6
Pic of SWB gas tank wanted
Strokermjcomanche replied to Minuit's topic in MJ Tech: Modification and Repairs
I can take pics of both my trucks tomorrow evening and send to your email. -
Thanks Don . I see a lot of swearing in my future . I hate wiring and really hate reading diagrams . Do you think that since my alternator voltage is low and controlled by the ecu as I posted in the other thread that if I check all the wiring for continuity and it checks out fine that my ecu is bad ?
When you go to Akron to visit your friend make sure you stop by Swensons . It's a great restaurant kind of like a+w and order a Gally boy . You won't be disappointed .
Are you getting a ground at that connector ? I skipped over the blower connector portion sorry .
Is your truck stickshift ? If so Check and see if the clutch master cylinder isn't or hasn't leaked on the fusebox . Also check to see that the blower fuse has power and isn't blown .
Update : After double checking all the grounds I started checking the rest of the wiring and noticed a couple coroded wires on a 5 wire plug by the trans plugs and by the trans dipstick . I had to cut about 6 inches of wire and solder and heat shrink everything back together . Now I have a speedometer but the trans still shifts irratically . I replaced the vss and the reed sensor with good known spares and nothing changed . I hate wiring and I'm at wits end . Should I try a new tcu ? I'm not sure what else to do . Thanks in advance .
I'm 5 minutes away from I 80 and 76 if you need a pit stop or ? I'm off after 5pm if you want to look me up.
Replacing rear tail lights
Strokermjcomanche replied to Incommando's topic in MJ Tech: Modification and Repairs
I think Mnkyboys truck has them . -
I think I've got a couple faded out pairs of tail lights in the basement . If you can't find a good option we could trade or?? Just an option . -
I'm in Youngstown Ohio , not too much to see here but cedar point is cool . If you need a place to crash for the night let me know .
I can check when I get home and send it to you for shipping costs .
I have a turn signal switch out of my 2000 xj that I took out 10 years ago because when I bought it it was a theft vehicle . They popped the column so i had to get a whole new column . If you need one to try let me know.
light/roll bar mounting
Strokermjcomanche replied to redwolf624's topic in MJ Tech: Modification and Repairs
I can snap some pics of them and send them to your email . But I think on the the informational picture thread there is a picture of what the brackets look like. -
Both the lwb and swb use the same bracketry. Backing plates having 3 m10 x1.5 nuts with bolts are used at the front of the wheel well and brackets mount to the frame using 6 m10x1.5 bolts on each side . -
Looks photoshopped .The rear tires look to be different sizes unless my eyes are playing tricks on me.
Thanks Hornbrod . It's the complete h.o harness minus the part that goes to the tail lights . The sad part is when I did the swap I had the shifter bracket off and if I knew what I know now I woulda changed it due to the fact of how easy I could get to it . I'm going to clean the connector to that sensor and take the 5minutes to change the vss being I have a good spare . Is there any way to check that sensor? Btw I have my own code reader ( innova 3160) and no codes came up related to the trans / speedo issue . Unless it's not capable of reading them .
Eagle : I checked all the fuses and all of them have power . I plan on changing the vss today and will also inspect the gears . This driveline has been in my other truck as well for 30k and never had an issue until now . I'll let you know if the vss works and was trying to see if I should check anything else . Thanks
Fog Light Question for the older folks
Strokermjcomanche replied to glundblad's topic in MJ Tech: Modification and Repairs
Pm sent Glundblad . -
Mitch : I don't see how the cluster would stop the trans from shifting . I would like to know of a way to double check though as I don't want to throw any parts at it unless I already have a spare to try ( and unfortunately I don't ) . Jeep driver : I can imagine how the tps would effect the trans but can't see why I wouldn't have a speedo . Any idea what voltage I'm supposed to have at the tps wires ? I have a 90 (renix) but not for 95 h.o..I have a multimeter
