Everything posted by STERLING STINGER
i went to the local leaf spring shop and got a thick leaf added to each side for $125.00 it has been nothing but good to me for the last 5 years.
Snow Plow Blade
STERLING STINGER replied to STERLING STINGER's topic in MJ Tech: Modification and Repairs
airlift bags installed. Easy installtion and they work great with the reccomended 50 psi in them with the plow on there is no sag at all and the ride is no diffrent. plow blade welded and painted up....ready to go. Thanks for the help guys!! -
Snow Plow Blade
YA ILL PROB INSTALL AIR SHOCKS AS WELL AS THE AIR LIFT SYSTEM....JUST TO BE SAFE -
Snow Plow Blade
I figured something was up when everything bolted right in. I didn't have to drill one hole!! -
Stubborn Axle Nut
STERLING STINGER replied to snakedoc67's topic in MJ Tech: Modification and Repairs
Heat. Lots of it. -
Snow Plow Blade
I got that done already Rob. Thanks for the input guys. I bought the "airlift" for it. I have not put them in yet though. I guess there is no way to lighten it up. Ill keep u all posted. -
Snow Plow Blade
hey guys... just wondering if anyone has ever lightened up a snow plow blade before. i installed the plow that was on my 88 on my 92 i just think the blade is too heavy for the plowing i actually do. and it tore up the 88....bushings, etc.... the blade is ready for a facelift thanks guys!!
Free Cherokee on CL
STERLING STINGER replied to partsmj's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Ha!!!! if anyone gets this i want an invite for a oyster/clam bake -
i am installing a meyers e-47 plow on my 92 mj i need the wiring and cellenoid for the plow. thanks paul
ive recently been noticing a rough idle in my 92. it will idle perfect for a couple mins, but then it seems like it wants to stall out...it will either stall or almost stall on me. It seems to do this even when i am in higher rpms on the roads....it sort of "bucks" also, its shifting all crazy...itll downshift or won't upshift when its supposed to. ive changed the map, plugs, wires, distributor cap n rotor, adjusted the tranny kickdown no clue what else to try. I'm going to change the fuel filter today and check the ground behind the drivers side tail light. hers the vid,,,its only doing it a little here ...it does it way worse than this Any help or comments will be appreciated.
i don't care....air bags sounds better anyways...their not a spring, their a bag
did you put the top plastic piece on or leave it? I called the company and they said the top plastic, to prevent the bag from puncturing on the top was unnesesary.
I once thought about front air shocks for my MJ - No luck Finding advertised - However, doing the dimension thing on the Monroe E-catalog web site http://www.monroe.com/assets/downloads/ ... hSheet.pdf - - I came up with these 2 shocks that will bolt in. MA822: compressed length 14.5 - - extended length 24.4 - - Travel 9.9 MA708: compressed length 12.3 - - extended length 19.9 - - travel 7.6 - - upside down mounting 32252: compressed length 13.0 - - extended length 21.1 - - travel 8.1 - - Monroe OEM type front specs Hope this helps. Yes...THANK YOU!! Has anyone tried them yet?
Then why don't you start off by replacing the sagged out coil springs then go from there? The spring is new.
to install these you have to remove the spring :fs2: and they seem very weak ..... now I'm thinking about going a diffrent route has anyone ever installed air shocks in the front of their mj? if so, what brands are suggested? thanks again Paul
I had to order them from eBay....some aftermarket China crap but only $25 and look good Thanks guys!
i have a yamaha wolverine 2008 450 yfm45fxxl is the model # i can't seem to find hand guards that will fit it. anyone have any website suggestions? thanks Paul
getting ready to install today.... look pretty easy ill post pics and my review when I'm done
