Are you certain the fuel tester is working properly? Do you have another vehicle you can use the tester on ? The reason I say that is I went to my local oreilys and rented one and it was not reading correctly. You also said that it's running" very very very rich" . If you unhook the MAP sensor when it's "running" do you notice
any change ? Mine blew the MAP hose
connection off at the throttle body and gave all the symptoms you're describing .
You can also try bypassing the two wires on the white ballast resistor on the drivers side inner fender beside the airbox to see if that changes the fuel pressure reading .
Was there any tags on the rear diff covers? That's one indicator and there should be numbers stamped in the ring gear ( large gear ) to also indicate a gear ratio.
I know the newer lock cylinders are different . There either bigger or smaller I can't remember . But if the holes are too small you can file the hole to fit the cylinders .
Ok We can go with how many swb 86s have you seen ? The grill can be changed as can the emblems . The bed on the other hand would take quite a bit of work to to shorten to appear to be a sb
I swapped in the 95 column along with everything else from the xj in my 89 mj . It's nice having the cruise but the airbag looks like it doesn't belong in the mj lol. I can send you some pics if you'd like .
You can buy a lower shaft seal kit at your local parts store for around 20 bucks. You don't have to even remove the box .But If you have any play or excessive wear on the shaft itself the repair isn't probably going to last long .
Did you bleed the all the brakes at the same time ? Right rear ,left rear , right front , left front? How did you go about eliminating the load sensing valve ? Are you using a different distribution valve?
We had a neighbor that thought she owned everyones house in the neighborhood . We don't have an HOA . She would put complaints in anyones mailbox of what she didn't approve of their house. Needless to say someone in the neighborhood put 50 pink flamingos in her yard one night and put a stop to her holier than thou attitude.
I will be taking both trucks with me . One Is an 89 white mj and the other is my black truck that will be in the heritage museum . Where are you in Ohio? What are you taking ? Maybe we can meet up?
87 didn't have the resistor . It started in 88 . There noisy, but how noisy ? I've heard mine for as long as it's been in the truck (5 years ?) but it functions well
Ok thanks for the explanation . But the sender itself would be helpful . It wouldn't have to be cut to fit the pump . He'd have to acquire the wiring though
