thejum57 Posted October 16, 2010 Share Posted October 16, 2010 Charged the battery, replaced the altenator belt. Started it, and removed the positive battery cable to see if the alt. was good. The AAA guy said it wasn't charging. When I pulled off the cable it kept running. :hmm: I'm thinking I saved about $70.00+ Link to comment Share on other sites More sharing options...
comanche12 Posted October 16, 2010 Share Posted October 16, 2010 painted my coils with por15, underbody paint sprayed on my coil base parts and still soon going drill then retap the bolt seat for coil base Link to comment Share on other sites More sharing options...
btm24 Posted October 16, 2010 Share Posted October 16, 2010 put in a new IAC :clapping: Brandon Link to comment Share on other sites More sharing options...
1988comanche Posted October 16, 2010 Share Posted October 16, 2010 i took out the clutch master cylinder, and got brake fluid everywhere! theres a FB post about it Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 17, 2010 Share Posted October 17, 2010 Changed Oil, Thermostat, and checked all the brakes in the Eliminator Wheeled the 88 for alittle this evening as well :D Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted October 17, 2010 Share Posted October 17, 2010 Pulled off the front bumper, remounted the KC amber fog lights to the OEM-style location, and reinstalled. Then I took her to the store to buy some Rogue Ales' Dead Guy Ale after the Rangers beat the Yankees. Link to comment Share on other sites More sharing options...
beaterheep Posted October 17, 2010 Share Posted October 17, 2010 looked at it, realized i didnt want to be out in the wind and cold doing anything to it, lightbar still needs to be wired, front lights need wiring, belt needs changed, still need to weld on the drivers side rear shock mount. looks nice with the temporary 34's on it though... Link to comment Share on other sites More sharing options...
comanche12 Posted October 17, 2010 Share Posted October 17, 2010 starting work on front coil base bolts issue then i just noticed there leak on passenger side front axle wheel seal :fs1: why there always new problem been appear after i fixed something else... :( anyway I'm moving on and keep fix it up Link to comment Share on other sites More sharing options...
MJCARENA Posted October 17, 2010 Share Posted October 17, 2010 Put a stock radio in it. Link to comment Share on other sites More sharing options...
freakjeep93 Posted October 17, 2010 Share Posted October 17, 2010 looked at it while i worked on my car. :( Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 17, 2010 Share Posted October 17, 2010 Fixed the Radio and put front brake pads on the Eliminator Dropped my 88 off for tomorrows 8am Alignment appt. :cheers: Link to comment Share on other sites More sharing options...
JACKED88 Posted October 19, 2010 Share Posted October 19, 2010 I gave it a bath. AINT SHE PURDY??? And detailed the interior ........ (oops, looks like I missed a spot inside that passenger vent) Consider it done. I don't need a new truck to get that "pride of owning a new truck feeling". I get more looks and more compliments on this 22 year old truck than most people get on their brand new ones. Gotta love it!!! Link to comment Share on other sites More sharing options...
comanche12 Posted October 19, 2010 Share Posted October 19, 2010 removed my front long axle shaft(passenger side)... guess what i noticed, its rusted and cover by dirts! :fs1: then i sudden check the seal. there even no axle shaft seal. and there mud/sand/leftover water inside in the long side axle tube.... :headpop: i sudden put my parts and axle in purple power and start think how to clean the craps from my axle. power wash would be most easy way to remove dirts from inside but wish have a way to use purple power to power wash with it. hopefully my bearings and other parts from inside r ok. :fs2: to preowner again! Link to comment Share on other sites More sharing options...
Automan2164 Posted October 19, 2010 Share Posted October 19, 2010 removed my front long axle shaft(passenger side)... guess what i noticed, its rusted and cover by dirts! :fs1: then i sudden check the seal. there even no axle shaft seal. and there mud/sand/leftover water inside in the long side axle tube.... :headpop: i sudden put my parts and axle in purple power and start think how to clean the craps from my axle. power wash would be most easy way to remove dirts from inside but wish have a way to use purple power to power wash with it. hopefully my bearings and other parts from inside r ok. :fs2: to preowner again! You sure? Where are you looking for the seals for? Because they ain't on the end of the axle tube. Rob L. Link to comment Share on other sites More sharing options...
Geonovast Posted October 20, 2010 Share Posted October 20, 2010 Only the last few inches of the axleshafts are past the seal. Seals are almost inside the diff. There's no point in lubricating the entire shaft. Link to comment Share on other sites More sharing options...
comanche12 Posted October 20, 2010 Share Posted October 20, 2010 Only the last few inches of the axleshafts are past the seal. Seals are almost inside the diff. There's no point in lubricating the entire shaft. Well lubracting's not just for shaft. oil lubricating the bearing, gears, etc. inside, seals jobs are blocking dirts from outside and keep oil stay inside without leaking here whats I'm missing: its circled in gray Link to comment Share on other sites More sharing options...
Automan2164 Posted October 20, 2010 Share Posted October 20, 2010 Well it's not just for shaft. It lubrication the bearing inside and block dirts from outside Is that english? Rob L. :???: Link to comment Share on other sites More sharing options...
comanche12 Posted October 20, 2010 Share Posted October 20, 2010 Well it's not just for shaft. It lubrication the bearing inside and block dirts from outside Is that english? Rob L. :???: i just edited it. Link to comment Share on other sites More sharing options...
Automan2164 Posted October 20, 2010 Share Posted October 20, 2010 Only the last few inches of the axleshafts are past the seal. Seals are almost inside the diff. There's no point in lubricating the entire shaft. Well lubracting's not just for shaft. oil lubricating the bearing, gears, etc. inside, seals jobs are blocking dirts from outside and keep oil stay inside without leaking here whats I'm missing: its circled in gray Sure its not hiding behind the carrier? I know on my D30's I have to pull the carrier out to service the seals. Rob L. :dunno: Link to comment Share on other sites More sharing options...
comanche12 Posted October 20, 2010 Share Posted October 20, 2010 Sure its not hiding behind the carrier? I know on my D30's I have to pull the carrier out to service the seals. Rob L. :dunno: yea there nothing in there and ony i seen r mud/sand/water and spider gears Link to comment Share on other sites More sharing options...
Automan2164 Posted October 20, 2010 Share Posted October 20, 2010 I'm telling you its there... But you can't see it without pulling the carrier. Rob L. Link to comment Share on other sites More sharing options...
comanche12 Posted October 20, 2010 Share Posted October 20, 2010 I'm telling you its there... But you can't see it without pulling the carrier. Rob L. ah maybe... so which thats mean i don't have to clean the mud and sand that i saw? i already drain the gearoil and remove cover... I'm gonna remove the carrier tomorrow or thursday... i hope its there. is it easy to replace? i rarely touch those kind of seal in my life. even in uti too :fs2: Link to comment Share on other sites More sharing options...
Automan2164 Posted October 20, 2010 Share Posted October 20, 2010 I did them at UTI. On my MJ. 8) Check this: http://www.pavementsucks.com/tech-article-3.html Rob L. Link to comment Share on other sites More sharing options...
comanche12 Posted October 20, 2010 Share Posted October 20, 2010 I did them at UTI. On my MJ. 8) Check this: http://www.pavementsucks.com/tech-article-3.html Rob L. lucky bastard. only i had touch them r in automatic class... ill check this url now Link to comment Share on other sites More sharing options...
Pete M Posted October 20, 2010 Share Posted October 20, 2010 removed my front long axle shaft(passenger side)... guess what i noticed, its rusted and cover by dirts! :fs1: then i sudden check the seal. there even no axle shaft seal. and there mud/sand/leftover water inside in the long side axle tube.... :headpop: i sudden put my parts and axle in purple power and start think how to clean the craps from my axle. power wash would be most easy way to remove dirts from inside but wish have a way to use purple power to power wash with it. hopefully my bearings and other parts from inside r ok. :fs2: to preowner again! dirt in there is pretty normal. to clean it, you can put some extensions on a shop vac and just suck it all out. the seal by the diff is fine as long as there's no oil dripping out the end of your axle tube. Link to comment Share on other sites More sharing options...
