MiNi Beast
Everything posted by MiNi Beast
  1. Doesn't advance the timing, it reads the flywheel telling cpu to fire at right time in correlation to fuel injector impulses and spark from distributor. So it dumb down speak for anyone not up on the technical terms, need all three with proper airflow to work. But I'm no expert and am nobody, so read into all you want. If want some technical support and get somewhere go pay for diagnostics. Or feel free to PayPal me when you find out what it is. Thanks have a great day cause I am. Or I'm sorry, just cause I'm having a great day doesn't mean you will either. My bad.
  2. Oh so now my opinion doesn't mean anything eh? That's not very club friendly. To be clear it was I don't give two $#!&z for your responses to my, as you say 'half answers', or how you might feel about my input. You don't like it, keep providing your input and lead everyone away from the club site to your personal site prick.
  3. Air filter time for new one. Temp sender bad so same price to install new gages, so why not. Replacement of some wiring from extra wire that was on the old winch.. score..
  4. I take full accountability for helping members solve their issues. Any input to me on the internet helps one go through many things that can cause the issues. More so when new members are just getting started, like me when I got started, I listened to anything that might get me to the root of the issue. I didn't say go buy this or that, so that's on the certified parts changer. I just often suggest things as it's explained to me and help best I can. Last time you had issues with my cps suggestion, it stilled ended up being cps. May not be here, and I have had bad cps with intermediate voltage signal, so scan tool read it to be ok, but go figure it still was bad. Again I appreciate your technical support as good to understand the proper terms of how things work or are called. I let you handle that being you have your own website and all, however, I just assume continue as my advice has helped many narrow things down if not fixed the issue all together. So what do I know I'm just a guy with a jeep that has yet to perform any of your tips. Good day sir, feel free to agree to disagree cause I'm to busy enjoying life to give 2 $#!&z.
  5. I will always explain it as retards it as makes the most sense to me. Still say cps. but thanks for the technical support.
  6. I cut too much metal to get one to bolt back up. Thank you though for the offer. Leafs will be a welcome edition to the ax15.
  7. Wow that nice red front clip make a beat jeep look good again.
  8. Slight mod. Hard-core tech here, drilled a hole. now to wire it. Yes please.
  9. Now thats getting full scrap value! Nice work.
  10. I want a long....
  11. June I thought?
  12. Awesomeness. Your post made me smile. Thanks for sharing man.
  13. Proper term being 'Cowl vent'
  14. Be a separate shroud for just the mechanical fan as the ac accessory fan has a built in shroud.
  15. Wow, not very often do you find yourself in a position to capture a MJ in its natural environment. Thing of Beauty I tell you.
  16. Finally.. 3x 9" 80watts duel batteries next up.
  17. don't be a jeep snob. You rock that grill how you want. Looks great times being had. ENJOY the time. Appreciate you sharing your experiences.
  18. I hate shipping with ups...... still waiting...
  19. Or just install a 62mm ob1 throttle body....
  20. You could use bumpers to create subframe, what I did front and rear and then welded crossmember as well(don't recommend that, you have good crossmember setup) plating behind cab would help I gather, but keep in mined with the unibody setup we also have a uniframe setup in the back, which in itself flexes out to a certain degree. Which is not a bad thing, but a couple additions to tie the two rails together would help with twisting overall, hence a cage be more ideal. I wanna say there is a cage kit available currently as someone just bought one and I can't think of his name, bought it was had for $1k. Which isn't bad for a bolt in setup, a thought. I look for it as I was interested in it myself and ill post it up.
