MercManche
Location
Flowery Branch, GA
Interests
Jeeps, Diesel, Restorations, Overlanding, ARB, Offroading, Welding, Fabrication, Maintenence, etc.
MercManche's Achievements
Comanche Fan (3/11)
Gladiator Rear Bumper on a Comanche
MercManche replied to JackD's topic in MJ Tech: DIY Projects and Write-Ups
Sorry for the massively late reply, but yea it appears to be basically plastic on the outside with a sheet-metal interior, which is fine, because its still stronger than the original Comanche bumper which is made of bend-ium. Also we did get the stock hitch with this one, the hitch interferes DIRECTLY with the rear crossmember so I don't think its possible to fit it without alot more headache than its worth, I was looking to build our brackets off of something like this https://dirtboundoffroad.com/products/mj-rear-bumper-hitch-jeep-comanche-mj Which all it would need are some nice 1/4" plates and gussets to fit the gladiator bumper too. We have been busy with other projects and this kinda fell off the radar for now. Just should be noted that yes, there are at least 2 variants of the JT bumper. -
Howdy! As soon as we can install them on our other Comanche I will let you know. Just know either way they are a PERFECT fit. Epplebee made a fantastic discovery here. (Thank you for sharing) My only complaint is its a bit hard to remove, so much so I would almost prefer to peel back the pillar panel and press the clip from behind vs using a pry tool and forcing it. Make 100% sure your clips are nice and round and not bent.
Howdy Pete, hope you're doing good man, I hope Jack can get that info soon because it would be great to add a hitch later on. Just mocked ours up on our Comanche. Looks amazing, so Jack thank you for posting about this idea. I believe you used the gladiator "Steel" rear bumper from the higher trims, the one we picked up is off a Sport, But regardless, the procedure is the same. Time to pick up some overpriced barstock. Instead of using the factory brackets, I going to make brackets that attach to the Comanche frame but mimick the JT mounting points so really any JT bumper would work (provided its trimmed for the bed corners) -
Dirty-Diesel Comanche Project
MercManche replied to MercManche's topic in Member Projects: Your Comanches
SOLD! -
@#$% off -
Update: I've been pretty busy with other projects at the moment, I just finished up my wrangler engine swap (2nd engine) and with life as it is, I don't think I want to get into another money pit. The other reason is I wanted to replace our Tacoma with this truck, but in order to even fit the OM617 in the engine bay you need at least a 3-4" lift, I looked at other (rear sump) engines aswell but the cost of getting them and machining adapter plates etc etc etc. So... to anyone who may be interested in a basically rust free comanche & parts. Let me know, I would like to sell the truck whole (with 2nd interior included) and additional parts as needed. -
Fox Shocks vs Old Man Emu
MercManche replied to shipp_m's topic in MJ Tech: Modification and Repairs
My friend used to have a comanche with their 6" kit D44 rear, never had any issues. But I agree, welding new SOA perches is the best way to go about it. -
Contact the guys at RRO, super friendly and you will have to do SOA in the rear and front will be selected with OME parts. https://www.rocky-road.com/index2.html Thats about the only "kit" available. -
If you are running a full OME kit, run the OME shocks, they are valved for the suspension and would give the best ride quality overall (for non adjustable shocks that is). I have Bilstein aswell, they are not specifically tuned for the springs but I don't notice a difference at all in my YJ. I do not like the bilstiens in the front (5100) as they are a bit stiff compared to the OME shocks I used to have. Fox is what I would go with if you are running anything different from the OME lift (as in not their full kit) I had a long conversation about spring rates and shock selection with ARB a while back, I agree with ghetdjc, I would just go with fox if its in your budget. Having rebuildable tunable shocks is the better choice. I have installed a set of Fox shocks on my friends JK about a year ago and it definitely made a big difference, and he loves it. -
Michaels Diesel Tow Rig MJ
MercManche replied to TDI_MJ_17's topic in Member Projects: Your Comanches
Please post some oil pan clearance photos with the 3" lift, looks like an awesome project! -
Been a few, ended up selling the other uh lawn ornament recently so now I have a bunch of spare interior parts and space to work again! Got this AX15 for $150 from a 95 Wrangler, yes yes I know about the transferase clocking and all but its not gonna be a problem. Next update will be after sorting all the parts out and working on the floor pans. Will also be locating a hood, some fenders and some axles. -
Long way away from putting them in permanently but yes I did install them. And they look fantastic! Just a FYI, those bent tabs are not factory, they are from improper removal. they should all look nice and straight. I am going to 100% disassemble them and I have to paint them blue to match my trim. Follow Epplebee's wiring guide and it'll work just like factory. I would recommend the LED aftermarket ones, wayyyy brighter.
Finally found a use for those dumb JLs!! -
Sweet cheap longbed in GA
MercManche replied to MercManche's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Yea he sold it for $1000 I think.
