Strokermjcomanche
    6
  1. Hornbrod is correct , on the xj the vent hose is on the other side and the whole neck is longer . What's wrong with yours , rusted ?
  2. I believe cherokee ones are the same .
  3. http://m.ebay.com/itm/NOS-Jeep-Cherokee-front-door-panel-grey-power-84-96-XJ-sport-right-leather-/190867976249?nav=SEARCH
  4. Mine grows in like Joe dirt , two bare patches between the gotee and sideburns .
  5. In addition to what Pete said ,a 3.4 out of a 93 /94 Camaro or firebird is the best to use IMO . I put one in my 86 blazer 11 years ago and it's still going strong .
  6. No that's definetly not normal .
  7. :doh: I knew that.............. You're good Don .
  8. Thanks. My white 99 cherokee , I don't have any pictures of that unfortunately ( it's nothing to look at anyhow lol. )
  9. Other then putting this on , I haven't done anything to this for weeks . Getting ready to put the black truck away in storage for 5 months .
  10. He's looking for a skid , not a tank .
  11. It seems like one of the fins may have gotten bent and is hitting the housing , or a bad bearing . Another thing I would check is that the pulley and or pulley bolts aren't making contact with anything .
  12. There should be A slight drag . If it seems excessive go compare it with another one from the parts store .
  13. I may have to go to Akron on Tuesday if anyone wants me to look at it .
  14. Well it's finally on . This is a quality product and would recommend this to anyone with the same problem . Brown dog included everything to do the job except for the tap for the knock sensor hole , which is understandable . Once I get the hole tapped I will put the bolt provided in the knock sensor hole . Here it is installed
  15. You need Monroe shock # 58497 If you have a Lwb truck the drivers side shock will hit the gas tank lip at the seam and will require some modification .If you have a swb truck you're good to go . Not to mention these are cheaper than the ones you linked . http://m.ebay.com/itm/Monroe-58497-Rear-Sensa-Trac-Load-Adjusting-/321800254897?nav=SEARCH
  16. http://m.ebay.com/itm/Jeep-Comanche-86-92-Interior-B-Pillar-Courtesy-Light-/121059797132?nav=SEARCH
  17. If I did a cheromanche this would be it , although I don't know what would happen with a lot of weight in the "bed". It's not anyone's on here is it?
  18. http://m.ebay.com/itm/Jeep-Cherokee-Sport-Sport-Utility-4-Door-/131626242355?nav=SEARCH
  19. It was at 4wd hardware at the columbiana Ohio jeepfest .
  20. That's the one on CL not too far from me . How is it ?
  21. I put mine where the clock delete panel is . I had to drill a hole behind the plate with a hole saw for somewhere to put the wires through .
  22. Check out bonkers on here , he does a good job of posting a lot of Comanches for sale every week . http://comancheclub.com/topic/48502-the-good-bad-and-rusty-1012-cl-list/?do=findComment&comment=493993
