act now and you could own one of my prized possessions! (though not quite prized enough to keep it over the "comanche" one I picked up). I just couldn't figure out how to safely slap it on top of the pile of stuff I already had so I had to leave it behind.
https://www.facebook.com/groups/329531317967602/permalink/583017692618962/?comment_id=583033345950730&reply_comment_id=583045422616189¬if_id=1621210640493549&ref=notif¬if_t=group_comment_mention
why not both? get some impressive LED strip lighting that mounts flush-ish to the ceiling (maybe hidden in the ceiling grooves, or maybe run along the wood at the peak and the tops of the walls) and then hang some period-correct fixtures to compliment the style.
just remember, there is no such thing as too much light! or for that matter, it can't come from too many angles either. the stupid shadows in the barn drive me nuts! gotta gets some upgrades of my own in there...
no way to get a cheap posi. that requires replacing the carrier and re-setting up the gears. might be a grand per axle. but you can add lunchbox lockers into both for probably under 300 each.
indeed I am. if you could send the fullsize image of the window sticker to ComancheClub@hotmail.com that would be sweet!
that truck is a collectors items for sure
stand closer to snap the pic. rotate the phone and fill the frame with the truck. it's a dark color and the camera can't capture it when there's so much bright sky and ground in the frame.
the MJ doors are the same dimensions and have the same lines as the front doors of a 4dr Cherokee. but in 96 the door striker changed so you'll need to swap it.
taillights are different and do not swap without metalwork.
there are some good door/glass swapping threads in here:
