9
Everything posted by 87MJTIM
Very rough idle and fuel leak on rail
87MJTIM replied to Jesse J's topic in MJ Tech: Modification and Repairs
87s did not come from the factory with a ballast resistor. There was a TSB to address the loud fuel pump with a dealer installed BR. My 87 doesn't have a BR. I have a parts 87 XJ that has the BR installed. -
Passenger side bed panel (LB) - no rust around wheel arch or the lower rear panel? (Preferably from a bed that has a trashed driver's side.)
Rockers and/or cab corners?
First, welcome to the obsession and madness. Next, change all fluids, coolant and oil. Get new plugs, wires, and dist. cap. New battery. Since it hasn't run in 20+ yrs, try turning the engine by hand to make sure it hasn't seized up. Spray some WD40 or PB Blaster in each cylinder to lube up the cylinder to ease the cranking. Try starting it. If it runs, then perform Cruiser's Renix tips (www.cruiser54.com). A good engine scanning tool is Nick In Time's Renix Engine Monitor (REM) (www.nickintimedesign.com). This will help you see how the sensors are performing. Once you have the engine running, focus on the brakes and tires. Good luck. Keep asking questions. Everyone is here and willing to help.
Rusted Hub Assy | Can't remove
87MJTIM replied to howeitsdone's topic in MJ Tech: Modification and Repairs
A 10 lb slide hammer and a hub puller. Acetylene torch is hotter than propane, but not as hot as Oxy-acetylene. -
HEAT is your friend! Can you get a propane torch close to the contact surfaces? -
Do you have the heat shield that goes between the manifold and the fuel rail?
Dash Light Issue Any Ideas?
87MJTIM replied to Coastal NC Jeeper's topic in MJ Tech: Modification and Repairs
I was have issues with my clock fading in and out of brightness. I did the dash grounding upgrade (Cruiser54) and now my clock displays bright. All dash lights are brighter now also. If you haven't done the ground upgrade, try that first. -
Coolant temp sensor location
87MJTIM replied to Chukkklez's topic in MJ Tech: Modification and Repairs
On the block, one is the coolant temperature sensor, the other is a knock sensor. Check out www.lunged.com for more useful information. -
proper water pump? Some pumps have the blades facing opposite direction. The belt spins the pump "backwards." I don't know how to check it when mounted.
Did you replace the hoses, especially the lower one? Those are supposed to have an internal spring to keep the hose from collapsing from the water pump suction. If the spring is gone or the hose is squishy, then the hose may collapse, restricting coolant flow.
Not a “car” movie, but a movie with cars…and very funny. It’s a mad mad mad mad world
It looks similar to a "pocket screw." You know the part. You've taken something apart. When you finish putting it back together you look around and see that one screw still lying there. You don't remember what it went into or where it belongs. So, you put it in your pocket. Problem solved!
I will be there Sat on the field.
NP231 fluid replacement/additives
87MJTIM replied to coolwind57's topic in MJ Tech: Modification and Repairs
I believe the NP231 takes ATF. I don't know what grade, though. -
The early AX15s have a 1/2" tip (89.5 to 93(?)). The later AX15s have a 3/4" tip (94+). One part to look for is the front bearing cover/retainer plate. The cover has sleeve the goes over the input shaft. If the sleeve is short, then it takes an internal slave cylinder. If the sleeve is long (3") then it takes an external slave cylinder. From the picture, it looks like a short sleeve on the shaft, but I cannot see very well.
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
The BA10 BH does not fit the AX15. You need a bell housing, the dust shield, the internal shift fork (if external), the crossmember and the tcase shift linkage.
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
NP231J: NP - New Process; J - Jeep version. Your tcase is an NP231J. However, it has a 21 spline input shaft. The AX15 has a 23 spline output shaft. You either need a tcase that has the 23 spline input or change your existing input shaft. Rockauto shows 23 spline shafts for $90 to $100. I bet you could find a tcase for that amount or less.
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
“England and America are two countries separated by the same language.” George B Shaw
Junk yard! The AX15 is not difficult to work on. Having a shop press (or friend with one) is good to have. Otherwise, some basic tools are all you need: socket sets, snap ring plyers, rubber mallet, feeler gauges...
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
That was part of our rebellion against Britain after the first war. We dropped the "u" from color, flavor, neighbor, etc. We also stopped drinking tea. We pronounce "Z" as zee, not zed. (That one took me a while to understand just what the heck you guys were saying.) Happy Canada Day, btw.
The tcase may hang too low or strike the bottom of the floor. I cannot remember which way it clocks to the trans. Either way, a YJ tcase clocks differently than an XJ tcase. The difference is from the bolt holes at the rear of the transmission, not the bolt holes on the tcase. Also, looking at the pictures of your MJ, the grill is upside down. Complete your signature: MJ yr., engine, trans, any modification done by you or a PO. Include your location: state (US) or province (CA).
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
As mentioned in your "Help!" thread - AX15 crossmember!
You can keep your driveshafts. The XJ rear DS will be too short. The front is the same for both MJ and XJ. The picture shows the bell housing has the external slave cylinder . The tcase shifter in the picture looks like a YJ not an XJ. If the set up came off a YJ, the tcase is clocked differently to the trans. If so, when you install the tcase it may strike the bottom of the floor.
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
In addition to the AX15 and matching tcase, you will need the crossmember, and tcase shift linkage. The BA10 crossmember doesn't fit. The tcase shifter can be "modified" to fit. What year did the AX15 come from? The input shaft tip changed sizes in 94+. You may have to change the pilot bearing/bushing. Pre 94 - 1/2" tip; Post 93 - 3/4" tip. Does the AX15 have the internal or external slave cylinder bell housing? The external is more desirable.
- 72 replies
- jeep comanche 4wd
- jeep
(and 2 more)
Tagged with:
