Everything posted by maddzz1
Mine does this too; but my pedal is also very spungy and goes almost to the floor. The brake light also keeps coming on even tho it is full of fluid. My booster is definately the cause. Good time to upgrade to a double booster
I have their 4.5" leaf packs but havent put them in yet. Answered all my questions quickly
It is the temp sender/sensor It is a differeent part# depending on if you have a full gauge cluster or idiot lights
Intrument Panel w/Gauges ('87)
maddzz1 replied to 87MJJeep's topic in MJ Tech: Modification and Repairs
Defog was not an option for an MJ. The PO probally grabbed the switches out of a cherokee when he hooked up the fog lights. The power/comfort switch with a standard. That I don't understand :hmm: -
Were there any MJs that came with a full center console and column shift? If so, was the black insert different? What fill the hole where the shifter/gear selector goes?
Junkyard suspension/handling upgrades
maddzz1 replied to jeepcoma's topic in MJ Tech: Modification and Repairs
I have heard that the sway bar from an XJ with the Country package is the same as the V8 ZJ -
I have an 89 Pioneer 4wd and it is 15/16 what ever that is in mm. Coversion chart says 15/16 = 23.8
can't really see the pic, but maybe the temp sender. To post the pic just copy and paste the bottom link of the 3 under the image on your photobucket page
Found It: viewtopic.php?t=4968&highlight=prop+valve
No Pete, Someone actually drew the front and rear axle using something like paint or illustrator and drew in the brake lines showing which port to plug and stuff. There was alot of info in the thread
Got a miss that isn't a miss....I need help.
maddzz1 replied to Codycobra84's topic in MJ Tech: Modification and Repairs
Did you switch to synthetic? It may have cleaned up a bunch of gunk and clogged the new filter, and don't use a fram filter. -
Thanks 64, but thats not it. The one I'm looking for someone used illustrator or paint to draw the axles and the brake lines. For some reason I can't find it.
From what I understand, if you are willing to pay the 4500.00 you can buy them. But ,of course, 99.9% of the cars arent worth close to that. :fs1: Unfortunately, american's have decided to trade their freedom for convenience.
AGH!!!! Rust in the floor board..
maddzz1 replied to clarkerussell's topic in MJ Tech: Modification and Repairs
Thanks for the help guys, after reading the above post, I think I'm going to tackle this with the help of a friend. I am planning on getting one of the floor boards from eBay, but I don't know what to do about the reinforcement piece that forms a cross on top of the pan. It does not look like that's included with the replacement pan and mine is pretty rusted in the front half. Any ideas? Clarke I think alot of people use C channel to make those and weld studs on to mount the seat too. -
That worked Pete. Thanks
I am looking for the thread about removing the height sensing valve. The one where someone drew some diagrams asking which was the correct way to do it.
Short term (things I have): -put new injectors in -put new wiper motor in -fix rust in floor (or where floor used to be) Middle term: -4.5" lift (parts I already have: 4.5" Hell Creek leaf packs, RE upper control arms) -31" BFG mt -trim fender and move flares up Long term: -bumpers -rock sliders I just put my buckets and full console in
People are quick to scream ban??? It has been 9 MONTHS. Yes, Pats posts and knowledge are very helpful and appreciated but that doesnt give you a pass on screwing another member. Yes, Pat is having some problems RIGHT NOW but HAS BEEN BEEN EMPLOYED for the majority of the 9 months if I remember correctly. A deadline for re-payment should be established between the 2 involved.
Here is a DIY that will show you some options on repair. viewtopic.php?f=9&t=13614 If you PM pollockzrodz I'm sure he would give you an estimate on what to expect to pay -
I don't have AC eagle. This was alot of water.
I think I know the cover you mean, I will pull it and see if there is a river in there. This is the 1st time this has happened
Doin some brake swapping, need guidance
maddzz1 replied to bigalpha's topic in MJ Tech: Modification and Repairs
Does anyone have the link to the post where someone drew pictures showing how the lines should go? -
Last night it was raining hard on my way home from work. When i got home i noticed my passenger side kick panel, lower dash were wet and there was a small puddle on the mat. After looking the water had come from up in the dash. The wiring in the dash around the knee board lights were all wet. There was also water up on the dash on the pass side that appeared to come in thru the defrost vent. I had put the defroster on with the temp slid over to cold before driving up a street with many puddles. I know this just pulls air in from outside so is it possible it also let water in?
Not sure about the 99, but with the 95-96 booster and prop valve you plug one of the ports on the prop valve and run a single line to the rear axle and remove the height sensing valve. I will see if i can find the post
