Strokermjcomanche
    6
  1. Went on a couple errands this morning and everything is working as normal . Stopped at an intersection , accelerated and the engine revs out to 5-6000 rpms without the trans shifting into second gear and I have no speedo either . If I let off the gas after going I'm guessing? 20 mph it will shift into second gear but has no passing gear . Once I get to maybe 45 - 50 mph and give it full throttle the engine will rev really high but the trans will not find a gear unroll I let off the throttle again . So far I've taken all the grounds, the two trans plugs,and the tcm plug and cleaned them all . I've also checked all the fuses for power . I've also checked for trouble codes and found nothing . The drivetrain is out of a 95 xj with 97xxx miles on it . I've recently replaced the vss and have a good known spare that I'm gonna try tommorow . I'm wondering if it's that or the tcm or??? Any help is much appreciated as always . Thanks for reading .
  2. Sorry Eagle. I was trying to send him a pm about the rol light stuff I have had sitting in my basement for years. The pm was not working for me and I used this 4 year old post to do it . He said he's been looking for them for years in the august mjotm post .
  3. I was able to respond to your pm . I'm gonna try sending another new pm to who I originally wanted to send . Thanks for your help
  4. Are you able to pm me 88comancheMitch? Thanks for your help.
  5. Glundblad: I have 1 rol nos light , 2 nos covers and 2 nos lenses . Pm me for more details .
  6. Sent a pm last night , no problem . I tried sending one this morning . It was typed out , hit send then it said array problem message not sent . Is it a forum problem or my phone or? Thanks
  7. No problem . Just so happens I have a spare shaft that I keep around for future projects .
  8. I was not aware of that. Thanks for clarifying. Do you happen to have a picture of a 2WD drive shaft? I have a 2wd shaft I can take a pic of and send it to you . Once everything is in place measure to get your shaft length . And if you're going to put a lift on your truck put that on before you do the shaft . I had my 2wd shaft shortened with no issues . They took all that rubber crap out , balanced it and put new joints in it for @ 100 bucks .
  9. I think you'd be best off finding someone in your area that has a standard trans mj/xj that would let you take it for a test drive . Personally I like the auto trans as I have one less thing to worry about if I have a pop or something else in my right hand .
  10. Would xj shackles work ? Aren't they only 1/2- 3/4 of an inch shorter in height? So in theory ,getting a set of 1 inch lift shackles for an xj would be the same as an mj shackle . Just a thought .
  11. Have you checked with maaco or Earl scheib for painting your truck . People in my area have gotten paint jobs rather reasonable . For what the bedliner costs ( and your going to have to mask it off anyhow ) it would be rather comparable . I'm all for you doing what you want with your truck and just trying to give another option .
  12. Hey Don I called my friend in parts at the local dealership . He said the oem 53006556 number was superseded and 91 -95 were the same . Hope that helps? Me like a dummy forgot to get the superseded number but I can call and get it tommorow .
  13. I wouldn't be able to get it till tues morning . But if you wanted to stop over you'd be more than welcome any evening after you tell me for sure you want it .
  14. He's 25 minutes away from me and farther from you also . If your serious and want it I can pick it up for you and meet you halfway . You can go on daveysjeep.com and see it on his website under "parts specials".
  15. Theres one a Davies jeep 330 337 5037 $125 . They also have a ax4 external housing 75$
  16. I live in Youngstown Ohio . Bodies rot out but 4.0s live forever !! Lol The 4.0 for sale is out of a 96xj with 77k on the engine . But it sounds like you're out west and might not have as many jys as us . I just got done building my 4.7 last year. Quick estimate, I have about 2k in the motor including all the machining and all new internal parts . Currently it has 2198 miles on it , and other than having to fix an oil pump it runs well . I have another 4.7 I'm putting together but I'm taking my good ole time doing so . Trying to find some good deals on performance parts .
  17. Tj 4.0s will also work in 99-04 wjs as I have one in my 01 as we speak . My advice would be to find a nice, low mileage clean engine even if parts need swapped over . There's currently several in my area with under 90k on them for $400 . With some work( flexplate ,head,etc) you can make most any 4.0 87- 98 fit in your truck . Make sure your rear main seal , head gasket, etc are all in good condition also as it's way easier to change outside the vehicle .
  18. Are you gonna be selling the steering wheel? can I call dibs ?
  19. I've always used bwd o rings . When I install them I use a little Vaseline to coat the rings so they don't bind or get cut . Iirc the BWD part number is 274572 .
  20. Oh ok . The kit came with the square washers when I bought the hitch new . Not saying the strips aren't better but I've towed 4 quads at a time ,vehicles etc.. with no problem . I'm wondering if the've ever been sued for the spacers ripping through the frame?
  21. When I put a new Hidden hitch on my 99 xj the hitch was bolted on with bolts and large square spacers for reinforcement . The kit came with peices of mechanics wire that the bolts threaded onto so the wire could be fed into the frame holes , pulled through and nuts and lock washers were used on the bottom . Iirc there were 4 on each side.
  22. Disconnect the cable at the transfer case / transmission and then that will give you ample room to pull it from the firewall to get to the back of the cluster to see the clip better .
  23. I don't think there's much to save on this one . He made it so customized I think there's a small amount of people that would buy it .
  24. Wow Glundblad nice truck !!! Glad to see an original owner mj even though it left you for a bit .I also have the factory LSD 44 in my truck and I'm the second owner of mine but the cable was snapped clean off and I'm guessing the spare is in a ditch or by now recycled into something else . I never thought to look at my window sticker/ build sheet to confirm which spare it came with . Ill run what I have now until I can decipher exactly what the truck had . Thanks
  25. They all look rather solid/ nice . In Ohio that many Mjs on a cl page would be considered a rust convention . Lol
