Everything posted by watchamakalit
Finally found one...Now it has a new floor.
watchamakalit replied to watchamakalit's topic in Member Projects: Your Comanches
oh boy oh boy I am super excited. Apparently all I had to do was buy the wife a pop up camper. I got the approval and ordered a set of General Spring Military Wrap springs. New ford f 150 shackles. RE 3.5" front springs. New front spring isolators. Just waiting on the parts to arrive. I might have slipped in a few other goodies too...... -
The duct tape you see is probably original. Its a good idea to go through the harness and fix these connections. There are crimp connector from the factory and should be replaced with a good solder joint and heat shrink tubing. The fittings in the radiator are usually for a built in automatic trans cooler. If you have a manual tranny they would have just been left vacant from the factory. Are you looking for the temp switch or just wondering why there are connectors missing on the radiator?
Thats kinda what I figured. Guess it really doesnt matter since turbines trump all. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Is there any way to tell what wheels these would have been from the factory? Just curious, I recived the truck with a set of steel rims on it. "WJN 15" Aluminum Wheels"
A College Students V8 Comanche
watchamakalit replied to 88mjsally's topic in MJ Hardcore Tech: Epic Journeys to Greatness
You may not want to use a set screw in there. I believe the plastic pins are there to allow it to collapse in the event of a head on collision. with out the plastic the steering shaft becomes a giant harpoon aimed right at the driver. Might not be bad to use a really low grade bolt, but I am not an expert..... -
How to Install RENIX Factory Cruise Control
watchamakalit replied to Blaine.D's topic in MJ Tech: DIY Projects and Write-Ups
Awesome thread. I am prepping to tackle this myself. I still need the brake switch and a lower speedo cable. Edit: Apparently I also need the bracket to mount the brake vacuum switch. Any idea where I can source one?- 17 replies
- 84-89
- cruise control
(and 1 more)
Tagged with:
This weekend was an interesting on for the MJ. Started out like any other friday morning but by 1pm I was elbow deep in my buddys excursion. He came in my drive doing 2mph and what sounded like 50,000 rpm. We new the transmission was getting close but neither of us was prepared for the sudden death. So the MJ had to sleep outside for the weekend but it became more fun on monday morning. I woke up at the but crack of dawn to take the MJ, with the transmission loaded the night before and strapped securely in the bed. Drove to my buddys house about 20mins south and picked him and a fresh cup of coffee up. Drove approximately 30mins north to the local tranny shop to exchange his junk for a fresh rebuild. We pull into the tranny shop parking lot and I parked the MJ. We climb out and I just about crapped my drawers. There under my baby is a puddle the size of a large wheelbarrow tub in the middle of what was a dry parking spot. After a very short investigation we realized the torque coverter had fallen from his trans and turned my MJ into a bit of a rolling, Mercron filled swimming pool. Boy was I relieved. Long story short we made it back to the shop with a trans that functions as it should and my buddy was back on the road about 2pm yesterday. The best part about it all is I get all day today to wash out the bed and the rest of the truck. But thats ok it was due for a bath. I will try to remember to take some pics of before and after....
That helps a ton. Now to get mine in and work on the install. .....
Butt weld. Forget the overlap idea I have tried that on MJs before. You will end up trapping moisture between the 2 pieces and simply continuing the rust cycle. Butt welding isn't that hard. There are some great tips and tricks that can be learned online for free that will help you a bunch. Let me finish this by saying, I am not a body guy by any means. I have just attempeted several methods of metal repair previously and can tell you what won't work.
- 15 replies
- street comanche
- body work
(and 1 more)
Tagged with:
eaglescout526 do you have any pics that will show the vacuum harness layout for the cruise? I think I have all my parts collected but I have done some head scratching over the vacuum harness.
Drag Racing Comanche - $25K
watchamakalit replied to bruceb's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I believe the bellhoisings are the same with the exception of the cps for the 4.0 My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
Is the top one the connector for an overhead console? Those look similar to that. Although I'm just going off memory. Not sure of the other one. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I have 2 sets of gear wrenches that I purchased many years ago when they first came out. Only trouble I have had with them is wearing out (not breaking) the ratchet mechanism in a couple of the common wrenches. Ive never managed to break one and I havent been gentle. I really don't underatand how I ever accomplished anything before owning them. Probably some of my favorite tools. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I can't say for certain but I'm sure someone makes an adapter and honestly if someone is in the buisiness of building trucks of this caliber probably has the resources to manufacture one. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
I'm a 7 slot fan but I think its the cj lover in me...... My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Probably pretty well I have a 904 in my co behind a 258. don't see why it wouldnt work behind the 4.0. Obviously not factory. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
https://www.nrablog.com/articles/2016/12/infographic-trap-skeet-sporting-clays/
Never really shot alot of trap. I'm a skeet shooter at heart. Personal beat is 23/25. But watch my father shoot many a perfect round. Made everyone mad when he did it with a 410 o/u My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I built a clay thrower a couple of weeks ago. Been planning this for a while but finally found time to throw it together (pun intended). My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I brought home 31 white bass and one crappie. My buddy had about half a dozen white bass and a nice channel cat. Her are some more pics My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Today I worked on controlling the fish population. Had a good evening. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I always seem to be a day behind when I get on here. lol Yesterday I tackled the new project on the mj. Sleeping quarters. I put the topper back on and began construction of a sleeping platform with storage underneath. don't worry everthing is good with the wife, I don't need a place to sleep. We are planning a road trip vacation to go see Yellowstone National Park and I have convinced her to take the truck. Today I have to deck the platform and begin working on a liner for the topper and some lighting....
I spent the last 2 days changing a u joint and both rear wheel bearings. It began with just the clunky u joint. I crawled under to change it and noticed the wheel seals leaking. I thought to myself what a great time to fix it since I didn't need to drive anywhere for a few days. After a lot of chasing parts, received wrong parts first round, I found a press at a friend of a friend house. It took 2 days because for some silly reason I still don't own a press. Locating and obtaining permission to use one, seems to be more difficult than before. I think when all this crap is over I am making a trip to harbor fraught to purchase a press. Put her all back together yesterday afternoon. Took a short test drive. Unfortunately something happened to the soothing vibration and growl coming from the rear of the truck. Now I have to listen to that silly radio in the dash. Oh well I trust my truck to begin making another joyful sound of carnage for me to listen to soon enough.....
