3
Everything posted by A-man930
How flexible is this stuff compared to the surrounding material?
They will be ISO bubble flared; M10x1.0 and (I believe) M12x1.0 If you don't want to flare your own lines, you can buy brass adapters to step down to 3/16" line and SAE double flare and use a pre-made line.
Custom Gaskets for HVAC
A-man930 replied to H3ADBANG4L1F3's topic in MJ Tech: Modification and Repairs
I reproduced mine with knives, tears, and maybe some blood, but yours look to be better quality. Add me to the list of people who would consider purchasing -
Here's the rest of the power steering system (the reservoir from the donor Jetta is shown earlier): -I bent and flared the hard portion of the suction line from some 5/8" tubing from McMaster Carr. -I found AN adapters for the pump and box and had a local shop make the pressure hose with some common JIC fittings. -I'm planning to use the OE trans. cooler in the radiator as a power steering cooler. Upper fitting in the radiator is just SAE flare, but I'm struggling to find a quick connect fitting for the outlet on the bottom...
guess which pile is the good wiper 'puters...
A-man930 replied to Pete M's topic in MJ Tech: Modification and Repairs
It was my understanding that this is more or less a GM part. You may find a wider market if this is the case. Do we know of a typical failure mode for these? So they suffer from Corrosion? Broken solder joints? -
Reusing the ZJ (?) master cylinder I've had for forever. Adding in an adjustable proportioning valve for the rears.
Man, I haven't really stopped tinkering with it, but things aren't really worth posting until they're at least somewhat complete... which takes months in my case. Thanks for the kind word.
I eventually found a parallel-flow A/C condenser for our trucks (I'll provide a link if I can find it) I'm hoping the OE serpentine condenser will flow enough volume to support the liquid-to-air charge cooler. Everything fits so well!
H3RESQ's Dream MJ, the build continues...
A-man930 replied to H3RESQ's topic in Member Projects: Your Comanches
How cool! What exactly does "significant" mean to you, may I ask? -
Bottom Radiator Bushings - Dimensions Needed
A-man930 replied to Salvagedcircuit's topic in MJ Tech: Modification and Repairs
This is why comancheclub is awesome. Thanks to all for sharing these finds! -
Sorry for the no-response on this. I'm using a Variable Frequency Drive; its a pretty popular way to do it nowadays and you can get them cheapish.
Project “Tomahawk”
A-man930 replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Compressor is a scroll-type from a 2000ish Civic, which natively rotate CCW. Was hoping to fit two of them like this with one as onboard air, but this was complicated enough!
This is the most complex piece I've ever attempted, but only because there were so many steps, not because there was any one "hard" thing to do - all rudimentary! To those with any inclination and means to do so, I would 100% recommend getting a lathe and a mill and learning how to use them. It's been a fun addition and beneficial to this whole resto-mod hobby.
After experiencing what a hole saw can do to a Jacob's taper, I can't imagine trying to mill with one
It is super useful! God's drill press and so much more. I should have taken video of using it to cope the 1-3/4" .250" wall DOM for the lower arms. It was straight up impressive.
SRT Comanche build
A-man930 replied to ghinmi's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Another IFS MJ build. Amazing.
