Salvagedcircuit
Everything posted by Salvagedcircuit
  1. Number 4 indeed. Keep in mind there are multiple radio antenna cables that AMC / chrysler used through the years. There are different antenna connectors and different sheet metal panel rubber plugs. Make sure that hole is sealed well as it's a source of water ingress from the front fenders. Some folks have had success using these: https://www.amazon.com/gp/product/B08LGNDD2G/ Good luck
  2. I'm going to check this thanks. I added 3/4in neoprene rubber below the new vinyl floor. no floor mats. When the pedal is fully depressed, there is still a gap between the pedal and the flooring, so I don't think the flooring is to blame. Great idea, I'm going to do this I will check this, but I don't remember hearing any strange noises I'm going to grab my vacuum tester and check this, thanks. I relocated my canister under my expansion tank, but the rubber lines to it are very old, I should probably replace them, as they are the last lines that are stock. factory air box, air filter has 50 miles on it. I have not observed any oil stains on it. Thanks tremendously for the input guys!
  3. I can check my cat with a usb endoscope camera. Thanks.
  4. 1) I have to check this 2) 3.55 3) 235/75R15
  5. I guess it's time to CAD mine up and duplicate it. Obviously it needs a better bottom attachment mechanism, and a removal of that proud rubbermaid logo lip, but otherwise the overall design is nice.
  6. I CADed up the dash switch blank found on XJs and Mjs from 1985-1996. It is exact. These files are free to download. I declare these files as Creative Commons CC0. Anyone can use these files for any application etc... If you are in need of this switch blank, you can 3D print one using ABS or PLA. The OEM blank has a textured center, as shown in the renders. To get replicate this texture, you can tape off the switch blank border and bead blast the center ABS lightly. It should produce a decently matte finish. If there is enough demand, maybe you can convince @Dzimm to print these up and list em for sale. Enjoy! XJ-MJ-switch-blank.STEP XJ-MJ-switch-blank.STL
  7. I've been slowly refurbishing my Comanche back to stock since initial purchase in 2022. The engine sounds excellent and the idle is stable around 650-800rpm. It has been decently reliable so far and I've been using it to run errands around town with no sweat. I have ironed out most of the problems with the vehicle but one remains: I can't accelerate above 60mph on flat ground. No matter what I do, I have to put my foot to the floor and hold it to approach 60mph. I'm guessing this is not normal? I know these are not speed demons, but I have to keep flooring it to maintain 60mph. I don't know why. There are no weird engine sounds, there are no strange transmission noises. The vehicle does not struggle or hesitate to accelerate from 0-60mph, it just plateaus at 60mph almost like there's a software limiter, but obviously there isn't. Where do I start troubleshooting this? Is my AW4 transmission not shifting into 3rd / 4th? Is is possible that my TPS needs adjustment? Condition: -IAC cleaned -throttle body thoroughly cleaned -new throttle body gasket -threaded fitting to throttle body for new hose to map sensor. no leaks.
  8. It looks like the Rubbermaid Plastic Car Cup Holder Organizer Storage Tray 3318-20, has been officially discontinued. I tried to grab another as a spare and It's gone everywhere. I contacted the company, Pilot automotive, that acquired the Rubbermaid auto rights and they told me it's discontinued.
  9. All the LS swap owners nod in agreement
  10. Someone on comancheclub asked about a spare grommet a while back and I can't find the post. I CADed up the Oval shaped 4.0L Engine Control Harness Rubber Grommet. It is exact. These files are free to download. I declare these files as Creative Commons CC0. Anyone can use these files for any application etc... If you are in need of this grommet, you can 3D print one using TPU. If you want to go overboard, you can make a silicone mold using this same CAD. If there is enough demand, maybe you can convince@Dzimm to print these up and list em for sale. Enjoy! XJ MJ Oval firewall boot.STL XJ MJ Oval firewall boot.STEP
  11. Wow, what a wild post. I don't see any axles there so everything is in parts. Bonkers!
  12. Nice. Oil coat the bottom or undercoat that lil guy and you should be good!
  13. Ooofh. Sorry to to hear it was a pain. I havn't done it myself. Any techniques that you found worked?
  14. Here's his video: From my searches, the back glass and gasket are completely held in by urethane glue, the same stuff used to install windshields. I can imagine a series of plastic pry tools and painters putty knives will let you remove the gasket relatively easily. Once the gasket is off, he used 1/16in stainless braided cable, the same as the parking break cable. You can also just purchase 1/16in garage door wire from any hardware store, it's the same thing. Kody used a torch and a screwdriver to melt a hole in the urethane. A soldering iron would likely work the same. Don't forget a glove so you don't kill your hands. Good luck!
  15. Actually, Kody kilmer on facebook did a video on how to remove the back glass let me find it.
  16. That back glass is definitely a nice have. Too bad it's a process to remove correctly.
  17. Updated! If you have the parts in my first post, let me know!
  18. So, what you are saying is, the best thing to grab off a scrap comanche, is the entire comanche. Got it.
  19. Thanks @schardein for the incredibly detailed and thorough response Also, thanks for the mcmastercarr link @GonzoTheGreat I plan on grabbing my set of taps and trying to recover the threads in the doors. If they are non recoverable, I'll drill the next size up and retap. I'm planning on using slightly longer sheet metal screws as the PO broke some of the plastic studs where the lower dash mounts. Edit: The door handle screws are M4-0.70 x16mm in length with an oval head profile. Thanks again!
  20. The PO butchered the interior of my comanche and I have found a mixture of drywall screws, self tapping screws, sheet metal screws, zippies and machine screws holding together my lower dash and door handles. What are the stock screws used on the comanche lower dash and the door handles? My synopsis: The three screws retaining the lower dash, just below the steering wheel fasten into sheet metal and are probably machine screws. Possibly 8-32 Phillips Oval Head Screws? The remaining screws on the lower dash are probably self tapping #6 Oval Head Screws as they fasten into plastic studs (some of mine are cracked off). The screw below the ash tray is likely a machine screw. I am not sure about the door handles. It seems the AMC engineers really liked oval head philips as I cannot find those locally at all and I'm sure the OP was not inclined to seek them out. My interior is currently a medley of screws that is for sure. Thanks!
  21. Neat! It's called the Roper Whitney Jr No. # 5. It comes in a kit up to 9/32. It comes in a nice plastic box. I purchased a new old stock one last christmas for my brother. Worth every penny of that $60. Roper also makes a larger hand punch, the XX, that goes up to 17/32. Both are still made in the states today, they just come in a plastic boxs instead of a metal ones. I have both and my brother uses them all the time to make head gaskets for older small engines.
  22. You sir are awesome. Thanks a ton! I plan on using the 9/32 in punch on my roper whitney hand punch. It is an incredible handy tool for projects like these and gasket making. Thanks for everyone who chimed in and provided feedback. It helps tremendously.
  23. I was thinking of putting an x-acto knife blade in the thread insert and putting the door card on. then looking at where the mark is and using a hole punch to make a proper hole.
