MiNi Beast
Everything posted by MiNi Beast
  1. just looks to be a axle sleeve for the inner axle shaft. not really needed. seals look good if fit the hole. lube the seal and slap that one piece axle shaft in and run it
  2. very nice. I love how that tailgate came together you gotz skillz.
  3. nice. i swear i do that every time with the backing plates.
  4. damn she's been putting you to work with that thing. good trade off i reckon
  5. what no underbody spray?
  6. well seems the way to go is air, more air better the sleep i reckon. ill just leave this here for those who wonder or might be looking for new ways to get out and about without sacrificing comfort. well its comfy. does allow you to stretch out to 6ft. not bad with the seats jammed forward. says not to drive while inflated, prolly cause of seats but i think you could air it up with seat back in postion so one could drive and other take a nap. It does come with a inflate/deflate pump that plugs into 12v socket. last air bed came with a plug for 120v but not bad if gots the room.. i like my long bed better.
  7. why the fuclk do you need a dryer in the damn desert? you know I dry clothes in the winter even on a line. must be rich be able to afford to heat up your clothes.
  8. did someone say group buy for leaf springs?
  9. sell it add to your funds. Much appreciated that tour saving it for someone to enjoy. looks like a solid truck.
  10. doing work for heat isnt that neat in my little white jeep.
  11. who the f$(@k has 2 pressure gages just lying about??!!!
  12. you just learned from your own experience and solved your current problem. replace the lifters and enjoy your day.
  13. tablets and few case of shock. but get new sand soon and you be good, no peeing in the pool
  14. buy tablets now as gone up and be in high demand and short supply.
  15. for that matter then plan to change out the sand.but varies on use and dirtyness. backwash it once a month. check baskets and ensure a good dip net. the stock up on noodles and squirt guns. and so need a hoop set up.
  16. did you replace or check it anyways sand that is? gaskets are no biggie, worse case is pump line under pool is cracked. keep eye on water level as well. some unions seal back up once running again others are just dryrotted and prolly due for new.
  17. unions check valves may be good after a bit running depending on the maintenence history? was is winterized?
  18. you have a heater set up?
  19. hell no thats a great system brother. need to back wash it and shock the pool.
  20. yeah not bad. these parts are just stupid simple upgrades for these jeeps. jeep go no where if it ain't running right. maintenence parts easy buy decision, peace of mind with reliability. She don't need to be pretty if she gets you home. what do you do with that stimulus check???? Buy jeep parts to keep it running down the road. #Curbs be rough in #MaynardHood..
