eaglescout526
Administrators
    13
  1. Build Date: 12/18/88 *B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -SA Charcoal 161 Zone 61-Atlanta 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Body Code: TL61 2WD Lowline Decor SWB
  2. Build Date: 4/26/88
  3. Build Date: 4/20/87.
  4. You could always try the option of having it rebuilt. There’s some guys on here that have gone that route.
  5. Step one: Take old Subaru Outback and toss engine. Step two: Toss in AMC 4.2L with 4.0L controls and 4WD system. Step three: Eagle spiritual successor. Or just buy an Eagle. I would actually do this as a project but it’s not practical. I’d just do it out of spite.
  6. To back up AZJeff, I can say that I have rarely seen my truck climb over 212. I have seen it get to 220 but that was on a freeway drive and it stayed like that until I returned home. Course it’s the 2.5L and I drive mostly surface streets home but I never see the gauge go over 210. And I don’t even have AC at all but I have never had a overheat issue except for the time my head gasket was bad. That was the only overheating issue I ever had.
  7. Sending PM
  8. Yes! Did you come across a whole thing?
  9. Easy for 4.0L owners to say. Not so much 2.5L
  10. Body code T-RWD M-medium price class. (Decor based) 62-Long Bed I finally figured it out!
  11. Basically the whole diagram is what you will need. Parts 3, 4 and 5 is the pump mount assembly minus the pump. 19 is the reservoir mount. So if you Find a 86-90 Jeep with 2.5L and power steering, you'll want to snag the whole shebang.
  12. That's only the surface of the interesting things you will find that you would never have guessed these trucks have.
  13. I don't know how essential the High Pressure sensor is to the operation of the RENIX system. Here's a diagram of what you'll need: Number 23 is the High pressure sensor. The wiring for that little sensor may very well be on the harness already. I can't imagine it being essential but it probably helps.
  14. That is correct, you will also need the lines and wiring. If you can find an XJ with the 2.5L.
  15. One dealer has one. The last one.
  16. Well since we are talking about MoPar T-stats, Chrysler uses MotoRad brand T-stats now and clearly swears by them for their 5.7L hemi. Here is a part number of the kit they sell that includes the gasket:
  17. Riding in the middle on a bench seat would be a total blast with that just jabbing you in the chest each time you shift.
  18. Well after one hell of a day at work and all that jazz I decided to go out and replace the rear shocks. I think a week of owning these things is enough prep time to install the shocks. As per the DIY of installing the JK shocks, you do absolutely have to replace the top rear bushing. Good thing my skyjacker shocks happened to have those exact bushings still in good shape. So they got swapped and are now installed. I'll get a picture tomorrow when the oven light turns back on.
  19. You are going to love those 550's. Great driving light.
  20. The mirror part number I provided superseded back in 1988, discontinued in 2012. Chrysler says it works up till the 2001 model year. There’s one part number before it that runs from 84-92 then it supersedes. I have one of these new part number mirror and it fits I just like the look of my old mirror. As for the fuel pump on the ‘91 and ‘92 fuel sending unit, none exist as new old stock. I have access to a more updated catalog of parts and I can see where parts are at and if the superseded or not.
  21. 35007638. I work at a dealer so I can see who has parts. Your internet skills don’t suck. I just happen to have access to resources most don’t have.
  22. I think Chrysler has maybe very few left. I’ll have to look. Edit: There are three left and they come with a screw.
  23. Well that sucks. I don't know how much help I can be but I gotta ask a few questions just to get us somewhere. How old is the battery? Did you go over every connection and check for corrosion/good grounds before you left? Has the alternator been charging properly/putting out correct volts?
