89 MJ
    8
Everything posted by 89 MJ
  1. That’s awesome! What an adventure.
  2. This was one of my many reasons to go to the southwest for school and will look for a job out here after school too. It’s so much better for wheeling. I hate cleaning mud off of things.
  3. 89 MJ
    2000 XJ problem
    Basically it replaces the coil on plug stuff with a Viper coil. It’s a coil with 6 terminals for your plug wires. Here is a video on it:
  4. That testing procedure I think was in one of the threads I posted.
  5. 89 MJ
    2000 XJ problem
    I see. I’ll stick with Renix haha
  6. December 2024 - @OffGridResearch's Street Comanche #12 Build Thread - Year/Model - 1987 Jeep Comanche (Street Comanche #12) Drivetrain- Renix 4.0 with Lightweight Flywheel 6 puck clutch and an Ax15. Cooling- Aluminum Rad with Cnc solid Fan hub Electrical/Ignition- Stock Suspension/Steering- Lowered Around 6 in up front 5 in the rear Interior- Corbeau Limited edition Seats Hurst Shifter Brakes- Stock Lighting Off Grid Research Mega Glow Running lights Exterior- Off Grid Research Evo II Body Kit, Off Grid Research RaceRubi Hood Wheel & Tires- 20 in American Racing Wheels Misc- Lots of Misc upgrades and power mods coming soon Best MJ story- Just being a part of this Community Since around 2008, I've been a huge street Comanche Enthusiast and it took me about 10 years to find this truck. I even had another one at one point. But this one i couldn't let go. I've built so many Comanches, Driven and wheeled Moab, Done work around the Home and Ranch, Climbed some of my first hills in 4wd in these trucks. I was blessed to be given a Pioneer long bed and went to get it with my girlfriend at the time, who now is the mother of my 2 boys, And we will never sell that truck. And my Street Comanche will be built and handed down to my boys when i am old and grey. I love these trucks, they are attractive, rare, tough, and just work. Ill Be a hardcore Comanche enthusiast till i die. My business Off Grid Research is focused on highlighting a long forgotten special sector of Jeep history. The Archer Brothers SCCA dominance in the Manufacturers truck series, Leading to the creation of the 100 Street Comanches. Now people can build their own Street Jeeps again. Cheers.
  7. Glad to see its on the road
  8. This forum is really one of a kind. I’m hoping you stick around. You seem to do very thorough research before asking a question and the headlight relay harness was very well done.
  9. 89 MJ
    2000 XJ problem
    I looked it up quickly, and if it’s a coil, you’d need the whole rail. Could do the Viper coil mod though. Not sure on all of the codes. Did you check the plug and plug wire? Are you sure that injector is firing?
  10. Ok. Have you gone through Cruiser’s Tips? Particularly the ones about cleaning grounds. How does it run once you get it started? Does it have a high idle or a miss or anything on startup? Or is it smooth running right away? Renix takes a little bit of cranking to get started compared to carbureted vehicles or newer vehicles. Once Cruiser’s tips are done, these threads might be worth reading.
  11. Depending on how much they roughed the surface up, I wonder if you’d be better off DAing the whole thing down with 180 followed by 320, then priming and painting it. I’m not talking about making it too nice, but rather making it all one color. That truck looks straight enough and solid enough that it deserves paint.
  12. Passenger side front fender on the 83 has been flared to match the width of the bed. Maybe this truck will end up with a razor grille
  13. Gauge cluster and steering column are installed. Custom shifter linkage for the column shift
  14. I’d wet sand it with 800 grit. Then up to 1500 when you’re down to blue to get rid of the sand scratches.
  15. More parts on the way. This time it’s a partial set of sill And here is why I needed them. Super corroded to the point of having holes. Actually, only needed the one for the drivers door, but spares don’t hurt.
  16. Not this year. Maybe someday in the future.
  17. Yes it is. There’s not a lot of trucks I would say this about, but I think that one’s probably worth the money.
  18. Post the VIN in the registry and you’ll get a mostly correct one
  19. That sounds much better for a car guy haha
  20. This. It might be worth pricing out building the D35 compared to buying a different axle, welding perches on it, and putting a locker or limited slip in it.
  21. As in it cranks slower or it cranks for a longer period of time? If it’s cranking slower, it’s probably because of the cold and the battery aging.
  22. This is a good point. I believe it was you who said that 35s under an 8.8 give as much clearance as 31s under a D35. It’s a good option when upgraded, but on a budget, I’d recommend swapping.
  23. 89 MJ
    1J7FT36L2KL512118
    Looks like you did it right. That’s a good looking truck!
