3
Everything posted by A-man930
Making outboard frame plates now. I cleaned up some old 1/8" plate that had some mild surface rust. Used white vinegar soaked paper towels. Works like a charm for the mill scale as well. mill scale.mp4
I'm confident the welds have excellent penetration and I don't see any porosity or other "technical" problems, but they sure aren't pretty One thing I'm getting out of all this welding is plenty of practice with a flap disc!
What a long process this has been. Here's hoping what I apply onto this surface does as good a job as what I removed
But it is likely to lead to a problem. Loose connections cause heat, especially when there's blower motor current in the circuit.
Engine mount brackets are "done" besides final cleanup and paint. Engine and drivetrain get pulled now to resume work on floors, frame plating, suspension mounts, etc.
rubber floor mat availability
A-man930 replied to ratrapp's topic in MJ Tech: Modification and Repairs
Can confirm; I had Herculiner on my floor for the better part of 8 years and the rust built up underneath it quite badly (plus it also suffered under the pedals, despite being "bedliner"). This go'round I'll lay down some epoxy primer on a CLEAN floor before anything else goes on top. -
Tailgate Straightening
A-man930 replied to ghetdjc320's topic in MJ Tech: DIY Projects and Write-Ups
I might give this a whirl. Do you have any more pictures of the "top-inside" of it? Mine looks like the metal is actually tearing apart; I'll upload a picture when I get home. -
I also want to figure out a way to hook the floormats in place like all newer cars do. The wife's JK floormats have a grommet in the mat and a hook clipped into the carpet... maybe a nut welded onto the floor and a really short bolt? -
I've developed the same concern... I've all but decided to use floormats to protect the "high-traffic" areas under your feet and try my luck with bare Lizard Skin for the rest of the interior (maybe a topcoat for color, but that's it). Edit: I checked their website and found they offer a topcoat: https://lizardskin.com/glossy-topcoat/ -
ShowTime Comanche Build.
A-man930 replied to Quarterpastgone's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Love the electrical work.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
Why is the transmission mount offset?
A-man930 replied to A-man930's topic in MJ Tech: Modification and Repairs
1990 short wheelbase 4x4 AX15. The mount itself is offset from the transmission case center line towards the driver's side. Was this to compensate for drivetrain "torquing"? Does anybody know? I like to know why things are the way they are before I start redesigning them...
Dyasko's 91' MJ build
A-man930 replied to dyasko's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I'm about to re-gear a D60 real soon and have caught myself (once again) thinking about making a case spreader... how do you know how much to crank on it? -
Project Uncompahgre - 1989/1999 MJ
A-man930 replied to USN_JeepMJ's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Wow just found this thread. Beautiful build 😍 -
Been taking bites out of the elephant lately. This is a Boostwerks Engineering Comp. Mount with the outer plates of a JCR steering box brace kit welded onto it. Also welded in some T&M Fab steering box stiffener plates.
Driving on the street to street truck
A-man930 replied to 70barracuda's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Those look right at home in there! Good work! -
I wish I could help, but I don't have a way to transport.
No way to transport and no plans for travel that way until July :/ Sorry man!
