clarkerussell
clarkerussell's Achievements
Comanche Aficionado (4/11)
Hello all, I'm trying to refresh the cooling system in my 1988 4.0 MJ and convert to an open system in the process. I have almost everything out, but I can't get the radiator header off because the two nuts that hold the upper radiator isolators are spinning with the bolt that is below it. Is there a trick to it or something? I am thinking I'll need to use a dremel and perhaps cut a slot in the slightly protruding bolt. Then I could use a box wrench on the nut and use a flat head screwdriver to hold the bolt in position. Any thoughts? Clarke
Well, after tearing out many, many parts, I finally found the water intrusion point. It's in the body seam directly under the main fusebox wire harness connector in the engine bay. I have purchased some 3M clear body seam sealer and will be attacking it tomorrow. Since I have a huge tube of the stuff, what other seams should I look at doing at the same time? I'm assuning I should look at the same seam on the passenger side, right? Anywhere else I need to pay attention to? Thanks. Clarke
AGH!!!! Rust in the floor board..
clarkerussell replied to clarkerussell's topic in MJ Tech: Modification and Repairs
It looks like the Cab Floor Reinforcement WAS available as a separate item, but it's NLA from Jeep... Does anyone know where part number 5700 0894 (#9 on the picture below) can be purchased? -
Clutch Master Cylinder for NV3550...
OK, so my roller pin Master Cylinder showed up yesterday, and it will mount just fine. The only problem is that the line I have running from my slave to the master is not correct. The newer master cylinders use a bottom mounted hydraulic line while the old one comes out of the top. Also, it does not look like the line is available from anyone, even the dealer. The only way to get the line is as a complete kit with master/slave/line as one unit. That's $200 at the dealer... Is there a different line that can use to route to the slave, or should I just buck up and either fabricate the mount or just buy the kit? Thanks in advance. Clarke -
Thanks for the help guys, after reading the above post, I think I'm going to tackle this with the help of a friend. I am planning on getting one of the floor boards from eBay, but I don't know what to do about the reinforcement piece that forms a cross on top of the pan. It does not look like that's included with the replacement pan and mine is pretty rusted in the front half. Any ideas? Clarke I think alot of people use C channel to make those and weld studs on to mount the seat too. I think the support where the seat is installed is fine, it's just the part that runs down the middle that's in front of the cross member that is the problem. -
Thanks for the help guys, after reading the above post, I think I'm going to tackle this with the help of a friend. I am planning on getting one of the floor boards from eBay, but I don't know what to do about the reinforcement piece that forms a cross on top of the pan. It does not look like that's included with the replacement pan and mine is pretty rusted in the front half. Any ideas? Clarke -
Well, the master cylinder I had was an OEM part with the hose already attached, but not attached to the slave. The NV3550 I got at the junk yard came with the slave, but the line was clipped. I had to remove the old line (2" or so), and then the new line just clipped on. SO, the only reason I'm looking into this is to avoind the cutting/welding/fabrication of a bracket to adapt the newer Master Cylinder to the MJ firewall holes. If I can just use an older Master with the existing slave, I'll go that route, I just don't know how to connect the master to the slave or if it's even possible due to fluid volumes, etc. Clarke OK, so the new master cylinder does use the newer plastic lines, but now I can't find a place to buy the line itself. The one I have is for the newer Master Cylinder and it attached to the bottom of the cylinder instead of the top. I guess I'll have to call the dealer tomorrow to see what can be done. It is not possible to connect an older master to a newer line(at least not without some real work) All the masters from something like 1993 on are the same plastic style with the roll pin. Any of those will work. The older metal types cannot easily be adapted. And I'm assuming the 1993-1996 master cylinder has the same mounting points as the older style Master Cylinder, right? If so, I might be able to salvage this! I just need to get a 1993-1996 Master and take a look. That's a lot easier than buying a welder and fabricating my adapter... -
Well, the master cylinder I had was an OEM part with the hose already attached, but not attached to the slave. The NV3550 I got at the junk yard came with the slave, but the line was clipped. I had to remove the old line (2" or so), and then the new line just clipped on. SO, the only reason I'm looking into this is to avoind the cutting/welding/fabrication of a bracket to adapt the newer Master Cylinder to the MJ firewall holes. If I can just use an older Master with the existing slave, I'll go that route, I just don't know how to connect the master to the slave or if it's even possible due to fluid volumes, etc. Clarke -
Guys, Can you use a clutch master cylinder for the AX15 on an NV3550? I know the older master cylinders used rigid lines and hoses and the NV3550 has plastic connectors, but would the master cylinder match up to the slave? Is it even relevant as long as you can get a hydraulic hose from the master to the slave? I'm asking because I'd like to go back to the standard mount slave cylinder that didn't require hacking up my firewall, but I don't know if/how the hoses would connect and if the master cylinder had to "match" the slave. Thanks. Clarke
I agree, at one point the slave cylinder WAS leaking, but I replaced it years ago. The fluid had actually leaked onto the fuse box and melted some of the plastic... Now when I tested it this afternoon (close the hood and run water over on the cowl), I saw water coming from the fuse box... The more I think about it, it COULD be coming from the slave cylinder and THEN drip over the fuse box. I'll dig deeper tomorrow morning. Thanks. Clarke
OK guys, I found the source of my floorboard rot and it's at the fuse box. Rain was coming in under the hood, and running down the outside of the firewall. It would run around the slave cylinder mounting bracket and accumulate on the top of the fusebox wiring harness. It would then just leak into the car... nice... SO, I need to take the fuse box out, but see no easy way of unplugging the loom from the back of the fuse box. Is this possible to do? If so, how? On a similar note, is there a gasket or something that should be there? Thanks. Clarke
OK, I've contacted the eBay guy to see if he'd sell just the drivers side pan. Does anyone know what a fair price to have it welded back in would be? Thanks. Clarke -
Well, I started pulling the rubber mat out of my truck to replace it with a new one. Looks like I should have done this much sooner as the driver side floor is rotted out... Crap... I've never had to deal with rust before, but here is what I'm up against. The rust does not extend TOO far up, and the frame rails seem fine. It does NOT extend to the rockers, and it does not go up towards the pedals under the rubber mat in the picture, it stops there. What are the repair options and, since I can't fix this myself, what would should I expect to pay a shop to repair? Thanks in advance. Clarke
Awesome. Thanks for the info!
No AC :) I have a supply of R-12 so I'm not converting yet.
