90eliminator
    Swisher Iowa
90eliminator's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. open radiator and open tank, moved the tank to the area next to the rad, where the airbox used to be, put a new air filter on it... so there was space for it.
  2. did not burp the system....how do I do that....?
  3. Well the system has been converted I think, the old radiator for a new one from a 97, new heater lines to the heater core, bypassing the control valve, but It now overheats. Do I need to change the coolant neck to a newer neck, or should I do simple things first like change the thermostat and then the water pump which is only a year old or so. The system slowly heats up, and then just continues till it overheats, never draws fluid from the overflow tank, and there is no heat when I turn the heat on. So my assumption is that coolant is not getting into the block at all? sound correct. Thanks for any advice!!
  4. I am going to upgrade my cooling system to the open system, but should I flush the system before I do the switch, or just wait and do it after....opinions? Thanks
  5. What is the best way to flush the system. My MJ also has brown coolant. I have a all new parts to upgrade to a open system. Can I just put a pressure washer into the inlet and fire away till the system come out with clean water....??? might try it tomorrow night, so if thats a bad idea...let me know..thanks
  6. hey guys, got a 90 comanche...cranks cranks cranks, then starts and dies... it will continue to do this until the battery dies, or it just decides to stay running, no rhyme or reason... So whats the first thing you think of, CPS, replaced it, ok TPS, replaced that, no change, replaced the coil, again no change... I'm confused and now have dropped $150 into this thing that have made no difference, and the spousal unit is getting ticked off.... please does anyone have any ideas....thanks
  7. mine stumbles all the time, at idle, and during acceleration. I have tried putting cleaners through with no difference... so my next step is to replace the injectors....so I figured I would upgrade them as I went... seen some 19lbs mustang injectors on ebay, just need to know if they would work....thanks
  8. I did a quick search, but nothing that satisfies me completely. I have a stumbling HO 4.0 , Its in a dedicated Offroad Rig, so I would love to put some bigger injectors in it...but what exactly am I looking for. Any Ford ones that fit a 5.0? Do I have to worry about the connection, or any length, or even color? Thanks guys. Shawn
  9. Hey guys, got a 90 eliminator...4.0 aw4, 231... It now cranks but does not run. I jumped in it to go to work the other day, and started it, back out of my driveway where it died, I pushed it back into my driveway and took the other truck...but whats up with this thing. It has done this before but it has always started back up. Any ideas on where to start. How do i check my Throttle sensor, or Crank sensor....thanks in Advance....
  10. Hey guys, got laid off so the company truck went away, so the comanche is back up on the road. its a 90 4.0 aw4, 231 pretty much stock. Here are the two things its doing that I would love to fix. 1. heater fan is noisy, most likely needs a drop of oil or two, is there a location to oil them, or do i need to drill a hole to get oil in the mechanism....? 2. sometimes she doesnt like to start. ie: cranks over fine catches then when the idle is coming down, she stalls, then cranks again, idle drops till she stalls, this will happen three to five times, then she will stay running fine after that. Just somewhat embarrassing at a gas station, or maybe future jobsite. Any ideas on that one... thanks in advance.. Shawn
  11. 90eliminator
    Thieves
    sorry man, if you look on the bright side, that plastic dash trim piece is replaceable... as well as it looks like they did not cut any wiring....so there is an extra bonus, they could have and really screwed you...still blows, but now you can upgrade....or use it as an excuse too.
  12. Ok, the coolant bottle blew up, so I replaced it with one from Napa, but now the new coolant bottle is pushing coolant out the cap through the blow out valving built in. I noticed that the aux fan is not operational, need to fix that...but that should not it to overheat sitting at idle...should it. Also I guess I need to know what the next step is. Radiator, thermostat? thanks in advance
  13. calipers are brand new....well from advanced auto parts...so I don't know? there released now... Is it just the calipers or is the master cylinder...I would assume that since both locked up that it was something in the master cylinder/ brake booster...???
  14. went wheeling last weekend..my front brakes ended up locking up, both calipers were dragging and not releasing. What do I need to replace to fix this problem.... Should I do any upgrades at this point, Its a 92 xj with a 4.0 and it has an 8.8 rear end. so its disc disc. The truck was stopping fine before, but any upgrades would be much appreciated...thanks
  15. So i just installed the sye on the np231, all went well I have a 6" lift.... but now I'm into the driveshaft problem...its a 92 xj with again 6" lift and an 8.8 rear... I've heard that I can reuse a front driveshaft from a xj/mj and have it lengthened... any problems with that...? or any other ideas out there....thanks y'all......
