89 MJ Posted June 7, 2021 Share Posted June 7, 2021 On 6/7/2021 at 2:49 AM, Pete M said: there's still like a month and a half. you got this Expand We were looking at the site today—46 days until the show. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 8, 2021 Author Share Posted June 8, 2021 Making progress 😌 More wheel coverage to keep the spray down. And found a spot to mount foot pegs. Link to comment Share on other sites More sharing options...
Pete M Posted June 8, 2021 Share Posted June 8, 2021 Front mudflaps are a highly underrated comfort item. I never took the doors off, but pre-flaps the spray off the tires would just obliterate any hope of using my side windows. Lol. 5 stars, would do flaps again. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 8, 2021 Author Share Posted June 8, 2021 Yeah the fender flares helped but still had a couple inches to cover. Now just need liner to block that fender body gap. And working at a set off removable rear flaps for highway cruising. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 10, 2021 Author Share Posted June 10, 2021 Well swapping fuel pressure regulator and seems to be running a bit more smoothly 👍cha-ching $80- Now to replace last part of fuel system. Tank and pump... Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 14, 2021 Author Share Posted June 14, 2021 Well tires off 🙄 going to be a good week. 👍 jk is back so thinking a beach ⛱ day is in order. Cause I love monday fundays. Brief checklist of things to do... 1. Swap tcase for 231d non leaking unit 2. Swap fuel pumps to complete new fuel system overhaul. 3. Swap to new set of leafs and combine old leafs into other back to create a 6 pack leaf stack with hopes of utilizing stock shackles yet still provided enough lift to bring rear sag up and allowing good hauling capabilities...well until I add airbags. 4. Replace brake booster and rerun all new brake hard lines with new proportional valve. 5. Setup 2nd battery and complete dual 12v setup with the new converter. 👌 6. Replace the electrical fans. 7. Install v8 steering pump and install hydro steering setup. 8. Install a reman 4.0 before hit the road to crazy 🤪 Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 14, 2021 Author Share Posted June 14, 2021 Beach day! Go topless. Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 19, 2021 Author Share Posted June 19, 2021 Well i think 🤔, i think i found my tcase leak. Tcase is still good just was leaking, well as i was looking to swap in the 231d and having a pita time trying to find the right rear extension housing, i noticed on the 231j that the front bearing retainer only had 1 bolt, which i didnt think nothing of before, until i was looking at the 231d and noticed 4 bolts holding that one together. So i pulled it and found it was to be sealed up and had no silicone with only the 1 bolt. So perhaps a little bit of goop and a few more bolts and I think it will be good to go back in. 😀 saves me some time-consuming work and will allow me to move on to more pressing issues. 😌 so will slap the tcase back in and move onto leaf springs. Link to comment Share on other sites More sharing options...
watchamakalit Posted June 20, 2021 Share Posted June 20, 2021 So now you have an extra 231 you won't be using? Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 20, 2021 Author Share Posted June 20, 2021 231 d is still on the bench yes. Link to comment Share on other sites More sharing options...
Swampy Posted June 28, 2021 Share Posted June 28, 2021 What hydro setup are you planning on running? Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 1, 2021 Author Share Posted July 1, 2021 On 6/28/2021 at 8:47 PM, Swampy said: What hydro setup are you planning on running? Expand Well, .. I have a factory box tapped, so furthermore my understanding is, I will need a v8 power steering pump or a high flow performance pump of some sorts. I currently have a psc high flow pump but Id be looking to replace that with a bigger resoviour setup. Also thinking 🤔 best to run a 1.5"x8" ram setup on my d44 setup. Need some lines made up as well, and have looked into rebuild able lines so can repair on trail if needed. Havent got to that point yet as maybe 😕 replacing 4.0 with a new rebuilt unit to ensure reliability and complete drivetrain upgrades for the next 5 years. Been busy though out in the woods lately. All in good time. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 5, 2021 Author Share Posted July 5, 2021 Beach day eh. 😎 Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 8, 2021 Author Share Posted July 8, 2021 Still playing in the woods. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 11, 2021 Author Share Posted July 11, 2021 Roof on and a few days in the woods, I'm ready to hit the city and check on my garden, and get some more checklist items taken care of. Changed the oil and now fixen to install replacement electric fans. Good times in #MaynardHood. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 11, 2021 Author Share Posted July 11, 2021 Removable front clip. Perhaps quad fans... 🤔 Link to comment Share on other sites More sharing options...
watchamakalit Posted July 11, 2021 Share Posted July 11, 2021 Your not cool if you don't have at least 6 fans..... Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 11, 2021 Author Share Posted July 11, 2021 Right. Three fans it is and will maybe use 4th in the back as a interior fan for hot days perhaps, and a spare backup. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 14, 2021 Author Share Posted July 14, 2021 Thinking today has good things in store. Link to comment Share on other sites More sharing options...
watchamakalit Posted July 14, 2021 Share Posted July 14, 2021 On 7/14/2021 at 11:55 AM, MiNi Beast said: Thinking today has good things in store. Expand Luck o' the Irish be with you. I had lucky charms for breakfast. Does that count? Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 14, 2021 Author Share Posted July 14, 2021 On 7/14/2021 at 1:13 PM, watchamakalit said: Luck o' the Irish be with you. I had lucky charms for breakfast. Does that count? Expand Indeed. Irish be in my blood. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 18, 2021 Author Share Posted July 18, 2021 Let the week begin. Headed to the woods hauling a trailer load. Dosent like hills or 5th gear. but thus far not overheating and its working. Plus plus i reckon. Gotta get the siding on the master cabin before I head out for the east coast adventures. new lights installed on the trailer before i left with a few racks as well. Nice to finally have a place for the tools of the woods. Need air bags though as the trailer makes the jeep sag 2-3" 😬 atleast need to get other leaf packs installed 🤔 before I leave I hope. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 18, 2021 Author Share Posted July 18, 2021 Rough day in the woods. Living the good life One day at a time. Thanks for following along in our "MJ Adventures". Link to comment Share on other sites More sharing options...
jdog Posted July 19, 2021 Share Posted July 19, 2021 Looks peaceful Link to comment Share on other sites More sharing options...
500 MJ Posted July 19, 2021 Share Posted July 19, 2021 #Maynardhood looks like a very nice place! Link to comment Share on other sites More sharing options...
