  • Replies 866
On 4/20/2025 at 9:16 PM, watchamakalit said:
What exterior lower window seal did you use with the big windows?  That's my big hang up with the late model window swap.  Is it just as simple as using the late model wipe?
 You’ll need all the late model trim for the outside including the glass surround trim. Here are a couple of pics of how they fit. Unfortunately, the original trim is not usable in the swap. Having a pair of donor doors is really handy for this swap
1 minute ago, watchamakalit said:
Awesome. Glad to see it fits well enough for your approval to use on your build. That means it's way nicer than my truck needs but will probably get. :roflmao:
:laugh:. The one gap you’ll see is in the front near the mirrors. The 97+ mirrors are slightly larger so they come closer to the trim. There is about a 3/16 gap between the mirror in trim in the pics above. Looks factory but I know there’s  gap lol.
Prepping final pieces for paint. I used fiberglass stranded filler for the flares anywhere the gap was larger than may 1/8”. After the glass work, I seam sealed them all to the fenders with medium bodied, flexible seam sealer. That portion is almost cured so will be spraying epoxy primer next. Cowl panel and header panel are all sanded and ready for sealer. Tailgate has been primed and sanded and is ready for a final wipe down with mineral spirits and paint. Hood needs to be lightly sanded and finished. I chose to paint the bottom of the hood black. It is getting lined with 1/2”  DynaCore for thermal and noise insulation. Mineral spirits is my go to for panel prep. It will remove most residues without being too harsh on cured finishes. Plan to begin reassembly tonight. Hope to have this thing out for road testing by Tuesday afternoon.
No rush now. Let it cure. Let it cure. :nono:
I'm excited for you. Going to look real good. Ladies like a man with a big bulge serveys say. :laugh: :beerbang:
Surprising how well the Morimoto 3rd brake light/cargo lamp fits the MJ roof. You do have to make a sizeable opening for it but if aligned properly, it really looks like it was made for it. I added the rapid flash module to make sure it gets attention when I stop.
All paint work is complete. Final reassembly and a few remaining punch list items begins tomorrow. Should be complete very soon. I’d be satisfied never picking up a paint gun for the rest of my days :laugh:
Painting is my favorite part of the job! It makes the biggest difference appearance wise too. Looks good man! You doing single or dual stage?
I said the same thing once my Comanche was finished. I’m getting the itch again… :laugh:
If you need one to work on you can always travel to the Hoosier state and body\paint mine. :brows:
A few shots of the mostly finished product. Only have a few punch list items left. The exhaust shop bent the passenger side tube a little too close to the driveshaft yoke so that piece will be replaced and rerouted in a few days. Then the truck will be on its long journey overseas. This has been a mind blowingly epic amount of work thus far. This project took me deeper into the build of a Comanche than I ever thought I would go. But in the end I’m very pleased with the end product. I’ll get plenty of glamour shots and keep updating with info along the way once o receive the truck overseas. Should be mid - late June.
7 minutes ago, fiatslug87 said:
Do you know how your previous one is doing rust-wise in that environment?
A guy has it stored indoors as part of his car collection. The things never really sees the light of day so It’s rust free. I really don’t let any rust start up. I use DOM16, fluid film, and ceramic coatings all the time to stay on top of any oxidation
There's only one thing to say:
:drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool:
