91 Eliminator 83K miles refresh with NOS parts
Dealer installed option, Jeep Special Equipment
From looking thru Jeep SE books it appears that there were 3 different "above factory bumper" winch mounts.
Ramsey was first supplier, 8200332
Warn WAR39637  (available thru Jeep and Warn dealers)
I'm not certain on dates / year of change of each style winch mount.
Found a NOS Jeep SE Ramsey hidden winch kit !!!
Looking at instructions, I have concluded that Ramsey made revisions to the kit.
Coolest part of this accessory is the unique hawse fairlead that fits the shape of XJ front bumper.
Gotta decide if MJ or Chief gets the honor.
I’m really looking for Warn Transformer (like look better than Ramsey grill / brush guard).
Would like to showcase the hidden on one & Transformer on other.
Worked on MJ today...trying get belt chirp to go away.
replaced idler pulley and bushing.with Mopar
Was tightening power steering pump and adjuster nut  broke.
Since MJ will be down few days decided tackle more stuff.  Pulled door panel (first time ever been off) and lubed window mechanism.
i did not want to disturb the water dam so I put Aerosol can inside door thru speaker hole.
Then lubed the hose by Inserting straw thru door clip hole and holding hose up so lube would run down.  Sooooo much better !
Whaaat?  Can you share the backstory?  How?  Where??
P-6605 Kit arrived, it’s the early version for 6000# Ramsey.  As far as I can tell this early kit used the 6000# only.
Kit 29513 for 84-94 XJ used 4500, 5000 which used wing style fairlead and 6000# that used fame fairlead as early kit. This kit used a 2x2 angle iron rectangle frame.
Not only am I a Jeep nut, I also enjoy learning history hands on.  TV sucks !
Ramsey designed a special winch for the hidden kit.  Ramsey 6000XJ.
From the research I have read, the mounting feet were beefed up to allow pulling load from them directly.
Most winches are mounted so feet see sheer loads.  Of course not the case with XJ hidden.
The new Ramsey Patriot 6000 doesn’t look to fit due to motor being “fatter”.
So went looking and found a NOS Ramsey 6000XJ
