Everything posted by watchamakalit
is it a short bed? Id be interested in the roll bar if so.
dang pete you beat me to it. I was about to ask about the bed.
Did I find a replacement renix oil cap?
watchamakalit replied to watchamakalit's topic in MJ Tech: Modification and Repairs
I did but it was long ago in a galaxy far far away. Translation: yes but can't remember results, as it has been too long ago for my brain to recall. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
Weber Carburetor 38 Dges/Dgas
watchamakalit replied to AMC86Kid's topic in MJ Tech: Modification and Repairs
I want to start off by saying I am for sure not a carberator guru. I have spent my shjare of hours leaned over a fender scratching my head just like you are. It sounds to me like you need a vacuum guage, a tachometer and a fuel pressure guage, and a manual or at bare minimum a parts breakdown for that carb. before you will get much farther with success. It also sounds like you would benifit from some reasearch on how to properly set a carb. I am not trying to tell you how, I just know that continually moving screws when you don't fully understand what they do will not help. To the best of my ability and guesswork: The screw behind the choke is an idle adjustment. It will help you to adjust the idle. To get the idle adjusted properly you first need to adjust the air fuel mixture. Its been a long time but this is best done with a vacuum guage IIRC. The 2 mixture screws are probably Low speed mixture and High speed mixture. I can't tell you which one is which, but a manual will. The other port is probably a full time vacuum for a break booster or somthing similar. I hope all this helps. And I am sure someone on here with more carb experience than me can help some more. -
Have you considered a donor harness from another vehicle? I swapped the entire engine harness in mine in about an hour. It also gave me a chance to completely dissassemble the harness and inspect/repair it before installing.
Cluster swap all day. Looks a lot better IMO. Its a really easy upgrade and you gain full gauges.
Yes along with cruisers mods. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
Extended cab? My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
While you have the belt off pay attention to the water pump. Especially the amount of resistance it takes to turn. There should be some as you should be spinning the impeller in fluid. Sounds almost like the impeller has come loose. Have you had any cooling issues? I would give the water pump shaft a good wiggle side to side and make sure the bearings are good. Also try taking a long bar (prybar or similar item works well). With engine running place one end of the bar on each belt driven item and place the other end in your fist with your ear up against it. You will be able to hear where the noise is coming from. I was taught this trick before mechanics had stethoscopes. It still works. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Has anyone tried it? Do you think that it wouls seal better than an old one? Looking to stop the oil spewing everywhere from mine. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
Looks like it might fit. Can anyone confirm? Motorad MO-85 Oil Filler Cap https://www.amazon.com/dp/B000V57RPU/ref=cm_sw_r_sms_apa_i_8ZcNEb688DY70 My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I know you said you spun the pulleys but did you check the harmonic balancer? They will seperate with time. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
$700 2wd no title
watchamakalit replied to watchamakalit's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I could see it for parts. But have to agree. -
awaiting trade updates....
$700 2wd no title
watchamakalit posted a topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
https://greenville.craigslist.org/pts/d/simpsonville-jeep-comanche/7104431992.html Someone grab this!!!!! Chrome tail lights and a chrome tailgate handle!!!!! -
what year did the bench seat get headrests?
watchamakalit replied to Pete M's topic in MJ Tech: Modification and Repairs
My 88 pioneer does not have headrests on the bench. However the '90 buckets I swapped in have headrests. -
I know where there are at least 3 in the same salvage yard..... My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
I forgot. Add it to the registry. Lol My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
how many miles on your truck's factory engine?
Ok I'll give that a try. I couldnt even get it to latch when I tried last time. But I didn't oil it either. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
Welcome to the community. This is a great place to start: http://cruiser54.com/ As far as the 4wd goes, you will need a 4wd trans, tcaseand shift linkage, driveshaft, plus a few interior parts. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Looks like a good use for some flexseal. Lol My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
Yes I have. I have a pretty bad leak at the cap still. I tried to do cruisers mod to the cap but it made it too tight to get all the way on. Been thinking about a late model valve cover swap. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t -
Transmission and Tranfer-Case ?
Stiffer isn't always better when it comes to engine and trans mounts. Ask the folks that have ran poly bushings. I wouldnt try to re-enginerd it. I would install a new factory mount and call it a day. -
Speedometer Fluctuations
watchamakalit replied to j_gevans's topic in MJ Tech: Modification and Repairs
I would have to agree. I had the same issue before I replaced my cable. Now smooth as a babys bottom. -
167,000 running like a champ. I have entertained the idea of swapping motors but this one isnt terrible. Just thought about a new one with less blow by and consequently fewer oil leaks.
