co-MAN-che
831 profile views
co-MAN-che's Achievements
Comanche Fan (3/11)
I appreciate the link, I will certainly grab some and fix what I can
PROBLEM SOLVED the busbar is in fact broken in multiple points. I believe I will need a new fusebox, for multiple circuits are down for the same reason. reintroduced power to the circuit directly and everything works as its supposed to. Looking into the fusebox and there is not much left in way of power distribution across the circuits.
so based off what you said and the wiring diagram (thank you for the download by the way), I will double check the radio and blower motor function. They worked when another posted on this thread to try them, but having lost interior lights last night, it has me concerned enough to try again. depending on the results, could it mean the bus bar itself is faulty?
Ok, I pulled the fuse block off the firewall, and there appears to be a missing wire from the 20a TURN B/U fuse. There are 2 yellow wires leading from one tab of the fuse to the flasher, but the other tab (where the contact fell out) has no evidence of a broken wire, as in no broken contact base or corrosion. This makes me thing I was mistaken in my original post for the signals couldn't have worked in the first place. Now I wonder what other wire is supposed to be hooked to that fuse. 12 volt power or is that a signal wire from the turn signal lever on the column? I'm going to get the alligator clip leads out and see if I can reconstruct the circuit with the help of a wiring diagram to test my theory. If i can snag a decent picture I'll post it to try to better explain what I'm seeing
I'll have to see how I can replace the little terminals in the block then. You did read it correctly earlier, the contacts did in fact fall out of the block when I pulled the TURN B/U fuse, so I won't be working with much but I'll see what I can perhaps make work with whats left. I'll be revisiting the page here as anything new develops
I've heard of that issue, and I looked for that when I bought it. All seems dry and leak free in my hands, but that.s not to say it didn't happen in the past. While I've got the fuse block off I'll be seeing what other circuits could have been affected and try to plug a fusible link into its place
Things I've accomplished today: finished up with cleaning and inspecting connectors and grounds replaced signal bulb socket driver side. verified its wired correctly. correct filament illuminates with hazards on and now flashes in time with the rest Things I've learned today: No b+ with key on turn flasher flashers slow down and eventually stop flashing after approx. 30 minutes. Battery is charged and flashers are new. fuse terminals for 20 amp TURN B/U fuse fell out of the fuse block, but had no power before after much probing with multimeter and test light, nothing indicates there is power going to or coming from the turn signal switch, like the circuit is completely dead. hazards still work lost interior dash lights tonight as well. Don't know if from me probing or if the issue is compounding whether headlights are on or off, problem persists. No green arrows light up under any circumstances unless hazards are on Lads & Gents, really getting close to just running new leads and fuses for everything. I hate to just hotwire stuff to work, but I'm nearing the end of my rope
Front Lighting connector has been cleaned and current tested. With Hazards on (all blinkers still work under the 4-ways) I noticed the driver side blinker socket was out of time with the rest, and that dual filament bulb was having the wrong filament illuminate. Flipped the bulb around and squared that away, but that makes me wonder if you should be able to turn those bulbs like that, given their little locking pins are at different heights. Maybe the socket is pooched? Still have grounds to clean and check. Will double check wiring connectors under the dash too. Perhaps the signal switch itself could have a broken contact being 33 years old. Will leave that for last because I don't have a locking plate depresser
all those work as supposed to.
Alright I will certainly get to this. I'll go ahead and place a little bit of fresh dielectric grease in each connection once I clean it.
Hey all, it's been almost 4 years since I had a comanche, and I must say my new acquisition isn't being cooperative. Turn signals worked when I looked at it day of purchase, now only about 2 weeks later, neither left nor right signals work. New fuses, both flasher relays under the dash are new, all new bulbs except headlights throughout. Hazard flashers work however. Arrows in dash light up when hazards are on. Nothing, not even relay clicking when I switch either left or right turn signal. Attempted with just key on run and vehicle engine running, neither produce a result. Heard about fluid leaking from the clutch master cylinder down to the fuse box, mine does leak but fuse box appears dry. Is there a plug or other fuse and/or relay I'm missing? All bulbs are new incandescent. Thanks in advance.
Yup, mine is lwb for sure
I have a long bed. I appreciate you being polite in getting me up to speed
Color me stupid but I don't know what those acronyms mean in reference to the hoist
