AZ summer, driver and rear window open. Grandfather told me that when he said "There is no AC, just windows down at 40, that's your AC."
  23. That's fair, someone really would have to be a stickler if they were looking. But it doesn't actually look noticeable with everything in place, pretty much hidden if anything.
  24. Nice, looks like a fun porject! I wish I had my truck in high school, oh well. But that 2.5L is pretty base, no AC or power steering, take care of it and it will take care of you forever.
  25. Thank you both! She is quite amazing and is fun to daily.
