Everything posted by Salvagedcircuit
Gosh, I'm glad you made it. You'll push through this! Wishing you a smooth and thorough recovery.
Key parts now has the comanche entire floor halves: https://www.keypartsonline.com/86-92-jeep-comanche-cab-floor-pan-drivers-side/ https://www.ebay.com/itm/175967748115 And the floor caps and side brackets https://www.keypartsonline.com/search.php?search_query=comanche https://www.ebay.com/itm/175862529072
Congrats! Make sure to install some kind of inline fuse to save you headaches in the future
Very cool project! Some folks dig the sun faded paint. My rear bumper is dented like yours, but I can't bring myself to replace it because it functionally works and there's nothing wrong with it. I think the previous owner tried backing into a small tree to push it over Good luck!
December 2023 - The YouTube Comanche
Salvagedcircuit replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Well deserved! That truck has certainly been places! -
Keep the fleet strong my dude What a find!
Time for CAD Delete?
Salvagedcircuit replied to acfortier's topic in MJ Tech: Modification and Repairs
Wow! That's incredible innovation right there! Always wanted to flush the coolant to replace a Serpentine belt
1990 Big Ton Shell project
Salvagedcircuit replied to rhar_tley's topic in Member Projects: Your Comanches
What an absolute steal. Sounds like the makings of a great combo. Good luck with it! -
This is mine currently. The OP said he did something to the CAD axle, but did not say what. While servicing the front axle, cleaning out the diff and adding in new fluid, I inspected the CAD axle. The collar is joining the axle halves. I did not touch any clips or the position of the fork and just put it back in place. There are currently no vacuum lines going to the CAD axle. The lines and diaphragm are capped off. I believe the fork is mating inside the collar. The vacuum diaphragm is pointing towards the passenger front wheel. Is this setup correctly as a CAD axle delete? Thanks. -
Similarly, has anyone tried the Alloy USA 451100 Differential Permanent Cable Lock Kit CAD delete? I moved the collar over on mine, but it sure would be nice knowing that the collar is not going to slide on me over time. I've seen redneck methods of using ring clamps to hold the collar, but that does not sit well with me. This method looks pretty straightforward. -
That's a lotta work right there! Hats off to you! What are you thinking of doing with the throttle body? Take an HO TB and adapt it to renix? Nice work!
Nice. I actually just got a 3d printer, so I'm thinking of printing one and comparing side by side to the real one. My previous 3d printer was a clone of the OG makerbot. It was pain to use every time, so I stopped using it. My new one is so, so nice. The files are still CC0, so anyone can print for any reason etc..
My brother and I grabbed the comanche and took it on a 600mi journey on black Friday. It's first long mile trip. New Hampshire > New Jersey > Massachusetts > New Hampshire. New leaf springs and suspension did not sweat a bit. It took it like a champ. That big ol EV charger weighs 750lbs. The charger came from the finest parts of New Jersey, as one would expect
If I had the room for another, I'd get it for $2500.
Interesting. I was debating putting small tweeters in the door A pillar corners, but I have not decided if I want the manual stick mirrors or leave the outside-adjust mirrors. The question is whether the A pillar spot is more appropriate for the tweeter than the lower dash. I'm not going after the add a 500w amp + dsp setup, just a nice stock radio setup. My current infinity kapps seem more than adequate for my needs and they were pretty cheap on ebay.
Yep. I grabbed the rubber grommets for the doors and upgraded the wire from 20awg to 16awg. My metra radio harness is 18awg, and 20awg is a bit undersized. I'm going to see if there's 16awg crimps for the radio wiring harness on digikey, so it's at least 16awg for the speakers. I found it on page 75. Thanks! I looked around and it seems that "J" is the 14awg ground for the power door locks / power door windows. Thanks a ton guys for helping me troubleshoot!
I adding in the rubber speaker grommets that were missing from my base comanche, and I noticed the PO ghost cliped the front left driver speaker to a 3 pin connector. I looked through the 88 electrical manual and I could not find a reference to a 3 pin left front speaker connector. This 3 pin connector is shown below and features a black, green and black-yellow wire. The solid black wire is not connected to the speaker. Does anyone know what this black wire connects to? Thanks!
Routing of factory antenna cable?
Salvagedcircuit replied to EUREKA's topic in MJ Tech: Modification and Repairs
Woah, there's a sight you don't see everyday. I was wondering how they routed wires for the power antenna. Thanks for the photos. -
The antenna cable has a big ol rubber cone like this. Unfortunately, some are larger than others and don't always fit. If it's smaller, you can always heatshrink the OD and shove it in the panel hole. She'll be right. Also, @fiatslug87 I did not realize the front kick panels had sound deadening juke behind them. Interesting. My radio-less base model did not.
