Everything posted by watchamakalit
The manche has me scratching my head. I have the dreaded start and immediately die issue. I have had this issue before and fixed it with a good cleaning of the ballast resistor terminals. This round is different. The truck will start with the key in the start position, but as soon as the ignition is turned back to run the truck dies. I have fuel pressure in the ignition switch start position only. No fuel pressure in the run position of the ignition and no prime from the pump. The B+ latch relay and the fuel pump relay have tested good and are reciving constant power. I can jump past the relay and the pump will run and create pressure on both circuits. The ballast resistor tested good. And I have tried bypassing completely with no change. I have completed all of cruiser54's tips. I believe the ecm is not signalling the relays to cycle but I can hear a relay in that area cycle during what should be the prime circut of the pump cycle. I have not tested the ecm pins to see if its providing signal to the relays. My question is where does tge ecm recive signal to tell it that its time to engage the propper relay? Does it read that off the cps? Or is there some other sensor responsible for this? I am pretty sure it is a faulty ecm but have no way to verify this other than dropping $150 on a possibly unnecessary part. Sent from my LG-H871 using Tapatalk
Yesterday I got the dash all back except for the radio, which is getting replaced. And I got the window tint finished. Pulled the ecm, pretty sure it is the cause of the elusive start and die immediately problem. Ballast resistor and fuel pump relay both checked good. Also ripped out the carpet. Time for a proper floor repair. The temp. pan that I threw in when I first got it has past its life. Gotta start shopping floor pans. Sent from my LG-H871 using Tapatalk
Need direction... driver side firewall
watchamakalit replied to Articul8's topic in MJ Tech: Modification and Repairs
There is a quarter inch bolt directly in the middle of the connector that has to be removed. I'm sure someone will be along shortly with a pic to clarify. Sent from my LG-H871 using Tapatalk -
Finally found one...Now it has a new floor.
watchamakalit replied to watchamakalit's topic in Member Projects: Your Comanches
Finally getting somewhere. I had a good day at the wrecking yard last Thursday and decided it was time to do something to the mj this weekend. So here is a run down. Sorry no pics I was too focused. New fuse panel is in. Core 4x4 adjustable trackbar is in 97+ wiper arms are on New hood latch cable is in New trim bezels for the door handles are in Window in both doors got tinted I would have probably put the dash in it too, but I was out of brake clean. I need to clean all the old schmoo out of the fuse block before assembly. And I have learned fuse panel work is super easy with the dash out. Tonight the fuse panel will recieve a good de-schmooing and fresh grease before reassembly. And hopefully the dash gets put back together. I will try to snap pics. Sent from my LG-H871 using Tapatalk -
I spent yesterday at the junkyard. New dash, fuse panel, wiper arms, cluster lens, hood latch cable, and a xj overhead console all followed me home. Ready to put some shop time in. Sent from my LG-H871 using Tapatalk
Jeep Turbine 10-Spoke Rims Restoration
watchamakalit replied to NEO auto's topic in MJ Tech: DIY Projects and Write-Ups
Love the look of these. Guess I'll plan on some sanding and paint in the future. Sent from my LG-H871 using Tapatalk -
Fuel filter is done. Time to move in..... Sent from my LG-H871 using Tapatalk -
Well the mj has been relaxing in the shop. In the last week I have polished off several of cruisers renix tips Changed the belt, air filter, and wiper bushings. Fixed the dome lights, back up lights and fabricobbled a home made collar to hold over the slip collar on the front axle. I still have a fuel filter to change. Next on the list will be the new windshield. Oh and some updated pics to. Sent from my LG-H871 using Tapatalk -
Finished my 4x4 conversion finally today. Last piece of the puzzle was my homemade bracket to keep the front axle locked in. Its really coming along. Should be in dd status shortly. Sent from my LG-H871 using Tapatalk
Didnt take any pics but I repaired a broken wire causing the interior lights not to work. Also cleanned a couple grounds and the c101 connector tonight. I'm committed to getting the my back to road worthy this time. Hoping to squeeze in a junkyard trip this weekend if time allows. Sent from my LG-H871 using Tapatalk
I'm an idiot. I didnt even think about rolocs. I love those things. Good idea on the turntable. Sent from my LG-H871 using Tapatalk -
Following. I have a set of 5 on the truck and I think 2 or 3 extras 2 of which are bent. Sent from my LG-H871 using Tapatalk -
Rip Don Sent from my LG-H871 using Tapatalk
Belay my last. Found the issue. All relating to the fuse panel. All are functioning properly now. Life is good Sent from my LG-H871 using Tapatalk -
Okay guys I've got a strange one. She is all back together but now I have no function out of the electrical items on the steering column. All connectors have been checked and re checked to confirm the are securely connected. No wipers, hazards, or turn signals. Also having a brakelight issue but I believe that to be related to the decaying fuse panel. Any thoughts on where to start? I am thinking its got to be something fairly simple, probably a mistake on my part, since they are all on the fritz together. Any help or suggestions are appreciated Sent from my LG-H871 using Tapatalk -
Just found this post. Don, Get well soon. I don't post alot but read ritually. Even in the short time you have been absent your presences has been noticed and missed by many. We are all anxiously awaiting your return. Dave Sent from my LG-H871 using Tapatalk
Lights on Gauge Cluster
watchamakalit replied to Amccutc21's topic in MJ Tech: Modification and Repairs
Don't forget blown fuse.... Sent from my LG-D850 using Tapatalk -
Ok little update The old cracked dash is back in for now and after a long talk with my most trusted advisor momma and I came to the conclusion it is now time to reassemble the mj and put it back into dd status. I plan to finish many small projects as time permits while still dding it. Hopefully all will work out well and the big chebby can leave my possession leaving me with just the mj and cj. All will be right with the world again. Sent from my LG-D850 using Tapatalk -
After cruising pictures on Google I am now kind of leaning towards an all black interior Sent from my LG-D850 using Tapatalk -
Mine are all vinyl but if I can find a decent set of gray cloth I wouldn't be opposed to them. Got any pics? Sent from my LG-D850 using Tapatalk -
I currently have the dash out cleaning a mouse nest from the bowels of the heater box. That's why I am actively pursuing a clean crack free gray dash pad. And a set of bucket seat covers. Sent from my LG-D850 using Tapatalk -
As promised a while ago here she sits in the new (still under construction, but getting close) shop Sent from my LG-D850 using Tapatalk -
Wow did this thread ever get neglected.... So not much has changed with the mj in a while. I got her all out together,and drove her for a while. Then there were a few "incidents". I smashed the header panel and punched a hole in the tailgate when a chain snapped. Before anyone freaks I was pulling a bush out of the flower beds not a vehicle. It was a short chain with enough force to pierce the outside skin of a poor condition gate. Then I incurred damage to the bed on both sides and one rear corner. It's still drivable it's all just cosmetic. Then life got in the way and I got greedy (working 70hrs/week) for big paychecks and I bought a newer dd So the mj went to the barn and got relegated to shelf duty[emoji22] But the shop is very near completion and by the time it's done it will be cold out and work(construction) will slow and I will need a winter project. So it is time to start collecting parts as the mj will be back to dd status hopefully by next summer and the gmc will get sold. The search is on for the remainder of the parts I need to fix the damage and finish the truck. I have returned it to the original header panel but will be ordering a new 97+. I opted against the door and fender swap again just don't care for the newer door panels. I am on the hunt for a rust free bed, a clean grey dash pad, and a few other misc items. I have funds in reserve and the go ahead from the boss to finish the work so it should be smooth sailing from here on out. Lol I'm away from home but will get some picture updates when I return. Sent from my LG-D850 using Tapatalk -
I'm hunting for a crack free gray or black dash pad haven't had much luck locally. Anybody got one? Sent from my LG-D850 using Tapatalk
Another overheating nightmare
watchamakalit replied to VixJeep's topic in MJ Tech: Modification and Repairs
Plastic expansion tank cracked? The cap on the tank is also a pressure cap just like what most people think of when you say radiator cap. Most people don't realize that a cooling system needs to build pressure to be capable of handling the cooling needs of the engine. If it's not holding pressure it will overheat. The same attention needs to be played to the 50/50 mix of antifreeze and water.- 23 replies
- Cooling system
- open system
(and 3 more)
Tagged with:
