Location
Atlanta, GA
1641 profile views
dkmcgowan's Achievements
Comanche Aficionado (4/11)
I have an 89 Comanche, about 120k miles on it. It runs and drives pretty good, done a decent amount of work on it. I use to drive it daily, but recently got another Cherokee I've been driving some. So the first occurrence was when it was really cold, I had not driven the vehicle in maybe 2 weeks, cranked it up, and there was a very loud engine knock. It got louder as I accelerated. I moved the vehicle in the driveway, and hit accelerator a couple times, noise accelerated and got faster, really loud knock, maybe 2 minutes later or so, it stopped completely. It was really cold, had been below freezing a few days, figure thick oil was maybe causing some really bad lifter noise, ignored it and moved on. It never did again, but also started driving it daily again. Today, I cranked it up, it's like 60 degrees here, not cold. I haven't driven in maybe 1.5 weeks give or take, I got the super loud engine knock again. It also still got faster and louder as I accelerated. This time I popped the hood, couldn't tell if it was coming from the head or deeper in the engine, but a loud knock for sure. It sounded louder and more of a knock than lifter noise, but it's hard to tell. I also never remember, doesn't one of the types of engine noise NOT get louder or faster as you accelerator? piston slap or lifter tick? I went in and hit the accelerator a few times, it would get faster and louder. Then I hit the accelerator really hard one time and it stopped instantly and I drove it all day, no issues again. I know sometimes noises from engine can end up being exhaust, but those usually get softer and softer over time. This got a little softer for a few seconds and then just stopped. I had the head rebuilt maybe 6 months ago when I had it over doing some other work. I checked and had good oil pressure, at the gauge, for whatever that is worth. It was a good 50 psi. Any ideas? If it does it again I will get a video.
I just need to replace o-rings on some 746 injectors. The original Renix injectors had a larger size on the fuel rail and a smaller on the bottom, when doing the 746 injector do I use the same size o-ring on the top/bottom? Can I pick the o-rings up at a parts store? Here are the original ones... http://www.oreillyauto.com/site/c/search.oap?year=1989&make=Jeep&model=Comanche&vi=1181685&keyword=fuel+injector+seal%21s%21o-ring+kit I'm thinking I just need the BWD 274571, but cannot tell, seems like both are the same size. The 746 injectors I have appear to have the same size o-ring on them. http://www.oreillyauto.com/site/c/detail/BWD0/274571/02524.oap?year=1998&make=Volvo&model=S70&vi=1434002&ck=Search_fuel+injector+seal%21s%21o-ring+kit_1434002_1481&keyword=fuel+injector+seal%21s%21o-ring+kit Just making sure... I know they are Bosch EV6, but that doesn't help me find them local.
"full time" light randomly coming on
dkmcgowan replied to dkmcgowan's topic in MJ Tech: Modification and Repairs
I figured it must be a short of some kind, or something wrong with the dash indicator itself. It is grounding somewhere. I think things are pretty different on your 91, I have an 89 Renix. The part time 4wd light is on the passenger fender, I have it circled in red. I can verify this works and is hooked up to my NP231. When the full time light was on today, I popped the hood and unplugged the part time light connector in the picture and the full time light stayed on. Does anyone know which wire is used for the full time light on the renix years? There are 2 wires on the plug going into harness for the part time light. -
I have an 89 Comanche that was originally 2wd and an automatic. I swapped it out to an AX15 with an NP231. When I did this swap, I found the wire on the passenger fender for the "Part Time" 4wd light. It looks like 2 wires coming into a single butt connector. I ran the switch from my NP231, two wires, one wire to ground and the other wire to that butt connector. Now my 4wd light works perfect, if I shift into 4wd I get the "Part Time" light on the dash. All was great... Now when driving around, if I hit bumps, or just randomly, the "Full Time" light started coming on. If I stop and push in the parking brake, and then release it to let it slam upwards, it usually makes it go off for a short time. I probably added the bulb to it when I added the bulb for "Part Time", so originally it probably had no bulb. It's my understanding the Comanche never came with a full time case, but the wiring must have it wired for it. The transfer case that had part and full time had a 3 wire switch on it. How do you think this started coming on? Where is the wire for the "Full Time", I don't see any other wires over near where the "Part Time" wire was. I was also always curious why the "Part Time" wire had 2 wires going into the butt connector, is that something? I know I can just take out dash and remove bulb, but now I'm curious how it's shorting to ground and coming on.
Bosch aftermarket fuel pump installation
dkmcgowan replied to Knucklehead97's topic in MJ Tech: DIY Projects and Write-Ups
I also read about pump being loud, but personally I can't hear it, seems like the same to me with replacement pump, at least inside the cab. Maybe you can hear it more when around the bed of the truck, but that doesn't bother me. -
something at idle pulling a load for a second
It looks like it would be pretty easy to replace the clutch, but I cannot seem to find one anywhere... I found some new mopar units, but they cost twice as much as an entire compressor with the clutch... -
It's a new alternator, not reman, but that doesn't mean much... It's charging great and when I see the load happen, my voltage doesn't go down. I will test both this weekend though. If the clutch is bad on the compressor, would unplugging tell me anything? Couldn't the clutch not disengage sometimes even when unplugged causing something like this? I have some additional info though. When I have the AC on, so the idle goes up a little, it smooths out and I don't feel the load every couple of seconds, even when the compressor is not running... So as long as it's in the AC switch mode I don't feel it, no matter about compressor being on/off. Weird right? Also, when I'm driving and accelerating with the AC on, if the compressor is off and I'm accelerating and it then cuts on like it does every few seconds, I lose power for a second. Is that normal? You can feel the compressor cut on and the engine lose power for half a second, then you keep on going. I've never had a car where you could feel the compressor cut on like that. -
When I sit at idle, I can hear something every couple of seconds pulling load. It sounds like if you barely turned the steering wheel and the power steering pump started working for a second. So this would be like if every second or two you barely moved the steering wheel and then moved it back. I can hear the load happen and the idle just barely drops, then it goes back. I have replaced the belt, the power steering pump, the idler pulley, and the water pump... So on the pulley that just leaves the fan clutch and the AC... When I turn on the AC it seems to stop, so it seems to only be when the AC is off. Any chance the clutch on my AC has some drag every once in awhile even when off? Any other ideas?
I hope it's not just an HO replacement unit. I talked to the tech at Tomco and he says the number very closely match the numbers from the Tomco 12120, which was the sensor for the Renix era's jeeps they do not make anymore. I asked them to send me the values in an email today, we will see. They said this 12134 closely matched the numbers for 12120, just needed a new end attached to it in order to work like the 12120, we will see. The values from the Renix era, I believe, are the ones below...
