maddzz1
Everything posted by maddzz1
  1. yeah, I thought if that confused anyone it would be you JT :teehee: we like to take our time.
  2. After 20 years, me and the wife finally got married on the 6th. Just got back from Florida yesterday for our honeymoon/vacation. 1st vacation with no kids in 17 years :banana:
  3. Register it in Rhode Island, you don't need a title.
  4. I know you said only one, but I think the saab vents along with the Z28 vents would look good.
  5. Pat, Are they telling you to wait for your next check? or are they saying they don't owe you the money? Another thing I do if I know I will be working alot of hours for a few weeks is change my exemptions to like 9. This way they take almost no taxes from all the OT. If you change it back after a few weeks it doesnt really affect your end of the year tax return. I think you can change exemptions up to like 4 times a year for fed law.
  6. I had a 79 honda accord. It had an oil chage, oil filter, air filter light on the dash. It had a slot under them to slide the ignition key into which reset them. Its amazing how they can take something as simple as that and complicate it 100 different ways.
  7. left is drivers side. Some of that wiring may be for the license plate light; couldnt tell from the pic if they were there or not.
  8. You can always find one for rockauto and alot of other sites too if you go here and search the website name: http://www.retailmenot.com/coupons/prom ... nAodAioSzw
  9. Read this: viewtopic.php?f=9&t=13614 Some good info. You can get the pans here: http://shermanparts.com/ The welding has to be done carefully to make sure it doesnt get to hot. After you do your tack welds, move around when connecting one tack weld to the other. This allows the metal where you just welded to cool. I am not a welder either but I have to do this to my MJ this summer. I plan on learning to weld prior to doing the job with a welder a friend is letting me use.
  10. I think its a scam. Everyone knows a "Kamel" can't drive. :rotf:
  11. It turns out that when I switched the cluster and reset the odometer I somehow got the needle for the speedo below that little pin. So it was stopping the needle from going up. :fool:
  12. Is it that the holes won't line up? or is that metal u-shaped thing ( Ithink it is to set camber or caster angle) bending up and blocking the hole?
  13. Do you mean just removing the speaker cover on the door? You have to remove the whole door panel. I just replaced mine and when I pulled the passenger side I noticed it felt kind of light. Turns out the magnet had actually fallen off the stock speaker and was just sitting in the bottom of the door. :shake: Eagle said the proper size speaker is a 4" that's installed on a 4x6 plate. Will a 4x6 speaker just drop into that hole? Eagle was referring to the speakers in the B pillar behind the seat, not the door. Were you referring to the B pillar? Ive only had the panels off once; I know there is a bracket that holds the speakers in, not sure how they mount w/out the bracket
  14. In RI you also have to register a truck every year now, where any car is every two years :dunno: and if you put the wrong weight on the registration form they send you a letter saying they canceled you reg and then you have to pay all over again :fs1: I wasnt sure so i made up a weight, they said it was wrong. I said I don't care. They told me within a week the reg would be suspended and i would have to pay all the fees again and go thru the whole reg process all over.
  15. Do you mean just removing the speaker cover on the door? You have to remove the whole door panel. I just replaced mine and when I pulled the passenger side I noticed it felt kind of light. Turns out the magnet had actually fallen off the stock speaker and was just sitting in the bottom of the door. :shake:
  16. If you can't get to that bolt, there is also another one just like it down near the sterring box. But I would do the top one if you can get at it. Easiest way is to turn the steering wheel until the bolt is facing up.
  17. Not at all!!! All opinions welcome, that's why I posted this!! :D :D I have tried the slick 50 to years back with little to no return. Your spot on, there is so many gimmicks and scams going on it is not even funny. But this was a show, dedicated to this product or at least people who have shows putting it on and endorsing this product. IIRC the guys from two guys garage did it. They had many people and even the owner of the company very convincing...heck I forked over the $35!!! I have some tappet noise like all 4.0's. But I seem to have one or two really stubborn ones. They sure seem like they are getting momentarily oil starved. I'm hoping this product clears that up. Time will tell... Thanks for all replies. I'm post up findings in a while.. CW I saw that show too. They had a piece of metal with a divot in it and put the zmax in the divot then heated up the metal and showed the zmax absorb into the metal.
  18. I voted yes. I think it should atleast be decriminalized.
  19. The axles both had things box type things on them almost like the cad; but different from the cad. It had benches in the back like a personnel carrier. The front rims had a step built into them, five or six pieces of metal that came out off the rim maybe six inches so you could use it as a step to reach the other bar type step to get into the cab. The grill was similar to the forward control but different.
  20. This is parked near my work, and it has a load sensing valve on the rear axle like an MJ.
  21. Yah maybe, I got that extension thing, but still...don't you have to actually "patch" the rust holes before the POR or does it fill and harden and all of that stuff? If you actuaaly have a small hole then por15 has a patch you can cover the hole with then the por 15 hardens it. Maybe do a few small easy projects here and there. that helps when i get in this type of mood.
  22. I hera ya, don. I have been back in the gym for 3 months after 5 years out. Doing weights 5 days a week and 1/2hr-45min cardio 4-5 days a week. I also been dieting for the 3 months (bodybuilding style of diet). I like to keep it simple so I eat the same food everyday instead of changing it. 12 weeks of the same food is getting old :ack: with only one cheat meal a week. Stick with it; it will be hard at first but within a month or two you actually feel better after the exercise.
  23. Here you go: http://www.napaonline.com/masterpages/N ... entilation and here's the other half: http://www.napaonline.com/masterpages/N ... entilation and the one on the back of the VC: http://www.napaonline.com/masterpages/N ... entilation
  24. Should you adjust with the wheels on the ground or with the wheels off the ground?
