watchamakalit
Everything posted by watchamakalit
  1. I get 0 ohms between the black wire and bat. neg. terminal. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  2. I will check this tonight when I get home from work. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  3. X2 My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  4. Not today but yesterday I "cruiser54ed" my valve cover and for the first time since I owned it I arrived home today after work with a dry valve cover. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  5. I guess I need both. I have an ax15 now so I suppose I will need the trans harness to. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  6. There is not enough power to light a test light so I am assuming a short in the circuit. I tried bypassing delay box already with no change. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  7. That reafing was key on engine off 12.6 at the battery terminals. I'll check it with a bulb and report back My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  8. Pump tests good but won't run when connected in truck. I have a varying voltage at the pump plug 10.8-11.4 when the wipers cycle and the washer is activated on the stalk. Any ideas? Something sounds shorted. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  9. Wanting to swap an auto into my mj. Let me know what ya got and a price shipped to 46750 My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  10. Pete, is that a shortbed? Do you need to get rid of it to calm your buyers remorse? Sent from my KFFOWI using Tapatalk
  11. I have a d44 rear. That's a for sure on the airbag My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  12. Well I guess if I decide to tackle this I'll take pics. I have a tilt column My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  13. I had a temporary daily driver that was a loaded 99 GMC 1500. Really the only thing I miss is the cruise. So I feel it would be worth a fair amount of effort to obtain it. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  14. I'm running CV shafts in the front now. I plan to pull them for spares. Will the unit bearings from the hubs swap as spares? Ive made mistakes and tossed usable parts in the past that I wished I hadn't. Just trying to cover bases. If the steering components are in good servicable condition would they be usable? My truck is not a crawler. Just a well loved daily. I'm not planning to swap these parts immediately just saving for emergency needs. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  15. Man. I hope one day the stars align and I can shake your hand. You never cease to amaze with your intricate knowledge of the inner workings of these trucks. I hold you in very high regard sir. That said I have a very solid mechanical ability not afraid to tackle anything. Thus me driving a 30yr old truck for a daily. However the basis of where to start and components necessary is knowledge I lack. Do you have a link to the half write up so I could do some research? My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  16. So maybe I should just live without cruise? Lol. No a problem for me. Just thought it might be nice to have. Any write ups out there? I looked but couldnt find any. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  17. My multi function switch is broken in my current column. I was just going to install a new switch but then got to thinking maybe this would be a good time to add cruise control. Would it be easier and quicker to just swap in a different column? I have heard the cruise wires are a pain to snake through the column. Is a factory cruise control swap possible? My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  18. Its a 4.0 I plan to save the motor for sure looks to me like wheels and tires should swap. Brake booster and master? Tcase, Front axle?
  19. The decision has been made. I have a zj parts machine. Suggestions on what I should pull for the mj? My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  20. It also feeds the vanity lamps? I guess i don't know if those were working or not but I am guessing not. Looking like I'm not going to get into it tonight, might have to be a coffee project for the morning.
  21. well the gives me an idea where to start looking ill go dive in and report back with findings..
  22. Yes. Blower and signals work My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  23. Clutch master is not leaking. Its one of the first things I check whenever an electrical gremlins shows up. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  24. I just put a new fuse box in about a month ago. Fuses are good connections in the box are tight and clean. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
  25. Leaving the jobsite this evening radio came on like normal. Before I hit the clutch to put it in gear the radio and lighter lost power again. I drove approx. one mile down the road and it came back on and began to function just fine all the way home. I really getting baffled by this one.
