what did you do to your MJ today?
JeepcoMJ
Swapped out the bench seat to buckets.  I was surprised that I took the base mounts off the bench seat  and bolted them right to the seats from a 89 Cherokee.   Made me set a lot higher and added a lot of leg room for me.  I am 5'11".  I also swapped the ecu from a 89 into my 88.  it is suppose to add 8 to 10 HP .  not sure if that happened but it does seem to make it run smoother.
I have acquired an 89 Cherokee that I have demoed and I am going to use the parts to make my 2wd a 4wd.  The Cherokee had a AX15 5 sp in it so it is working.   now my next thing i need to acquire is a Dana 44 with a3.54 gears in it.
I think I will have enough parts to start the change.  Time frame will be in January.
I am also thinking of replacing my fuse box and replace the steering column.   my question is what headaches will I see when putting in a colum with cruise control where I don't have one now.   And how do I replace the swivel in the tilt wheel.
Any suggestions on the upgrades would be appreciated.
I do believe it's 88-90 will give a boost to 87.  :dunno: but my brain sucks so I could have those numbers wrong.
tech questions should really get their own threads so more eyes will see them. :L:
Diagnosed a bad starter and pushed it in my driveway. Yet another week down til i can buy the starter. This truck has been down for one thing or another all but 3 weeks since i bought it the first weekend in Nov..... anyone want to buy a '90 base model?
tis the joys of old Jeeps.  just gotta keep your spirits up and nip away at the issues. :L:  we've all been there.
I can attest to that.
I've got a list of repairs, or upgrades on every Jeep in the driveway.
In the past few days it's rained like there was no end. I found my new rear slider in the MJ is leaking when it rains for a few days. It's already Full***d up my new headliner!
No to mention the dam windshield is leaking even after I put an added layer of silicone.
On top of that it needs a new clutch since the PO did a $#!& job, and the slave leaks. Don't forget it needs front brakes & rotors.
Then my 03 TJ with the transmission rebuild is headed back to the shop for the 5th time, because it still won't act right!
The wife's 11 JKU has a leak on the freedom tops, and the new LED front turns are randomly not working. It needs to be regeared so that it has some balls. No more struggling on the highway.
My son's 94 YJ needs the ax5 rebuilt, a clutch, and exhaust manifold. Add a tire swing to the bumper, install lights, and
Dad's 01 TJ needs an alternator, harness repaired, PCM, complete frame, then the bumper, winch, lift, and lights installed.
I've had a small leak around the windshield, about half way up the passenger A pillar. Last week I find my headliner is wet on the driver back corner, right where it cups under the rear glass window frame.
Late Friday I pull both A pillar trim, and the drivers B pillar. It drizzled Saturday, and had been clear since!
I find the windshield leak using the water hose, and as soon as I start poking at it I realized what the Fu-- stick Di-- dumb half @$$ PO did to try and cover it up!
There's a strip of Butyl tape stuffed around the windshield. Worst part is that this @$$ hat PO couldn't every do that correctly. It was leaking past the Butyl tape!
It's got a small crack in the windshield so the up side is that it's probably big enough to replace the windshield.
Now to find my rear window leak!
So I got a new windshield after 4 hours. Windshield took 30 minutes the clean up in between the old glass and new glass took 2 hours.
the previous owner had installed the windshield with nothing but two layers of butyl tape.
The extra time it took was because they decided to close down and take lunch in the middle of my windshield I was waiting on
Found 50sqft of sound deadening & insulating 50mil adhesive mat on Amazon for $50 shipped.
Rear of the cab, tunnel, and roof are about to get quiet!
Butyl or asphalt based? After my fat mat fiasco I'll never do asphalt again. Also, if your bored look into sound deader showdown. He describes anything more than 25% coverage is a waste for what it's designed for. I ended up pulling my 100% fat mat cab and putting in some Norico 50mil and a layer on mass loaded vinyl. Helped a but I just need new tires.
Sent from my SM-G900V using Tapatalk
I've fully MLVed my truck. I won't say it completely transformed the driving experience but it came damn close. I was extremely disappointed by a nearly full covering of dynamat before this.
Of course, in my experience the main issue at speed is wind noise. No sound deadening material will do anything for that.
I did the floor and rear cab. The tires only have 10k on them but they are 8 years old and I get a nasty howl around 40 mph, doesn't help I have phenomenal hearing. I end up wearing earplugs on pavement. Earlier this year when I rewired I put in a oem firewall mat and that helped my noise some more.
I thought about some closed cell foam, really dense and thick, to put in the B pillars, but that phase passed once I began soddering wires. Found today that my tcase is about dead, very pronounced resonance you can feal, so maybe my tires aren't the culprit. I did run out of fluid a.few years ago lol
I'm using 50mil butyl base foil backed. I'm using more than I would if it were solely for sound deadening. The foil backed 50mil provides very good heat reduction. It's not as good as using an actual insulation, but is easier to install, and no messy fiberglass.
I know what ya mean.
I'm debating doing bed liner in my Rubi. 6in long arm, 35s, tummy tuck, custom shafts, regear, custom torque converter, and no carpet to avoid the messy cleanup after wheeling. Everything resonates, and the volume is unbelievable. I could use a thick coat of bed liner, and it will take quite a bit of it out.
If you look around Lowe's\Home Depot you can find Great Stuff expanding foam for doors\windows. It's not the regular Reed cans. These are green cans, and less destructive that the original. I'm going to fill my pillars, and roof line with it.
Got the tcase rebuilt. Apparently red rtv doesn't hold up to atf fluid, plugged the lube galleys in the main shafts and created a little wear on the drive sprockets. I did run it extremely low if not out of fluid a few years ago. Used a different case and guts I had, did the output bearings/seals and used some locktite 598 black with is compatible with atf. Fixed my 60+ mph vibration due to front output being being toast, but I still have a clicking noise while creeping. I figure it's driveshaft related since the inner part of the cv joint is bone dry and I only have 1 new grease able joint on it. I'll have to pull it and go for a drive before sinking more money into that stupid shaft.
On 12/26/2018 at 11:22 AM, GreasemonkeySC said:
So what did everyone's MJ get for Christmas?
Oh oh oh pick me pick me, mine got a BOAR offroad recovery bag loaded with 2 d-rings, a snatch block, 3 recovery straps in different lengths and colors, folding shovel in sheathing bag, a pair of gloves, and line snap hold down bag and hi lift jack with base and anti rattle rubber handle keeper thingy.
