Automan2164 Posted May 19, 2010 Share Posted May 19, 2010 I miss something?Rob L. :dunno: Yeah, you missed the fact that it says "what did you do to your MJ today?", yet Jake's posts are ok. But it is still an MJ. Rob L. :D Link to comment Share on other sites More sharing options...
Geonovast Posted May 19, 2010 Share Posted May 19, 2010 :fool: Link to comment Share on other sites More sharing options...
shelbyluvv Posted May 21, 2010 Share Posted May 21, 2010 SOLD IT!!!! Link to comment Share on other sites More sharing options...
dunl Posted May 21, 2010 Share Posted May 21, 2010 SOLD IT!!!! NOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 22, 2010 Share Posted May 22, 2010 She got a REALLY good wash!!! I even had blue foam during the rince off!!! :doh: :shake: :eek: :D (Had some oxidation foarming from the rattle can paint job!) CW Link to comment Share on other sites More sharing options...
1tonMJ Posted May 23, 2010 Share Posted May 23, 2010 I got home to today to find the muffler hanging from both pipes, just resting on the flange of the muffler. I have a glasspack that came on my CJ, so that is going under there until I spring for a new exhaust. :shake: Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 23, 2010 Share Posted May 23, 2010 i located and changed my tps.......starts in the rain now!!! those 2 bolts were easier than i thougth theyd be when i was looking at them from the bottom. loooooong extention with a knuckle, 11mm socket...waa laaa........easy....good to know thanks forum! Link to comment Share on other sites More sharing options...
beepbeepmyredjeep Posted May 23, 2010 Share Posted May 23, 2010 Brought the bed cap home today. I'll post pics after we clean it up tomorrow. You guys are going to love it, my dad made some special modifications to it. Link to comment Share on other sites More sharing options...
over2land Posted May 23, 2010 Share Posted May 23, 2010 Replaced TPS. Fixed frayed/broken wires on back up light switch. Painted keying scratches with left-over white from the Dodge paintjob, painted lower front bumper fairing, pulled heater valve rod out to get heat working again after yesterday's coolant/T-stat/radiator hose replacement. Link to comment Share on other sites More sharing options...
Geonovast Posted May 23, 2010 Share Posted May 23, 2010 i located and changed my tps.......starts in the rain now!!! those 2 bolts were easier than i thougth theyd be when i was looking at them from the bottom. loooooong extention with a knuckle, 11mm socket...waa laaa........easy....good to know thanks forum! Surely you mean CPS. :redX: TPS is on your throttle body. Link to comment Share on other sites More sharing options...
beepbeepmyredjeep Posted May 23, 2010 Share Posted May 23, 2010 Cleaned the dome light connectors. Re-installed, works like a champ. Link to comment Share on other sites More sharing options...
Jakeman17 Posted May 23, 2010 Share Posted May 23, 2010 Moved it out of the garage and back in Link to comment Share on other sites More sharing options...
Wildman Posted May 24, 2010 Share Posted May 24, 2010 Jacked it up, and crawled under it the first time since winter........trying to figure out where the burned gear oil smell is coming from :hmm: Ended up topping off all the gear oil spots.......check the bottom end out to see what fell off this past winter. Did find the front right U-joint is shot :fs2: Next month.........time for total service on the 'ole girl, getting it ready for annual inspection again :roll: Link to comment Share on other sites More sharing options...
2360 Posted May 25, 2010 Share Posted May 25, 2010 Today I moved the CB antenna from on top of the cab to the left rear bumper. Still have to run the wire to it. I painted the top the header panel and touched up some other spots on the wiper grill. Replaced portion of the plastic piping from the value cover. That took about 8 hrs. :doh: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 25, 2010 Share Posted May 25, 2010 That's a nice looking topper!! Make sure you have a good ground on that antenna. The ground plane will suk with mounting it that lo to the ground, but the 102" of ariel will help some. Side of the bed is better if you don't mind drilling holes. You get at least a 2" SQ ground plane. CW Link to comment Share on other sites More sharing options...
johnnyc Posted May 25, 2010 Share Posted May 25, 2010 Mounted up a couple of 305/70/16 Maxxis Bighorns to replace my two front bald ones. Found two used tires of the exact same brand and size as the ones that I've been running. About 10/32" tread for $20 each at a tire store. Had a hell of a time getting these on my beadlocks. Couldn't break the bead on the first one. Then couldn't seat the bead on the second one. But it's all done now. Used 8 oz. of Airsoft pellets in each tire. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 25, 2010 Share Posted May 25, 2010 New headlight bulbs... I converted to H4's a couple years back. Upgraded the wiring last year. I swapped in some new bulbs I got off EBay... I have been running a set of these in my Lil commuter mazda and I really liked them so I picked up a couple more sets for the other Jeeps... Sorry for the cell pic.. Yellow is much easier on oncoming drivers eyes. Penetrates wet roads fog and snow much better. CW Link to comment Share on other sites More sharing options...
Pete M Posted May 26, 2010 Share Posted May 26, 2010 I threw the flares on and hit them with some paint, just to see what it looks like. They are a bit higher than stock. I've thought about making them removable, but I'm thinking more about just adding more screws and considering them sacrificial instead. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted May 26, 2010 Share Posted May 26, 2010 Confermed that the parts truck has an internal Transmission problem and alittle more than just 2 loose bolts...lol No biggie, its all getting stripped of parts now anyway :wrench: Link to comment Share on other sites More sharing options...
johnnyc Posted May 26, 2010 Share Posted May 26, 2010 Looks good Pete. I like the new color of the truck. Link to comment Share on other sites More sharing options...
danboone5 Posted May 26, 2010 Share Posted May 26, 2010 Just admired it. Wait till you guys see my floorpans though. Some of you will cry. Link to comment Share on other sites More sharing options...
HKB3 Posted May 26, 2010 Share Posted May 26, 2010 Drove it to see these: and my truck overheated stuck in traffic leaving :rant: Link to comment Share on other sites More sharing options...
DJM/78 Posted May 26, 2010 Share Posted May 26, 2010 Hey pete what happened to 9 shades of red ? I'm digg'in the military look though , would look sweet with some desert painted D windows .. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 26, 2010 Share Posted May 26, 2010 ^^^^^ I got to see a Concorde land and take off once, in Battle Creek, MI.... British air was sending a bunch of its pilots to school at Western Michigan University's Battle Creek Pilot traing program..... friggin shweet! That was obviously before the Concordes were retired..... what a great way to get to school though! Battle Creek has an ANG base... Ft Custer.... A10 Warthogs fly around town every weekend! I love them things! Great lookin Air show though, where was it at? Link to comment Share on other sites More sharing options...
Pete M Posted May 26, 2010 Share Posted May 26, 2010 Hey pete what happened to 9 shades of red ? I'm digg'in the military look though , would look sweet with some desert painted D windows .. They are fighting to get back out. :shake: I hate rust. I painted it last year. Still thinking about doing a camo job on it. There's no way to touch up the "paint" I used with more of the same, so I figure I can just blend all the trouble spots into the camo. :yes: Link to comment Share on other sites More sharing options...
