Everything posted by Salvagedcircuit
Very cool!
No probs. It's not the most affordable way to do it (I think each plated bolt is like $1.25 each locally) but I found it a lot more convenient than cutting small squares or circles and then having to move a magnet every few tac welds. You will have to wire wheel the zinc plated elevator bolts though. It is cheaper to grab some from mcmaster.
Nice work. What I did with holes ~1/4in and larger was to tap in elevator bolts and weld it up. I grabbed the shortest elevator bolts with the largest head size I could find at the local hardware store and lopped off the threaded end leaving a short stem. Head size was about 1.5in diameter. It's nice because you can just tap in the bolt stem into the hole and it'll hold itself in place while you weld. For accumulations of tiny holes, if the area was weak and thin, I would elevator bolt it. If not, I seam sealed it. Seam sealer filled in the holes no problemo.
Here's my drivers side. This was a good condition mj on the east coast. Wirewheel the rust and seam sealer away on the drivers side and then you can get a good idea about the metal condition. Carpet out: The solution: You will likely not need to do this much work, yours looks a lot better than mine.
Installed a Touchscreen Headunit
Salvagedcircuit replied to MississippiComanche's topic in MJ Tech: Modification and Repairs
I've seen a lot of variations of these ~1.25-slot-Din-to-1-slot-Din radios. https://www.amazon.com/gp/product/B0CB635ZGL/ https://www.amazon.com/gp/product/B0CB5DP1J3/ They all seem like clone-zone products of dubious quality sold by alphabet sellers on amazon / ebay / aliexpress. I think I should grab one for a teardown to see what they are really made of. There is no doubt these are tailor made for eastern markets and resold to western markets. Thus, I bet there's no western microcontrollers ADCs, DACs or sound specific ICs. You will not find a Analog Devices Sharc DSP in one of these like you'd find in an established brand. Cloned microcontrollers are likely not going to have DRM enabled either, so ironically, these cloned devices will be more useful than legit ones lol. Why bother paying to join an electronics consortium when you can clone the designs yourself? I bet these are straight up an espressif esp32's with additional memory and a cloned audio microcontroller. Just look at the photos. Have you ever seen a trapezoidal USB port? -
I see all three embedded youtube videos @gogmorgo posted.
1990 Comanche Eliminator
Salvagedcircuit replied to pizzaman09's topic in Member Projects: Your Comanches
Neat solution! nice job. -
Merry Christmas to everybody here
Busted LCD clocks
Salvagedcircuit replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Custom LCD segment displays can be produced via a contract manufacturer: Granted, I doubt that needs to be done here. I can imagine AMC used whatever was inexpensive and plentiful to get a hold of when they had the clocks produced. I have not yet had the time to look at and analyze the broken clocks I got from you, but whenever I do, I'll let you know Best case scenario, a similar sized transflective 7-segment tft LCD can be found and utilized. -
Clean Wiring Layout
Salvagedcircuit replied to Orthocad's topic in MJ Tech: Modification and Repairs
I wrote up this guide which you might find useful, but it is mainly targeted at the 4.0L engine because that's what I'm most familiar with: A lot of these photos came from Bring A Trailer listings of jeeps with the specific years. -
Radiator gave up the ghost
Salvagedcircuit replied to Smokeyyank's topic in MJ Tech: Modification and Repairs
He's 100% right! Previous owner was careless and left me a mangled mess. Luckily these lines are still available. Thank goodness! -
Hahahaha. "HAL, make me a photo of an 80s jeep pickup crossed with a chia pet and Bob Ross on a picturesque lake sunset" I can do that Dave
new old paperwork discovered! also new racing print!
Salvagedcircuit replied to Pete M's topic in The Pub
Those would make some cool posters indeed -
Ultra cool find Pete -
Brand New Taillight Lens Installation
Salvagedcircuit replied to MYE Jeep's topic in MJ Tech: DIY Projects and Write-Ups
This is an excellent guide. Many thanks for being thorough! If I end up taking mine apart, I may just use sem seam-sealer or 3M 08008 Black Weatherstrip /gasket Adhesive to seal them up again. -
widdeeee body mod lol.
Wow, it certainly does!
So I thought I saw a Street Comanche….
Salvagedcircuit replied to NorthwestMJ's topic in Member Projects: Your Comanches
I think I'll chime in here: Man this thing is soo unique. It must be a treasure to see it pass by. -
Rubbing alcohol and Goo gone work wonders. Rubbing alcohol attacks clear plastics (can make opaque and crack), so avoid in that specific case.
That's one hell of an awesome build! Thanks for sharing these photos. That one deserves it's own poster!
