Herc
    Brantford, ON Canada
  • Interests
    Hmmm.......wheeling, wrenching, movies, music
Herc's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Awesome Krusty!! Was just looking at my COMANCHE and considering the options for towing next year. Perfect timing dude!! Will be ordering a set after my move in October, keep up the good work.
  2. Traced the seven fatory spices in the fuel power line from Relay to pump, truck now has fuel again and then fixed fuel leak. MJ is finally running again after several months and total swap out with 96 cherokee. Lotta work and doesn't help when everything is four hours away........but now in the home stretch. One maybe two weeks and I'll be driving it again :banana:
  3. I upgraded mine to a high amp alternator from a Grand Cherokee V8, 135 amp IIRC. Bolt in and plug in to the factory harness(91-92 MJ only), larger casing but still fits without interference. Mind you I several lights, a winch and other various electrical gizmo's, and more to add so wanted the headroom for charging a second battery as well. As for a good aftermarket alternator, AC Delco and Bosch are readily available. For the older Comanche's different alternator and wiring.
  4. ^ we have a winner!
  5. Very nice! I'd love to Dually an MJ one day with stroker and mod'd AW4.....
  6. Both Moog and Precision joints "add grease" When I use a Spicer joint I'll check it as well.
  7. Unless you find an MJ D44 or AMC 20 (which will be bolt in) the rest will not bolt in. I have the Chrysler 8.25 with metric ton springs under my 86 long box, beautiful combo.
  8. Cleaned and painted the engine bay, cleaned the engine/tranny/tcase and installed in my truck
  9. I used a thick cut set of 4.10's on my 3.55 carrier in the YJ they are great. Been runnin them for two years now.
  10. Find a drill, Big enough to drill out the top of the rivet and go just far enough to take of the top of the rivet then punch the remainder through the dash.
  11. Took out the drivetrain, wiring harnesses, dash and steering column.
  12. Not to mention the turdy-five in the rear...
  13. Has the extra length of the 8.25 at the pinion been taken into account? I believe they are 1" longer than the D35 from axle centreline. I also temp bolt in and adjust the angles then tack and pull to burn in.
  14. Dayum........ :banana: :bowdown: :thumbsup:
  15. Here is one from Rubicon Express Spring plate with skid And those shock mounts I used on my 44 in the YJ, they work great!
