Black lever on m/t steering column?
3 hours ago, Torq_Shep said:
If you decide you want to sell this column I would love to have it for my truck =P
You can use an auto one if you hold the lock back down the column.
lol no its going in my truck =P thats why I pulled it
2 hours ago, 87MJTIM said:
It is a key release tab.  When you shut off the engine, press the tab down, it allows you to fully shut off the engine and release the key from the ignition.
oh ok cool
On 7/30/2021 at 7:15 AM, Strokermjcomanche said:
^^ only found on stick shift vehicles.
and if you mistakenly turned the key back when you're trying to steer you have to press down on the lever the lock to column
Hmm, it’s on my 91 auto which has always been an auto. Was on my 88yj also and 89 xj auto. Just thought it was on all the typical GM steering columns
15 minutes ago, kryptronic said:
I owned a 95 YJ 2.5L automatic without the lever.  The gear selection indicator was located on the top of the column.
That’s probably key there. All mine have been floor shift autos and all had the lever just like the manuals
Chrystler lists the 'key release lever' as being available for vehicles with manual transmissions and floor shift automatic transmissions.
Concerning the YJ, none were ever made with a floor shift automatic.  All were column shift, and they did not have the key release lever.  A large majority of YJs produced were manuals, likely accounting for the claims that all YJs had the key release lever.  No automatic YJs had it.
As far as Cherokees and Comanches, the lever would have been present when built on all but column shift automatics.
The purpose of the lever is to provide a secondary manual safety guarding against removal of the key prior to putting the car in gear when parking.
